Just got a Vortech tune ran good for only a few days.
Old Sep 30, 2009 | 03:49 PM
Naminos's Avatar
Naminos
Default Just got a Vortech tune ran good for only a few days.
I just got a tune for my Vortech stock 3.33 pulley, with Utec and 440cc injectors. It ran great for the first 4 days and after that it started to bog like the it was running to rich. My AFR reads about 14.7 to 15.3 at idle and 12.0 at WOT, is what it shoud be I think.
Everytime I drive for abot 15 minutes or about 10 miles my car starts to bog real badly as if it wasn't tuned at all. My SES light comes on flashing, but goes away after the car sits and evaporates all the excess fuel in my cylinders. I checked if I had it on map 0, checked for any vaccuum leaks and cleaned my MAF just in case, but it still does the same thing.
I'm gettin a reschedule for a tune, but I was wondering if anyone had ran into this issue before only a couple days after what seemed to be a good tune. Can tunes really go bad?
Old Sep 30, 2009 | 03:54 PM
350Z400rwhp's Avatar
350Z400rwhp
Sounds like you are on the right track by taking it back to your tuner to start with. wish I had more for ya but I'm stumped. I will say 12.0 @ WOT is way too lean.
Old Sep 30, 2009 | 05:38 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Tune shouldn't change at all. But it's good to take it back. What ems you running? And 12@WOT is kinda lean, but if your tuner felt safe that way...
Old Sep 30, 2009 | 05:45 PM
tylerxfire's Avatar
tylerxfire
i dont know what to tell u really...i guess take it back and run it on the dyno for a while and see what happens...weird u are getting codes and stuff..somethin must be going on...but as far as 12.0 i hope thats not at redline cause thats a little lean..
with my tune i touch 12.0 on the hit and then level into high 11's and around 11.7-11.5 at redline...rich would be in anything lower than 11's really
Old Sep 30, 2009 | 05:46 PM
tylerxfire's Avatar
tylerxfire
chef u sold ur kit? what u doin now..pm me and let me know what ur plan is...
Old Sep 30, 2009 | 06:01 PM
Naminos's Avatar
Naminos
I just took another look at me AFR while WOT it's actually at about 11 to 11.5. But I've been thinking if my one of my injectors are staying open causing fuel to flood the cylinders.
Old Sep 30, 2009 | 09:52 PM
boostedmaxima's Avatar
boostedmaxima
Did you regap the plugs for the added power? You might be having spark blow out, or it maybe be even time to change the plugs.
Old Sep 30, 2009 | 11:36 PM
Naminos's Avatar
Naminos
Regap? I got pre-gapped iridium spark plugs, and just put them right in. Should I regap them a differenntly?
Old Oct 1, 2009 | 04:29 AM
05Z33's Avatar
05Z33
No need to regap iridium plugs. What are you using for a fuel pump, Walbro intank or Vortech FMU? You might have a bad pump. Check your A/F when the car bogs down. You might be leaning out, and you ecu is going into safe mode.
Old Oct 1, 2009 | 04:59 AM
Naminos's Avatar
Naminos
I have an intank walbro with a fuel pressure gauge and it's getting around 53 psi so ithink that's ok. My car bogs for awhile before the SES light turns on so my ecu probably isn't in safe mode. I think I might try first the regap to see if that may help.
Old Oct 1, 2009 | 05:49 AM
djamps's Avatar
djamps
Flashing SES light usually means bad misfiring. Since your AFR isn't too far off I think your injectors are OK. I would look into making sure your plugs are OK and you've got spark. Perhaps one of the coils or plugs is going bad, or maybe spark blowout as other suggests. Whether fuel actually combusts or not doesn't effect the AFR by much.
Either way, stop driving it or you could wash your cylinders walls and have a much bigger issue on your hands.
Old Oct 1, 2009 | 06:02 AM
GreenGoblin's Avatar
GreenGoblin
A coil pack might be on the way out causing the speratic bogging.
Old Oct 1, 2009 | 06:38 AM
str8dum1's Avatar
str8dum1
also 12.0 AFR is not lean or dangerous. All depends on the timing used. 12-15* is just fine. My car is set at around 12 AFR for WOT no problem.
Old Oct 1, 2009 | 11:47 PM
Naminos's Avatar
Naminos
Well I just regapped my spark plugs and won't get a chance to drive it a few miles until tomorrow, but I did start the ignition and already seemed car sounded better
thanks for the input guys.
Old Oct 2, 2009 | 02:35 PM
Naminos's Avatar
Naminos
Alright, regapped the plugs and dyam my cars back to normal. thanks alot for all the input
Old Oct 2, 2009 | 03:25 PM
binder's Avatar
binder
what were they at? it doesn't sound like a gap problem.
It sounds like a coil problem and maybe by taking them out and putting them back in when taking the plugs out you got a better connection.
Old Oct 2, 2009 | 07:44 PM
Naminos's Avatar
Naminos
It was at stock at 44 and I brought it down to 35 and it hasn't bogged down all day. The coils were plgged down when I took them out, seemed right on to me, but hey I can't argue I'm just just glad to be driving around and happy at WOT again
Old Oct 2, 2009 | 08:22 PM
tylerxfire's Avatar
tylerxfire
id keep an eye on the cats also if u have cats or high flow cats, i went thru 2 sets of metallic high flow cats and that will make the car bog but should be an all the time thing
Old Oct 3, 2009 | 04:02 AM
binder's Avatar
binder
hmmm, i just don't see a 44 plug gap not affecting the car through the tuning process then a couple days later causing a problem. I would keep an eye on the coils. I had the SES light come on and problems like that and it was a bad connection at coil #2.
It would work fine, then sometimes it wouldn't. I would assume it wiggled around and made contact sometimes then not other times. I found the wire that wasn't making good contact and everything has been fine for over 6 months now.
Old Oct 3, 2009 | 08:53 AM
Naminos's Avatar
Naminos
So far mines been good for about a day. But getting ready to garage it for winter hopefully it stays good when I start it up in spring.
nanotech
Oct 2, 2015 05:02 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
