AEM Oil temp gauge question,need help please :)
Old Aug 14, 2009 | 07:09 PM
kajuraelai's Avatar
kajuraelai
Default AEM Oil temp gauge question,need help please :)
OK my situation is im looking to install my oil temp probe into the oil pan, now its saying to use one of the adapters and screw it in place, if anyone has this installed which adapter did you use? and did you have to tap into the oil pan again? (im running a vortech kit and really would like to avoid tapping into the actual pan again). I heard you can use the oil plug spot to screw it in, if anyone has done this please let me know... did you have any leak issues? do you have to use plumbers tape to get it to screw in? i really like to avoid this because the thought of something breaking off is something im not even going to entertain in my low brain cell count
please let me know .. any help would be greatly thanked .
Old Aug 14, 2009 | 08:15 PM
frankie945's Avatar
frankie945
I used a oil filter sandwich plate, at least that's what I call it. It has a extra hole drilled in it for probes.
Old Aug 14, 2009 | 08:30 PM
binder's Avatar
binder
I just drilled and tapped my oil pan directly below my vortech return. Straight down all the way until the bottom. I put it there so it's in the oil. Works great.
Spend the money on a spacer if you don't want to drill another tap. I personally didn't care since there is already a hole drilled in. Saved me $100+ on a spacer and i didn't have to wait for it to arrive. I just drilled and used all the same tools for the vortech install.
Old Aug 14, 2009 | 08:37 PM
kajuraelai's Avatar
kajuraelai
actually i do have a spacer, jwt oil spacer to be exact , so i"ll have to drill again thanks guys for the help
Old Aug 15, 2009 | 10:54 AM
westpak's Avatar
westpak
SFZCC
yeah I used the jwt oil pan spacer for my sensor
Old Aug 17, 2009 | 02:55 AM
350z006's Avatar
350z006
I used a greddy oil sandwich...the thread for the greddy were metric while the threads for my oil temp sensor (Stri) were SAE, so I had to re-thread the greddy...no big deal...no oil leaks...
Old Apr 18, 2013 | 08:02 AM
wechslerl's Avatar
wechslerl
Default oil temp sensor instead oil plug
Did you find how to adapt the oil sensor???
issyz
Jul 2, 2017 03:04 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
Li1ag
Sep 28, 2015 02:07 PM
SharX59
Sep 27, 2015 09:23 AM
