Rear Mount Twin Turbo
Old Aug 11, 2009 | 09:49 AM
JTinFL's Avatar
JTinFL
We would have to get the exhaust housing up to around 400F before it would be consistent and make big power on the few STSs kits that I tuned. That means we had to do 4-5 pulls just to get one power run. This causes a lot of heat soak on the engine and I believe this is why they put down smaller numbers with the exact same turbo set up as a front mount setup. This and the boost per gear at the track (1/4 mile) was very weak. We were only seeing 2 to 3 pounds in 1st, 4 or so in 2nd, 6 in 3rd, and 8 in 4th down the quarter mile. Im sure it has a lot to do with the amount of heat at the turbo.
Old Aug 11, 2009 | 09:51 AM
Quamen's Avatar
Quamen
Originally Posted by athensgls
i understand lag would be logner due to the physical aspect of the gas having to travel farther. but im going to be using relativly small turbos so lag shouldn't be too out of control. My biggest question is with all the DIY people on this site no one has attempted this? I don't want to be having to fight a uphill battle to get this turbo kit to work efficently.
Then buy a kit. Custom kits are not a waste of time IMO. However, they are not as easy as face value and they are generally not cheaper than a bolt on kit. Especially a custom twin turbo.
You will generally get bit cost wise on fittings, couplers, clamps and piping that are often hard to account for.
What you want to do is more than reasonable and achieveable. However, your choice in turbo size and A/R will be even more crucial for a rear mount TT.
Old Aug 11, 2009 | 10:24 AM
scotts300's Avatar
scotts300
Agreed.
Z Car Garage (www.zcargarage) put together a single turbo car and I believe they experienced the same situation. Lots of piping, not much boost, so not much power.
Old Aug 11, 2009 | 10:26 AM
athensgls's Avatar
athensgls
bottom line no power, no go imo. The corvettes love the twin rear mount set up is that because of added displacemtn involves more heat meaning by the time they hit the turbos the amount of free energy is still enough to produce effcient power?
Old Aug 11, 2009 | 10:33 AM
Quamen's Avatar
Quamen
Just a quick 30 minute rendering as an idea:
Note that the turbos would not be symetrical in real life and the piping would have different bends in it in order to clear the driveshaft, fuel tank, swaybar and differential. Also please not that the foundry that made the compressor side of the above turbos does not know what they are doing
Old Aug 11, 2009 | 10:47 AM
str8dum1's Avatar
str8dum1
you'll definitely make power. a fully wrapped 2" exhaust and smallish turbos and it would probably be pretty responsive on the street. After the car heated up, bigger turbos probably wouldnt be that bad either.
All we can do is guess. I say try it. Fab'ing the piping wouldnt be too difficult as any exhaust shop could do it fairly quickly.
Chomorro's Avatar
Chomorro
Didnt the sts guys find that an electronic boost controller was solving this issue? This is good info to know, you should post in the sts thread
Old Aug 11, 2009 | 11:28 AM
athensgls's Avatar
athensgls
Old Aug 11, 2009 | 11:51 AM
scotts300's Avatar
scotts300
No intercooler needed with all that piping length! Might as well take a stop through the gas tank to cool down the intake charge while the air is on its 15' journey back to the TB.
Old Aug 11, 2009 | 12:01 PM
CRIDDA's Avatar
CRIDDA
Go for it. We already had a member get to or real close to the 600whp on a built block and different turbo on the single STS kit.
Old Aug 11, 2009 | 12:23 PM
athensgls's Avatar
athensgls
These are on a lexus isf, again a v8 ...
Old Aug 11, 2009 | 12:28 PM
athensgls's Avatar
athensgls
Could turbo blankets be used to solve this problem?
like this baby
quamen your model would combine the downpipes creating a little more back pressure than the free flowing pipes of the other option. with the slight inscrease in back preasure would spool times increase?
