Engine build opinions...
Old Sep 18, 2009 | 11:02 AM
max-hid's Avatar
max-hid
Default Engine build opinions...
I have a vortech with 3.12 pulley and im going to build my engine..i want to know what is best do it low compresion(8:5:1) or high compresion pistons(11:1)..im going to put a 50-75 hp shot of nitours to for drag days..which is the best setup of pistos??
Old Sep 18, 2009 | 11:37 AM
Sylvan Lake V35's Avatar
Sylvan Lake V35
I hate be the search...guy but really.... I bet even google has a ton of info on high vs low compression as well as what applications each is suited for and the effects of boost/nitrous on each.
Lower compression engines respond better to boost/nitrous. High compression works typically is best for N/A or low boost small shot applications. If I was doing your build I would go with a 9.0:1 compression ratio.
Old Sep 18, 2009 | 12:34 PM
str8dum1's Avatar
str8dum1
i wouldnt bother building the motor
Old Sep 18, 2009 | 01:13 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Definately a low compression motor.
Old Sep 18, 2009 | 01:23 PM
SmallTuner's Avatar
SmallTuner
a 9.0:1 is what u need for your setup
Old Sep 19, 2009 | 07:20 AM
Floridaboy1605's Avatar
Floridaboy1605
If you plan on staying with the charger u might get away with a 9.5 or even 10:1 Comp Ratio... But if u have the slightest idea of going for more power down the road just get the 9:1 Comp ratio!!!
Old Sep 21, 2009 | 04:44 AM
max-hid's Avatar
max-hid
Thanks...im dont want to make more than 400whp.that is my goal...i need to built the motor??
Old Sep 21, 2009 | 06:47 AM
Cass007's Avatar
Cass007
Originally Posted by max-hid
thanks...im dont want to make more than 400whp.that is my goal...i need to built the motor??
Old Sep 21, 2009 | 08:24 AM
IIQuickSilverII's Avatar
IIQuickSilverII
RA has build cars with 430whp and a built engine
edit.
NO
Old Sep 21, 2009 | 08:33 AM
05Z33's Avatar
05Z33
I would say skip the nitrous and go with a higher compression motor. If you really want to spray then you need to lower that compression for sure. However I see your goal is 400whp, in that case you don't need to build your motor at all.
Old Sep 21, 2009 | 09:10 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
For 400whp, spend your money on engine management and a good tune. If you decide to build, I would keep compression up around 10 rather than 8.5 or 9:1 for your setup on 3.12 pulley.
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
