Best clutch/flywheel setup for f.i. 450 h.p. Range?
Old Oct 1, 2009 | 02:07 PM
  #41
thom000001's Avatar
thom000001
I have stock flywheel and Stage 5 street disc........guess having oh 150ft-lb+ more tq than its rated for finally did it in lol....
Talking with them on a few things though.
tom
Originally Posted by Kal_El
I went with an Exedy chromoly steel flywheel and a southbend stage 5 clutch and love it.
http://www.dxdracingclutches.com/
  #42
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
yeah no spring internall that I know of on the stock throttle body - that's sorta what makes it drive by wire Easy way to check I would guess is at idle (car running), see what TPS is at. Should be a very low % or voltage #, depending on how that ecu displays the data. Next things would be to see what cam timing, injector pulsewidth and ignition timing are doing. Hopefully you can draw some correlations with all that data and figure it out
Old Oct 1, 2009 | 05:25 PM
  #43
frankie945's Avatar
frankie945
Originally Posted by BriGuyMax
Sounds like you had a clutch fluid bleeding issue, that would have nothing to do with the clutch itself.
ALL aftermarket flywheels for the 350Z cause that drivetrain noise. It's a function of them not damping the vibrations from the motor like the stock dual mass unit. It doesn't mean they "suck azz". My Carbonetic setup is even louder than the JWT setup was.
If you like to race from a dig. JWT clutch it self sucks. I had no air or bleeding problems. If you have owned one and draged you would understand. The hotter they get the worse they are. For NA jwt would be the way to go. That is from my experience with the JWT clutch and flywheel.
Old Oct 1, 2009 | 05:35 PM
  #44
djamps's Avatar
djamps
If you push it by hand (with car off) it pops back, so definitely sprung, probably as a fail safe.
Old Oct 1, 2009 | 06:26 PM
  #45
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
The actual clutch itself has NOTHING TO DO with the pedal pressure changing with abuse. That's all about fluid, clutch line and slave cylinder performance.
Read post #6 in this thread. I HAVE owned the JWT setup and drag raced with it EXTENSIVELY.
Old Oct 2, 2009 | 04:35 AM
  #46
QuadCam's Avatar
QuadCam
the act street clutch has performed flawlessly for me for over 3 years of forced induction daily driving. I have been very impressed with this clutch. I am also using it with the ACT Prolite flywheel.
Old Oct 2, 2009 | 06:05 AM
  #47
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
That's good to know. What power level are you at?
Old Oct 2, 2009 | 06:13 AM
  #48
Kal_El's Avatar
Kal_El
tom
wow, lol yeah I guess that would do it. Mine is holding up well with my current power levels. The stage 5 is rated for 690 lbs right? jeesh
Old Oct 2, 2009 | 09:19 AM
  #49
Rafa's Avatar
Rafa
Quote:
Originally Posted by Rafa
I've had my JWT clutch/flywheel combo for two years and i love it, plus it holds 550/lbs of torque just fine..............
Which is is a little over 400 to the rear wheels How much power is your car putting down
around 600whp@14psi
Old Oct 2, 2009 | 10:30 AM
  #50
Nealoc187's Avatar
Nealoc187
JWT, even though I really don't like the company, their clutch is great for that torque level (clutches hold torque not HP, HP doesn't matter in this discussion).
Worked great both in terms of streetability and ability to handle launches on slicks producing 1.6 60' times and 11.5s at the track, over and over and over. Great setup.
Old Oct 2, 2009 | 10:31 AM
  #51
Nealoc187's Avatar
Nealoc187
Now if we only had a few options for clutches and none of them would hold big power, then I'd be the first on the bandwagon to change the setup.
You'd probably be the one guinea pigging it even.
350Z_Al
Oct 29, 2020 07:44 PM