Old Aug 11, 2009 | 12:31 PM
JTinFL's Avatar
JTinFL
I would just talk to some STS Z owners to see what they say. Even with 400whp the car would only run high 12 and trap 110-112 on a good day.
Old Aug 11, 2009 | 12:44 PM
athenG's Avatar
athenG
I dont know about 4psi in second gear. I have a crappy Utec BCS and still hit 6+psi on 1st. I think I'll hit full boost on 1st and definitely 8psi on second with a good EBC.
+1
Ran my STS about 20 times already on a quarter mile and here is one of my logs.. I'm set for 8psi by the way.
Edit: I also have the AIT logs so you can see I started at 19C and end up 35C after the pull so AIT is not crazy hot and this was my 6th run of the night.
Code:
[TSMP][RPM][PSIG][MAF][TPS][LOD][KN][SIG][IDC%][IGN][VOEF][BMV][MMV][WBO2][AIT][CLT]
1st Gear
000.40 4522 -11.0 2.1    0    0   0  34.3   7.7 ECU  100 000  1.6  12.07 019  085
000.60 3749 -10.5 1.9    2    0   0  32.2   4.5 ECU  100 000  1.5  15.26 020  086
000.80 3373  -8.5 2.2   41    0   0  41.3  44.9 ECU  100 000  3.4  21.80 018  085
001.00 3844  -0.4 3.7   98   10   0  29.1  36.2 21.0  +5.0 000  3.7  21.51 019  085
001.20 3958  +0.6 3.9   98   10   0  28.1  34.9 21.0  +5.0 000  3.6  15.51 018  085
001.41 4162  +0.7 4.2  100   10   0  28.0  41.0 17.6  +5.0 000  4.0  12.97 017  085
001.60 4501  +1.4 4.3  100   20   0  23.9  47.5 19.0  +5.0 000  4.2  13.21 019  085
001.80 4954  +2.3 4.5   99   30   0  20.9  62.3 18.0  +5.0 000  4.4  13.29 019  085
002.00 5423  +4.0 4.9   99   50   0  22.8  79.7 17.7  +5.0 000  4.6  12.82 019  085
002.20 5911  +6.1 4.9   99   60   0  25.0  90.5 18.8  +5.0 000  4.6  12.27 020  085
002.41 6426  +6.6 5.0   98   40   0  26.8  98.8 17.9  +5.0 000  4.5  11.74 021  086
2nd Gear
002.60 6640  -6.7 2.7    0    0   0  22.6  64.1 19.0 100 000  2.0  11.57 021  086
002.80 6440  -3.6 2.5  100   10   0  34.1   8.4 21.3  +3.0 000  4.4  12.48 021  085
003.01 5927  +2.6 4.7  100   40   0  13.3  59.6 17.8  +3.0 000  4.6  13.28 020  085
003.20 5450  +5.7 4.9  100   70   0  22.2  69.6 14.5  +3.0 000  4.6  12.73 022  085
003.40 5271  +7.0 5.0  100   70   0  07.9   82.9 15.2  +3.0 000  4.6  12.10 020  085
003.59 5326  +7.2 5.0  100   70   0  15.0  87.4 15.6  +3.0 000  4.6  11.97 022  085
003.80 5524  +6.9 5.0  100   70   0  15.0  88.5 15.9  +3.0 000  4.6  11.95 022  085
004.00 5770  +6.9 5.0  100   70   0  23.9  89.2 16.8  +3.0 000  4.6  11.91 023  085
004.20 6025  +6.9 5.0  100   70   0  23.8  90.1 17.2  +3.0 000  4.6  11.85 024  085
004.40 6269  +6.9 5.0  100   70   0  24.9  91.7 17.0  +3.0 000  4.6  11.79 024  085
004.60 6514  +7.1 5.0  100   70   0  24.8  93.3 17.5  +3.0 000  4.6  11.75 025  085
004.80 6950  +3.0 5.0   19   10   0  25.7   0.0 ECU   +3.0 000  2.2  12.20 026  086
