Sleeved block w APS twin turbo temp?
Old Aug 12, 2009 | 04:22 PM
amai21's Avatar
amai21
Default Sleeved block w APS twin turbo temp?
For people with a sleeved block and APS twin turbo setup.....What range of temperatures are you all seeing?
Old Aug 12, 2009 | 07:59 PM
eltness350's Avatar
eltness350
The Untouchable
it depends on a bunch of things...what coolant u r running, low temp t-stat, rear coolant bypass mod, upgraded rad/fans, oil pan spacer/bigger one.....ohh and search...
Old Aug 12, 2009 | 08:20 PM
amai21's Avatar
amai21
Yes to bypass, GTM fan upgrade w/shroud and Spal controller, larger oil pan supplied by APS. I have done a few searches but not really finding answers for sleeved block temps.
Old Aug 13, 2009 | 04:24 AM
westpak's Avatar
westpak
SFZCC
https://my350z.com/forum/forced-indu...n-sleeves.html
Old Aug 13, 2009 | 04:54 AM
amai21's Avatar
amai21
Thanks..... I have noticed that the fan should make quite a bit of a difference. I am still running around 210, and the system has been bled,burped quite of few times.
Old Aug 14, 2009 | 01:21 PM
GTM's Avatar
GTM
Vendor - Former Vendor
I run around 200-210, highway cruise 190's, and as low as 185 at night on the highway.
I think the hottest is has gotten is 215 peak.
Your fine.
-George
GT Motorsports
Old Aug 15, 2009 | 10:31 AM
westpak's Avatar
westpak
SFZCC
Your fine.
-George
GT Motorsports
very similar to mine, maybe around 5-10 deg lower in all settings, I think the bigger opening of the Nismo V2 bumper has helped air flow quite a bit
also have rear cooling mod, Nismo thermostat and bypassed stock oil cooler, also when the sleeves were done the opening was made bigger than the Darton instructions said to, since the first dumbass didn't even enlarge them at all in addition to bad sleeve install
Old Aug 15, 2009 | 10:39 AM
Nexx's Avatar
Nexx
are these water coolant temps or oil temps you guys are comparing?
Old Aug 15, 2009 | 10:48 AM
westpak's Avatar
westpak
SFZCC
my assumption was coolant, oil temps should not differ much from stock
Old Aug 15, 2009 | 06:19 PM
GTM's Avatar
GTM
Coolant. My oil is usually around 210-220 peak 235ish
Old Aug 16, 2009 | 06:57 AM
alan21's Avatar
alan21
my temps are in the same range as you guys give or take 5-10 degrees
Old Aug 16, 2009 | 05:54 PM
amai21's Avatar
amai21
Bypassed stock oil cooler? Upgraded to a aftermarket one, or just got rid of it?
Old Aug 16, 2009 | 05:59 PM
westpak's Avatar
westpak
SFZCC
I removed the coolant line that goes through the stock oil cooler but I did add a Sertrab oil cooler, I figured that it would remove a heat source from the coolant system and cool the oil better, I live in South Florida so I figured I didn't need the coolant to help warm the oil when the car was cold.
Old Aug 23, 2009 | 03:00 PM
amai21's Avatar
amai21
Any mods that can be done to help with A/C bumping up the temps?? I run a constant 198, but the second I turn on the A/C the temp bumps to 208-213. No I cannot stop using it ! Texas heat at 103 is freaking insane to drive in.
Old Aug 23, 2009 | 03:11 PM
XKR's Avatar
XKR
My temp hangs around 200-205 in traffic...maybe a little higher in Houston with AC on.....in outside temps above 95 degrees. As long as your fans are working you will be fine
Old Aug 23, 2009 | 03:14 PM
GTM's Avatar
GTM
Try bleeding your cooling system, you more than likely have air pockets.
Old Aug 23, 2009 | 03:21 PM
XKR's Avatar
XKR
I am sure he means in traffic.....On the freeway my temps will drop....But in traffic....with outside temps above 95 degrees....with AC on....over 200 is the norm for me.
Old Aug 24, 2009 | 04:56 AM
amai21's Avatar
amai21
Iam running 208 in without traffic and every morning I check my coolant, it's topped off! Still I should bleed it more times??
Old Aug 24, 2009 | 04:16 PM
GTM's Avatar
GTM
Checking the coolant doesn't really mean there aren't air pockets, the smallest air pocket will make a difference.
Are you bleeding the system from the factory bleed "T" on the rear passenger side of the engine? That is the highest point of the cooling system and where the air pockets would collect.
-George
Old Aug 24, 2009 | 06:08 PM
ttg35fort's Avatar
ttg35fort
Professional
Mike, was your other motor sleeved?
