Forgetting to lower pressure on the DRs at the strip = carnage
Old Jun 20, 2009 | 07:53 AM
Nealoc187's Avatar
Nealoc187
A lot of times you can mitigate wheelhop simply by altering tire pressures. My car will wheelhop pretty bad on street tires sometimes (a million things affect it, tire pressure, track surface, track temp, track prep, bushing wear, bushing stiffness, clutch modulation, etc etc etc) but the first thing I do at the track if I wheelhop is start lowering my tire pressure some and often it will make it less of an issue.
Brian's car never wheelhops to my knowledge when he runs much lower DR pressures at the track, but he just forgot to lower it this time so I had to wait with him at McDonalds for the tow truck to show up and give him a ride back to his place since the tow truck driver had two middle aged asian women in the cab with him... (I don't know, and I didn't ask... lol).
Old Jun 20, 2009 | 01:21 PM
ADMAN's Avatar
ADMAN
"You should be more careful next time..."
Old Jun 20, 2009 | 02:56 PM
350Z400rwhp's Avatar
350Z400rwhp
The wheel hop in our cars is caused by the diff bushing. If you look under and see black streaks around your diff then the bushing has ruptured. Unfortunatly its very expensive to replace this with an aluminum bushing and will cause some driveline whine. The flexing of the bushings causes wheel hop too, its actually the tires gripping and turning inward and slipping and then regripping rather than actual hopping though that causes this. I only get wheel hop at the drag strip, do you guys think lowering the pressure on street tires would help? What would be a safe pressure assuming I'm going well over 100 by the time I would get to the end of the track?
Old Jun 20, 2009 | 05:13 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I wondered what those black streaks were...haha...mine has been ruptured for about 2 years and I didn't even know. This is the FIRST time I've gotten noticeable wheelhop.
Old Jun 20, 2009 | 05:37 PM
Gingervitis526's Avatar
Gingervitis526
Throwing out some free advertising here, I just remember seeing these awhile back.... SPL Solid diff bushings
Old Jun 20, 2009 | 05:40 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Originally Posted by Nexx
similar thing happened to me. i did remember to lower tire pressure but not enough. took it from 35psi to 30. should have taken them down to 22 or so. wheel hopped, got out of it, got on it and now as some of you guys have read, i get a grinding sound from the clutch. at a stand still in neutral i still get a grind when i press and depress the clutch. weird. wheel hop ftl!
You're on street tires, so your case may be different.
Originally Posted by thom000001
Wheel hop will break ANYTHING...upgraded or not......could be made from god's johnson, wheelhop will destroy it.
tom
+1
Originally Posted by Vas@Extended
damn I get wheel hop even on my stock setup.. and especially going from 1st - 2nd gear... my wheel hop is crazy.. what can I do to prevent this?
Feather your clutch more, ease onto your accelerator pedal, and learn to modulate things better.
Originally Posted by djamps
Thanks for the knowledge...I didn't realize lowering the pressure was so important!
This only applies if you're on drag radials. You can also lower your street tire pressure, but they're not meant to be driven with lower pressure. Other drag race tire pressures don't need to be "lowered" since they should be low to begin with anyway.
Originally Posted by Nealoc187
...a million things [can cause wheel hop], tire pressure, track surface, track temp, track prep, bushing wear, bushing stiffness, clutch modulation, etc etc etc...
+1
Old Jun 20, 2009 | 06:57 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
I had the same thing happen to my DSS level 2 the inner CV cage that houses the bearings shattered causing the splines on the axle to slip rounding them off. BFG DR with too much pressure as well
Old Jun 21, 2009 | 06:05 AM
Quamen's Avatar
Quamen
Looks like I may have to make a set of solid diff bushings.
Old Jun 21, 2009 | 06:55 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
The axle shaft pictured looks like a stock one...
Old Jun 21, 2009 | 09:48 AM
Sylvan Lake V35
You might be right I have a bout 4 axles in my garage that might be a stocker for the driver side. I went and looked in my garage again I can't find the level 2??? I went out and took the pictures after I saw your thread but I broke the axle over a year ago sorry for the confusion. I think the level 2 was rounded off more
Old Jun 21, 2009 | 09:54 AM
BoostedProbe's Avatar
BoostedProbe
I had the same thing happen to my DSS level 2 the inner CV cage that houses the bearings shattered causing the splines on the axle to slip rounding them off. BFG DR with too much pressure as well:
I remember that day at Castrol Gord. You were saying (and Dustin) that there was too much wheel hop, and I said lower your tire pressure. I remember you saying that your pressure was in the 34psi range. I think you were also running some crazy negative camber back then too.
Old Jun 22, 2009 | 03:56 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Ouch! Simple mistake that isnt very forgiving with so much power...
Old Jun 22, 2009 | 09:09 AM
Sylvan Lake V35
Yes a lesson learned the hard way. I am going to work on loading up the drivetrain more with the method you recommended.
Old Jun 22, 2009 | 08:22 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I'm going to work on letting air out of my tires...
Old Jun 22, 2009 | 09:09 PM
Sylvan Lake V35
ya and that too. I thought I might get ribbed for that I after I hit submit reply . My stocker broke because of drive train shock so loading the drive train and lower pressure in the DRs both must haves
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