3rd Gear
005.00 7060  -6.6 3.5   99   30   0  45.9  47.1 19.1  +3.0 000  4.6  13.29 025  085
005.20 6095  +5.0 4.7  100   60   0  13.1  66.5 16.1  +3.0 000  4.4  13.26 025  085
005.40 5367  +7.1 4.9  100   80   0  16.1  80.9 07.7  +3.0 000  4.6  12.06 026  086
005.60 5242  +8.5 4.9  100   90   0  20.0  86.7 12.3  +3.0 000  4.6  11.51 025  085
005.80 5253  +8.2 5.0  100   80   0  19.4  87.3 13.4  +3.0 000  4.6  11.55 026  086
006.00 5299  +7.5 5.0  100   80   0  16.0  87.6 14.9  +3.0 000  4.6  11.50 025  086
006.20 5439  +7.0 5.0  100   70   0  20.9  87.1 15.4  +3.0 000  4.6  11.43 026  086
006.40 5561  +7.1 5.0  100   70   0  21.0  88.4 15.4  +3.0 000  4.6  11.48 026  086
006.60 5693  +7.2 5.0  100   80   0  22.1  89.1 15.2  +3.0 000  4.6  11.52 028  086
006.80 5827  +7.2 5.0  100   70   0  21.8  90.1 15.5  +3.0 000  4.6  11.52 026  086
007.00 5961  +7.3 5.0  100   70   0  22.8  90.8 16.1  +3.0 000  4.6  11.53 027  086
007.20 6088  +7.3 5.0  100   70   0  22.8  91.6 16.1  +3.0 000  4.6  11.51 027  086
007.40 6213  +7.2 5.0  100   70   0  23.7  92.3 16.1  +3.0 000  4.6  11.47 028  086
007.60 6333  +7.1 5.0  100   70   0  23.7  93.8 16.1  +3.0 000  4.6  11.44 028  086
007.80 6443  +7.5 5.0  100   70   0  23.9  93.9 16.5  +3.0 000  4.6  11.43 028  086
008.00 6548  +7.6 5.0  100   70   0  23.7  94.0 16.7  +3.0 000  4.6  11.46 029  084
008.20 6666  +7.3 5.0  100   70   0  24.9  95.4 16.9  +3.0 000  4.6  11.49 030  086
008.41 6779  +7.3 5.0  100   70   0  25.8  96.6 17.3  +3.0 000  4.6  11.43 030  086
008.59 6877  +7.1 5.0  100   70   0  25.8  97.1 17.0  +3.0 000  4.6  11.31 031  087
4th gear
008.80 7390  -5.2 3.1    1    0   1  13.6  72.0 18.5  +3.0 000  2.8  11.84 031  086
008.99 6821  +0.7 4.4  100   40   0  38.0  42.8 16.0  +1.0 000  4.5  12.73 030  086
009.20 6091  +5.8 4.8  100   70   0  12.0  80.2 15.9  +3.0 000  4.6  12.51 030  086
009.40 5756  +8.4 5.0  100   90   0  15.1  91.9 13.3  +3.0 000  4.6  11.74 030  086
009.59 5723  +8.8 5.0  100   90   0  19.4  98.0 13.0  +3.0 000  4.6  11.48 031  088
009.80 5697  +8.2 5.0  100   80   0  20.9  93.6 13.9  +1.0 000  4.6  11.30 031  086
009.99 5738  +7.9 5.0  100   80   0  20.8  91.5 14.8  +1.0 000  4.6  11.21 031  087
010.20 5820  +7.6 5.0  100   80   0  22.0  88.8 15.1  +1.0 000  4.6  11.30 031  086
010.40 5893  +7.5 5.0  100   80   0  21.7  89.0 15.5  +1.0 000  4.6  11.43 032  086
010.59 5964  +7.6 5.0  100   80   0  22.9  89.6 15.6  +1.0 000  4.6  11.53 032  086
010.80 6030  +7.7 5.0  100   80   0  22.7  89.7 15.9  +1.0 000  4.6  11.55 032  086
011.00 6099  +7.8 5.0  100   80   0  22.8  90.6 15.9  +1.0 000  4.6  11.50 032  086
011.20 6165  +7.7 5.0  100   80   0  22.7  90.7 15.9  +1.0 000  4.6  11.46 032  086
