Installed Vortech today, with Utec, Speedo and Triple gauge not working, Please Help
Old Aug 31, 2009 | 06:49 PM
Naminos's Avatar
Naminos
Default Installed Vortech today, with Utec, Speedo and Triple gauge not working, Please Help
I just got done with my install, I did the walbro intank, Vortech tuner and a Utec. Now the stock gauges all don't work, they just light up, any ideas?
Please help, this sucks.
Old Aug 31, 2009 | 07:13 PM
Mike@Blackline's Avatar
Mike@Blackline
FI never goes smoothly, makes me not want to do it
Old Aug 31, 2009 | 08:11 PM
350Z400rwhp's Avatar
350Z400rwhp
Are you talking about the dash gauges, the tripple set or all of them? I would start with checking fuses..
Old Aug 31, 2009 | 10:16 PM
Naminos's Avatar
Naminos
The gauge in the triple does a self check win I turn on the ignition, and the speedo flashes my airbag and rpm or mph and fuel don't work they all just light up. It's seems as though there is no signal going to them. I'm wondering if it was from the used Utec I bought form the forums. Everything plugged back in and I checked the fuses. Car drives fine. I'ma have to pull the Utec tomorrow and go from there.
Old Sep 1, 2009 | 07:26 AM
djamps's Avatar
djamps
Does it only happen with the UTEC connected? Make sure it's connected firmly/properly. Sounds like a bad or loose pin/connector on the UTEC.
Old Sep 1, 2009 | 08:56 AM
05Z33's Avatar
05Z33
Just unplug the Utec and reconnect the OEM ECU. If the gauges work then you know where the problem is coming from. Like djamps said make sure the utec is plugged in right.
Old Sep 1, 2009 | 08:58 AM
350Z400rwhp
+1 I think this is the source of your problem.
Old Sep 1, 2009 | 09:28 AM
GreenGoblin's Avatar
GreenGoblin
take a carefull look at all the pins on the utec and oem ecu to make sure none have been bent.
Old Sep 1, 2009 | 06:03 PM
Naminos's Avatar
Naminos
I got it YEAH!!, but boo I kink and snapped a wire on my Utec, whils shoving it on that tight spot. Just got my soldering tools and badabing bada boom. Thanks for the help guys.
Old Sep 1, 2009 | 06:11 PM
wenlipai's Avatar
wenlipai
yeah going FI is PITA
Old Sep 2, 2009 | 07:01 AM
ekelly36's Avatar
ekelly36
atleast is was a small issue
Old Sep 2, 2009 | 07:45 AM
GreenGoblin
gald you got it sorted out.
NissanZcrazy
Nov 2, 2015 06:03 PM
seagrasser
Oct 11, 2015 03:27 PM
Shane86
Sep 17, 2015 05:33 PM
Calinismo350z
Sep 14, 2015 04:04 PM
