please check this map for vortech 3.33 pulley
Old Sep 7, 2009 | 06:15 PM
max-hid's Avatar
max-hid
Default please check this map for vortech 3.33 pulley
please check this map to see if everything that you look is ok..im going to upload the video with the wideband in a few minutes to you tube so you can check...i think is to rich in low rev and it have to much gas consuption...
https://my350z.com/forum/tuning/4547...these-map.html
Old Sep 7, 2009 | 08:07 PM
max-hid's Avatar
max-hid
this is the video of my aem wideband
http://www.youtube.com/watch?v=hTeiuym0Hps
Old Sep 7, 2009 | 10:05 PM
350Z400rwhp's Avatar
350Z400rwhp
Not sure how much of a big deal it is. You look dead on from 3000rpm to redline though and that's where it counts. You are running 10s from idle to 3000, here is when my car was tuned by Sharif and it seems to be high 12's from idle to 3000. I had a belt slip issue but you can get the idea.<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/i668-MEb5WM&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/i668-MEb5WM&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Sep 8, 2009 | 05:29 AM
djamps's Avatar
djamps
too rich in the low end but good up top. When it says 10.0 you are actually less than that because 10.0 is bottomed out. Lean it out down there before you wash your cylinder walls and lose compression!
Old Sep 8, 2009 | 10:22 AM
max-hid's Avatar
max-hid
im going with my tuner today so it can lean mor the car before 3000rpm
Old Sep 8, 2009 | 07:42 PM
max-hid's Avatar
max-hid
this is the car today after the new tune..please check it an give me your aopinion if its ok..im runin 6.6 pound of boost..
http://www.youtube.com/watch?v=4L0Jvn_QG64
Old Sep 8, 2009 | 08:21 PM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
What's going on with the fuel map in the 5k rpm column?
Old Sep 8, 2009 | 08:22 PM
350Z400rwhp
Looks a tad bit lean but not sure where your timing is set at. Mine was running about 12.2 also when Sharif tuned mine so you might be right on.
Old Sep 9, 2009 | 04:02 AM
max-hid's Avatar
max-hid
im going to check in that column because didnt see yesterday what my tuner do..im going to download the new map today and im going to upload the photo to check it..thanks for all your helpp..here in dominican republic tuner are not so good..
Old Sep 9, 2009 | 05:16 AM
djamps's Avatar
djamps
Better, if not slightly lean, but seems to be jumping around alot.
Old Sep 9, 2009 | 05:24 AM
max-hid's Avatar
max-hid
You think it woul be better if i tune it again??at wat afr i need to put it and before 3000rpm what is my afr target??
Old Sep 9, 2009 | 08:49 AM
350Z400rwhp
you look good on the bottom end but I would shoot for 11.4 or so on the top end.
Old Sep 9, 2009 | 10:37 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Do you have any dyno sheet shows A/F? if do, could you post it up?
Old Sep 9, 2009 | 11:22 AM
max-hid's Avatar
max-hid
Today i will post dyno sheet im going for the final tune so you can check it..
Old Sep 9, 2009 | 11:50 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Keep ur eyes on a/f gauge and tuner's computer monitor. And I also agree with 350z400whp about target a/f.
Old Sep 9, 2009 | 12:12 PM
max-hid's Avatar
max-hid
Thanks for the quote..i will..
Fixxxercask
Nov 9, 2015 11:10 AM
2ndchanceZ
Oct 26, 2015 08:03 PM