011.40 6222  +7.9 5.0  100   80   0  23.0  91.8 09.3  +1.0 000  4.6  11.41 032  086
011.60 6297  +7.8 5.0  100   80   0  23.9  92.8 15.2  +1.0 000  4.6  11.39 032  086
011.80 6375  +8.0 5.0  100   80   0  23.7  93.0 15.4  +1.0 000  4.6  11.44 032  086
012.00 6437  +7.9 5.0  100   80   0  24.0  93.7 15.6  +1.0 000  4.6  11.43 032  086
012.20 6496  +7.8 5.0  100   80   0  23.9  94.2 15.7  +1.0 000  4.6  11.37 033  086
012.40 6550  +7.8 5.0  100   80   0  24.0  93.9 15.9  +1.0 000  4.6  11.36 033  086
012.60 6615  +8.0 5.0  100   80   0  23.7  93.8 16.1  +1.0 000  4.6  11.35 033  086
012.80 6665  +7.7 5.0  100   80   0  23.7  94.9 16.0  +1.0 000  4.6  11.36 034  087
013.00 6720  +7.7 5.0  100   80   0  24.9  95.3 15.9  +1.0 000  4.6  11.39 035  087
013.20 6792  +7.6 5.0  100   80   0  25.9  95.5 16.0  +1.0 000  4.6  11.41 035  087
013.40 6850  +7.8 5.0  100   80   0  25.9  96.5 16.0  +1.0 000  4.6  11.46 035  087
013.60 6899  +7.6 5.0   82   10   0  25.8  97.1 15.7  +1.0 000  3.5  11.55 035  087
013.80 6626  -8.0 2.8    2    0   0  33.8  13.0 18.0 100 000  2.0  11.47 036  088
014.00 6127 -11.6 1.9    1    0   0  33.0   6.2 18.0 100 000  1.7  12.08 035  088
014.20 5500 -11.9 1.8    2    0   0  25.1   5.6 18.0 100 000  1.5  16.53 035  088
Old Aug 11, 2009 | 12:47 PM
athenG's Avatar
athenG
I only have 373whp on a heavy G35 that weight 3650lbs with me and 19" that weight 60lbs each in the back and still trap 111.x mph. I know it is still weak compared to the other Front-Mount but my driving skills and shifting suck also.
Old Aug 11, 2009 | 12:49 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
+1 and the most expensive thing...time
Old Aug 11, 2009 | 01:02 PM
athensgls's Avatar
athensgls
lets come pare those logs ! i should have my turbonetics logs from back in teh day let me search
Old Aug 11, 2009 | 01:33 PM
  #38
athenG's Avatar
athenG
By the way, I only have a TP and the crappy Utec BCS. My exhaust is not Jet-Hot coated, No heat wrap on the exhaust, no turbo blanket, no wrap on the headers and to make things worst, all my charge pipe underneath the car is also not Jet-Hot coated Just a regular pipe with a paint.. lol Granted I was the first one who had the modified piping that MRC fabricated and STS didnt send him some coated pipe.
Old Aug 11, 2009 | 03:43 PM
  #39
athensgls's Avatar
athensgls
What about headers? i was thinking about using long tube headers. I read about them on these forums https://my350z.com/forum/na-builds/3...-roadster.html
Old Aug 11, 2009 | 04:30 PM
  #40
str8dum1's Avatar
str8dum1
those headers cost $2500 LOL
either way, i'd use the stock manifolds, 2" or maybe 2.25" exhaust pipe and go from there.
