My VQ35HR Build
Old Jul 9, 2009 | 09:21 PM
Jasonvs2146's Avatar
Jasonvs2146
Default My VQ35HR Build
Well some of you know my old motor was blown.
I am building a new block. S&R Performance in Tampa FL is doing the work
Here is what we are doing
CP Pistons (.5mm over)
Eagle H Beam Rods
BC Titanium Springs & Retainers
HKS Head Gaskets
ATI Super Damper
ARP Head bolts/Studs
Custom block guards
Im sure I have forgotten something ill update this list as i remember.
Pics will be posted here as it progresses
Old Jul 9, 2009 | 09:25 PM
Jasonvs2146
Here is some pics of the beginning stages of the Bridging/Block Guards
Old Jul 9, 2009 | 09:26 PM
350z 6spd's Avatar
350z 6spd
Ever figure out the cause of the blown motor?
Old Jul 10, 2009 | 09:19 PM
Jasonvs2146
more pics to come monday also numbers n everythin will be posted here
Old Jul 22, 2009 | 01:33 PM
Jasonvs2146
More pics
Before:
After and still waiting to be decked:
Old Jul 22, 2009 | 05:33 PM
ADMAN's Avatar
ADMAN
Sorry about the motor. Congrats on the build.
Old Jul 22, 2009 | 05:35 PM
ryan350z's Avatar
ryan350z
looking good!!
Old Jul 22, 2009 | 07:05 PM
SH Luciano's Avatar
SH Luciano
sweet! good luck with the build up.
Old Jul 24, 2009 | 08:02 AM
Jasonvs2146
If you look at the original pictures that I posted of the VQ engine block, you'll see round cooling passages around each of the cylinders. They are for coolant to run up and down beside the cylinders to cool them off and dissipate the heat from combustion.
The top of the block is called the "deck." You may have heard the term "decking" a block. It means milling the top of the block to true up the deck. A block with coolant openings up to the bottom of the cylinder heads is called an open deck block. Just like in this picture.
If you look at that picture and imagine the tremendous combustion forces and explosions that occur in each of the cylinders, you can see how the open deck configuration would not be best from a performance standpoint. The cylinder becomes unstable and it becomes easier to blow a head gasket.
What S&R did was to weld in billet aluminum into the top of the cylinder cooling passages and create a closed deck block. That's actually pretty cool. I've never seen anyone do that before. The new welded in billet pieces strengthen the block and make it much more resistant to twisting and blowing head gaskets.
Here's the picture after the billet pieces have been welded in. Looks like the block will have to be decked again to clean things up. I hope Bobby posts another picture of the block after it's been decked again. You'll be surprised at how cool it will look.
When you first look at it, it seems like that would cut off the circulation from the cylinder heads. That's what Danny originally asked about. It turns out that these passages do not pass through into the cylinder heads, so there is no actual loss of cooling ability. I suppose technically the coolant doesn't go quite as far up the cylinder as it used to, but it's only slightly less (the thickness of the welded in billet shim).
Old Jul 24, 2009 | 08:22 AM
thom000001's Avatar
thom000001
Is this more cost effective and/or easier than Sleeving the block?........some sleeved block guys are making mucho power and pushing high combustion pressures (38psi of boost at 8.5:1 comp)
I'd be interested to see what the coolant and oil temps due. (we know sleeved motor cars run hotter than stock sleeved cars, this looks like it may be even more impacting)
tom
Old Jul 24, 2009 | 08:24 AM
MDHRZ's Avatar
MDHRZ
What caused the motor to blow the first time?
Old Jul 24, 2009 | 09:53 AM
midz350's Avatar
midz350
It looks like the VR38DETT block!!!
Old Jul 24, 2009 | 10:16 AM
MDHRZ's Avatar
MDHRZ
Can't see the pics right now. I fail
Old Jul 24, 2009 | 10:51 AM
thom000001's Avatar
thom000001
Thanks Hal....stole your pic
Here's what I am referring to......
Here is your setup that you are planning
Here is the VR38 (GTR motor) that looks very similar....except they still have water passages around the bores......I'm just curious what kinda temps you are going to get in the motor.....well water temps won't be high cause there will be no water going near the cylinders.....but those cylinders will be crazy hot (like possible warping aluminum head hot), with no cooling other than fuel.
Just my thoughts
Tom
Old Jul 24, 2009 | 01:33 PM
Jasonvs2146
the shims are only about 1/2 in deep they are not 100%
Old Jul 25, 2009 | 05:52 AM
S&R Performance's Avatar
S&R Performance
Vendor - Former Vendor
There will be some holes drilled around the cylinders.
Old Jul 27, 2009 | 03:17 PM
S&R Performance
Here are some updated pics of the block being cut. We have started drilling holes for the coolant passage.
looking more like a VR38
Old Jul 27, 2009 | 03:23 PM
SH Luciano's Avatar
SH Luciano
it sure is...should be a sick build!
Old Jul 27, 2009 | 03:53 PM
thom000001's Avatar
thom000001
nice...pretty interesting build
tom
Old Jul 27, 2009 | 04:05 PM
0jiggy0's Avatar
0jiggy0
I think the honda guys have been doing this for a while, cant wait to see the results.
