Critique my build...
Old Oct 4, 2009 | 02:56 PM
str8dum1's Avatar
str8dum1
remember JoeK blew his HR head gasket at ~670 hp. not worth the risk for a big HP build
Old Oct 4, 2009 | 03:15 PM
IslandZavage's Avatar
IslandZavage
i was searching for that but couldn't remember the name
Old Oct 4, 2009 | 03:23 PM
ttg35fort's Avatar
ttg35fort
Professional
I totally appriciate what you are saying, but he also had the HR head bolts.
Before his issue, I was considering both the HR head bolts and the HR head gaskets. After his problem, I have eliminated the HR head bolts from my potential buld list. Just because the HR head bolts failed does not mean the HR head gaskets are bad. Nonetheless, it certainly does raise suspission!!!!! I am aware of the failure, and I am proceeding cautiously.
As I previously mentioned, if the HKS had the same cooling modification, it would be a no-brainer. But, the HKS does not have that modification, so the HR head gasket presents a seductive option... It may be good, it may be bad, I don't know. So, I will continue to monitor the situation until it is time to make a choice.
Old Oct 4, 2009 | 03:26 PM
str8dum1's Avatar
str8dum1
are sure it wasnt ARP, i'm almost positive he had ARP from a previous build. gotta try to look over his thread
and i thought your motor was shipping 2 weeks ago?
edit- my bad he only had ARP mains
https://my350z.com/forum/forced-indu...-build-10.html
carry on
Old Oct 4, 2009 | 03:33 PM
ttg35fort's Avatar
ttg35fort
Professional
So did I.
Old Oct 4, 2009 | 04:41 PM
Cass007's Avatar
Cass007
carry on
No, it was the stock TTY studs, not the L19s, He stated that the bolts were the issue and he reccommended swapping them out if you were going over ~15-17psi.
Old Oct 4, 2009 | 07:26 PM
abui01's Avatar
abui01
bout time you're throwing a turbo in there
Old Oct 5, 2009 | 05:42 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Why not go through one of your local shops?
Two local shops in the area I would recommend, much easier to let them do it all start to finish.
Old Oct 5, 2009 | 05:47 AM
XKR's Avatar
XKR
His name on here is "Mad Scientist".
Old Oct 5, 2009 | 02:12 PM
IslandZavage
aside from the HR gasket having the cooling channel do they look any similar to the HKS? What about the HR head studs to ARP studs? (im speaking in terms of material/quality/strength if known). What doesnt help me going this route is that Nissan didnt intend for the HR to be under boost so im sure when they made the studs/gasket FI wasnt on their mind.
But it is good to see people having success with them at a fraction of the cost of the alternate options.
BTW- Just picked up my Full Long Block today @ Japtrix a few hours ago . Big shout out to you guys giving some great info and suggestions.
Old Oct 5, 2009 | 03:09 PM
str8dum1's Avatar
str8dum1
definitively no on the HR head studs if you are shooting for 600+. Thats what let loose on Joe's car.
Old Oct 16, 2009 | 05:20 AM
bb1314's Avatar
bb1314
da Terminator!
Hey where did you go Ian?
Old Oct 16, 2009 | 05:57 AM
djamps's Avatar
djamps
I wouldn't get larger injectors than you actually need, as the larger the injector the more issues you will have with idle and part throttle (cruising).
tripmachine
Southern California
17
Jul 17, 2006 11:21 PM
tree-fity-zee
Northern California
Nov 21, 2003 02:44 PM
raymanZ
Jul 10, 2002 02:42 PM
