Removed EVAP
Old Aug 24, 2009 | 09:46 AM
GreenGoblin's Avatar
GreenGoblin
Default Removed EVAP
I started removing the evap junk out of my car... I got a code which I expected, I can not remember the number off the top of my head. My question is to the gurus or anyone one else who might know. Do you just leave the code and move on or did you add a resistor or something to trick the ecu that it is still there.
I will move to the rear of the car now to remove the carcoal box and other misc. garbage.
So far I have filled up 2 times since the evap stuff has been removed from under the hood and no filling issues knock on wood.
Old Aug 24, 2009 | 10:13 AM
derekinthez's Avatar
derekinthez
I'm interested in hearing answers to this one.
Old Aug 24, 2009 | 05:05 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
On my personal car and customer's wishing to remove evap - I turn the code off via reflash.
People who have emissions testing: Keep in mind, removing the evap system (and/or related codes) will cause EVAP readiness test to show "Not Ready"
Old Aug 25, 2009 | 04:54 PM
jtgli's Avatar
jtgli
Whats the purpose for doing this, if any?
Old Aug 25, 2009 | 05:44 PM
Dynosty's Avatar
Dynosty
Though there are more parts, the two most common reasons would be to clean things up in the engine bay and make room for fuel lines under the car.
Old Aug 25, 2009 | 06:15 PM
rcdash's Avatar
rcdash
To remove extra equipment, hoses, etc. The evaporative system exists solely for the purpose of minimizing hydrocarbon (fuel vapor) release to the atmosphere.
EDIT: oops - Hal beat me to it.
Old Aug 26, 2009 | 08:06 AM
thom000001's Avatar
thom000001
Yup,
for those of us running Graden hoses for fuel lines you need to do this for room. lol
tom
Old Aug 26, 2009 | 10:26 AM
str8dum1's Avatar
str8dum1
^are you running -10an or bigger? 2x -8AN fits easily under the car.
Old Aug 26, 2009 | 10:40 AM
thom000001's Avatar
thom000001
-10 from tank to engine yea.
tom
Old Aug 26, 2009 | 10:51 AM
Dynosty's Avatar
Dynosty
Being that the evap line is the largest tube running under the car it is nice to remove it and have that opened up even if you are only putting a -6 in the place of it.
Old Aug 26, 2009 | 12:28 PM
str8dum1's Avatar
str8dum1
hmm, i guess i never bothered to think what those other lines were. I'm using a hardline between the motor and the tank (CJM stage2) with the stock gas line removed and it fits nicely.
Old Aug 26, 2009 | 12:47 PM
GreenGoblin
That is part of my plan, to delete what is not needed, and make room for the fuel system that will go in its place.
Old Apr 12, 2012 | 04:10 PM
Nickk6's Avatar
Nickk6
Does anyone know how to get rid of the CEL? I need to pass smog. Is there anyone in so cal that can do a re-flash?
Old Apr 12, 2012 | 04:26 PM
djamps's Avatar
djamps
The reflash isn't going to make you pass a smog test it just kills the light.
Old Apr 12, 2012 | 07:12 PM
rcdash's Avatar
rcdash
Actually, a reflash can make the EVAP SRT show "not available" instead of "not ready" so that is pretty cool.
Old Aug 25, 2012 | 06:30 PM
mw9's Avatar
mw9
any updates to this removal. I am in the process of removal and thinking that we might need some sort of check valve on the breather line off the tank, any thoughts
Old Aug 27, 2012 | 03:21 PM
350zion's Avatar
350zion
Professional
I jus installed a check valve on the purge line off the canister.. I didn't remove the whole thing yet, but prolly will in the future.. I jus wanted to get the smell of fuel which was pumped directly in to my car gone....
I haven't driven since I did it but the smell is now gone.. I rerouted the hose towards the back of the car then stuck a check on it...
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Cashwin
Oct 1, 2015 06:36 AM
