Electrical issues after TT
Old Oct 1, 2009 | 02:58 PM
tylerxfire's Avatar
tylerxfire
congrats, i knew that was ur problem
Old Oct 19, 2009 | 07:40 AM
MichaelofHearts's Avatar
MichaelofHearts
Happened again, this time bad enough to make me pull over and stall the car. Checked the major grounds, all fine. Had a suggestion that its a loose connector but I already looked everywhere that involved the charging mech...any other ideas?
Old Oct 19, 2009 | 09:20 AM
tylerxfire's Avatar
tylerxfire
have u checked ur alternator? the oi psi was still normal though now right? what is happening again?
Old Oct 19, 2009 | 12:27 PM
MichaelofHearts
Yeah sorry I should have been more clear, the oil psi is fine and dandy, its the electrical issues again. I had the alternator tested and they said it was fine.
Old Oct 19, 2009 | 01:45 PM
MichaelofHearts
Originally Posted by Sylvan Lake V35
I recently had/have the same issue. The battery light and the brake light flickering and the car not starting. I swapped the cluster like red 35 said it didn't help my issue but it seems to come and go so i am going to check my grounds and the alternator connections as well.
If you figure it out, Id be really appreciative if you post your findings. If it is a ground issue, it might not be the same as mine but at least that gives me a place to look. Thanks a lot bud.
Old Oct 19, 2009 | 08:16 PM
MichaelofHearts
Fixed!!! I had a small oil leak a little while back and some oil got on a ground and the ground was covered in dirt so I cleaned it off and I took off my alternator ground and reconnected it after a good cleaning. Green lights.
Thanks for your help guys
Old Oct 19, 2009 | 08:21 PM
JAM3Z's Avatar
JAM3Z
Phenom
Great to hear you got that problem licked! I know how frustrating electrical issues can be, so hopefully this is the last of them for you.
Old Oct 20, 2009 | 04:39 PM
ADMAN's Avatar
ADMAN
Which grounding point???
sherm
Apr 11, 2020 05:21 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
