my compression test
Old Jul 17, 2009 | 11:00 AM
  #41
djamps's Avatar
djamps
headgasket? Whats the oil look like?
Old Jul 17, 2009 | 01:59 PM
  #42
NETSHARK's Avatar
NETSHARK
Originally Posted by rcdash
looks like you have oil mixed in with your coolant.
+100000
i had the same problem/coolant color on my other car, it was a head issue it was very slightly broken due to overheating and a 125+ weather.
The problem maybe in the heads not the block itself, just inspect the heads it might be a head issue leakage not fully torqued broken etc not the block itself, don`t give up on the block yet, good luck man :1
another place to check is the stock oil cooler/heater it might be broken try to bypass it by connecting both hoses going to its water ends together and idle the car and check if its dropping any oil or something.
Old Jul 17, 2009 | 03:52 PM
  #43
SmallTuner's Avatar
SmallTuner
dont be sad my friend
ill do it in no time.
trust me
Old Jul 17, 2009 | 04:06 PM
  #44
SmallTuner's Avatar
SmallTuner
Originally Posted by NETSHARK
+100000
hey dude long time no @@
the heads are fresh and new, my head bolts are ARP 1/2" head studs and i torqued them my self (96 FTLB) the engine is just used for a short time.
tuning was very Conservative all the time with 0 knock.
after i did my compressin test again with some oil drops in the cylinders the compressin just jumpd up.
and allso issue started befor installing the new turbos but i was not sure that time.
i think its the heads like u said or the piston to cylinder bore clearance
n e way every thing will be clear after i open the motor.
Old Jul 17, 2009 | 06:35 PM
  #45
rocks's Avatar
rocks
Its probably your heads due to the way the coolant looks. I have over 40k miles on my engine from Todd with no problems. Its not sleeved or forced induction. I just did a compression test on it about two months ago and it was good.
Old Jul 19, 2009 | 12:33 PM
  #46
SmallTuner's Avatar
SmallTuner
damn i open the heads, the water passages all brown color !!!!
Old Jul 19, 2009 | 11:02 PM
  #47
nyqueenz's Avatar
nyqueenz
Originally Posted by SmallTuner
i tune the car, its not making any power more than 570 to the wheels.
any thing more than 16psi is a waste.
power is dropping from 5500 RPM
i checkd the timing, and the cold lash for the rockers its normal
then, i did a compression test.
it was really reallllllly bad
1 = 95
2 = 91
3 = 91
4 = 85
5 = 91
6 = 91
the engine temperture is normal, but its overheating
the overflow tank is allways full with dirt
ill start all over again and rebuild the engine
im not sure how this is happend, bad luck with my darton sleeves.
N E way, i just like to share with u guys
hey where is the shop at in Kuwait? I wanna come check you out..
Old Jul 19, 2009 | 11:45 PM
  #48
boostedmaxima's Avatar
boostedmaxima
Old Jul 20, 2009 | 04:21 AM
  #49
SmallTuner's Avatar
SmallTuner
not a shop
ever thing is done here in my home
im testing and checking and removing opening installing tuning everthing allone by my self
i know its crazy, but thats it
Old Jul 20, 2009 | 05:44 AM
  #50
nyqueenz's Avatar
nyqueenz
^ dang im comin ova takin notes...
Old Jul 20, 2009 | 12:20 PM
  #51
SmallTuner's Avatar
SmallTuner
u welcome any time
ill give u a call tomorrow and we will c.
Old Jul 20, 2009 | 01:16 PM
  #52
nyqueenz's Avatar
nyqueenz
u welcome any time
yea bro let me know i could give u a hand.. workin on cars is my 2nd nature..
issyz
Jul 2, 2017 03:04 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
codek
Sep 28, 2015 03:03 AM
