Problem After Tranny Swap!?
Old Jun 9, 2009 | 09:46 PM
aguita's Avatar
aguita
Default Problem After Tranny Swap!?
Hello
Problem solved..Sensor was removed and re-installed but for some reason I get the same Shots around 6k intermitent..also know my vdc-slip lights are on..!
Old Jun 10, 2009 | 03:52 AM
marra23's Avatar
marra23
could be timimg. check the sensors on the tranny.
Old Jun 10, 2009 | 04:30 AM
rcdash's Avatar
rcdash
Getting that CEL code is important. Were you able to read OBD II codes before using those scanners?
Old Jun 10, 2009 | 05:08 AM
captj3's Avatar
captj3
Check the crank position sensor. Make sure it's plugged in or you may have to replace it due to accidently hitting it or dropping it. This thing has created tons of problems that don't even throw a code or the right code. Yet replacing it fixes the problem 90% of the time it may be worth the $60 dollars for the part. Did you do anything else to the car? You can also reset the ecu by disconnecting the battery.
Old Jun 10, 2009 | 08:07 AM
aguita's Avatar
aguita
Never got a CEL..but this thing happens on the my other Z.I cannot connect to the obd port..
if the sensor is not connected I guess that the car wont start right??so It must be connected..
Old Jun 10, 2009 | 08:15 AM
JCat's Avatar
JCat
Same problem happened to me . . . . and it was the crank position sensor. It got mis-aligned.
Old Jun 10, 2009 | 08:49 PM
aguita's Avatar
aguita
up
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
