max boost on 1 BOV??
Hey guys,
at what boost level do you need to consider going from 1x 50mm BOV to 2x BOV?
If you are going to run ~30 psi, would you want 2 BOV's to prevent compressor surge.
I know Jkenefic has 2 on his yellow Z and all the shop race cars do.
Its one of those things where its easier to get another vband flange welded before a kit goes on.
Thanks!
Thanks!
evos run 30pis constantly(alot do) and the turbosmart one i know for a fact hold that without fail and the hks starts to leak around 25ish(stock holds it more efficently) and are usually swapped. However i am not sure if displacement has an affect on psi(pressure is pressure) threshold but ive heard it plays a part.
Tials do have some hefty springs though
It is not a question of psi but rather CFM. Running 30psi on an evo is not that same as running 30psi on a Z since pressure is a measure of restriction and does not indicate a volume. OP, what horsepower level are you looking to be at?
thank you quam, couldnt have put it better myself
figure normal Z power. 15psi @600 hp, 29 psi at xxx hp.
and the only cars with 2 BOV's would be a HR motor with 2 TB's. None of the non-rev or rev-up kits come with 2 BOv;s bc there is only 1 TB.
