Rear Mount Twin Turbo
Old Aug 10, 2009 | 02:18 PM
athensgls's Avatar
athensgls
Default Rear Mount Twin Turbo
Ive been running over creative ideas for inovative turbo options for my next build and stumbled across the STS lables turbo chargers. Im familiar with their single kit and know its flaws and its advantages. I personaly love the sound of the turbos through the exhaust (911 turbo + straight pipes = ultimate :-D). Ive been running the idea of doing twin turbo rear mount setup utilizing the STS universaltwin turbo kit, upgrading all the parts to good stuff.
Turbos - Turbonetics gtk 350 x2
Intercooler - will utlize one intercooler in each side of the g35 front bumper to allow air flow much like the JWT and SFR kits.
EMS - FCON V pro with all asessories
Fuel - DW 600cc injectors
Meth- Alcohol injection Systems
wastegate - tial 38MM open dumped
Blow off valve - Tial 50mm
Gauges - zeitronix touch screen + HKS navigator
Boost controll - HKS evc VI
I was wondering if anyone has done this or any input in general so i can get some feed back and continue to look into design and ferther research.
Old Aug 10, 2009 | 02:24 PM
*Boose*'s Avatar
*Boose*
They make one for the gto. But my question is why? All kits for the Z are perfect for your every need. More power get this one, more mid range buy this, dyno queen get this one.
KingBaby's Avatar
KingBaby
Hardest Setting
This new to me...wish you luck...hope you got your card ready
Old Aug 10, 2009 | 02:27 PM
athensgls's Avatar
athensgls
Money isnt an issue as much as the project beign finished correctly
Old Aug 10, 2009 | 02:29 PM
athensgls's Avatar
athensgls
im familiar with all turbos and such and if i do a kit i think i will go with the greddy tuner 20g and a built block but for now im stuck on this rear mount twins idea.
Old Aug 10, 2009 | 02:31 PM
SH Luciano's Avatar
SH Luciano
custom is always cool, just be prepared for some headaches here/there...
Old Aug 10, 2009 | 02:40 PM
KingBaby's Avatar
KingBaby
Hardest Setting
In that case...draw it up
Old Aug 10, 2009 | 02:54 PM
UMW350Z's Avatar
UMW350Z
That is a serious kit that I would not 'fix' until it broke.
Old Aug 10, 2009 | 03:02 PM
0jiggy0's Avatar
0jiggy0
What are you doing for the piping? Theres only so much room under the Z/G. I dont think 2 pipes going back and 2 coming forward would work. I guess you could merge the test pipes together into 1 3 inch pipe that splits off to each turbo. Then have the pipes coming from the turbos merge together to a single 3 inch pipe going forward to a SINGLE intercooler. 2 intercoolers means more pipe. Sounds ambitious but impractical. GL if you decide to keep going.
Old Aug 10, 2009 | 03:08 PM
Ztouring04's Avatar
Ztouring04
I think it would be a cool build....I'm in for updates if you attempt it!!
Old Aug 10, 2009 | 03:36 PM
tilleys99's Avatar
tilleys99
Im thinking of doing a single turbonetics 62-1 on my 07 HR Z. Just need a few more pieces.
Old Aug 10, 2009 | 04:23 PM
sanford's Avatar
sanford
Default check this out bro
https://my350z.com/forum/forced-indu...on-thread.html
i read a couple of pages they sound wicked and good luck
Old Aug 10, 2009 | 06:18 PM
str8dum1's Avatar
str8dum1
no reason you cant do it. fab should be fairly easy and straight forward. Sizing the turbos correctly would be the only thing since the exhaust has soo much length to cover.
Probably be easiest to buy the single kit specific for the Z and modding the uppipe and IC pipe
Old Aug 10, 2009 | 07:43 PM
Zonda85's Avatar
Zonda85
suscribed.....
will the vq35 generate enough exhaust pressure to spool both turbos?
Old Aug 11, 2009 | 03:22 AM
*Boose*'s Avatar
*Boose*
It would be the same as a true dual basically.
Old Aug 11, 2009 | 04:22 AM
marra23's Avatar
marra23
I was thinking similar but for the 370z. GO for it!!
Old Aug 11, 2009 | 05:42 AM
JTinFL's Avatar
JTinFL
I would make sure that you ride around in the regular STS kit first so you can see how they run.
Old Aug 11, 2009 | 08:01 AM
athenG's Avatar
athenG
+1 The sound is amazing but if you want big power then Front-Mount > Rear-Mount. I have a rear-mount and I'm happy but when the time comes when I'm ready to build my motor then I'm leaning toward switching to a front-mount. The sound is just amazing that it is hard to let go though.. lol
Old Aug 11, 2009 | 09:06 AM
athensgls's Avatar
athensgls
is the ride seriously different ive been in a greddtt z on 5-15 psi, and a turbonetics 7-18psi.
Old Aug 11, 2009 | 09:09 AM
athensgls's Avatar
athensgls
i understand lag would be logner due to the physical aspect of the gas having to travel farther. but im going to be using relativly small turbos so lag shouldn't be too out of control. My biggest question is with all the DIY people on this site no one has attempted this? I don't want to be having to fight a uphill battle to get this turbo kit to work efficently.
