Why does my turbo car sound like a diesel?
Old Oct 5, 2009 | 04:31 AM
mx594's Avatar
mx594
Default Why does my turbo car sound like a diesel?
I just recently finished my custom turbo install on my G35. It is based off of an HKS GTRS twin turbo "setup kit", with JWT intercoolers and some custom charge/intake piping. I have a Greddy EVO2 exhaust and Berk test pipes. I also have a CJM stage 0 return and DW 600cc injectors. Before the turbo install I had stock cats and the car sounded pretty normal, except for the rattle from the ACT flywheel.
Well now that the car is turbo, the exhaust is actually a little quieter at idle even with the test pipes. Except now it sorta sounds like a diesel at idle. There is this "clicking" or "ticking" sound at idle that’s actually pretty loud in the cabin, accompanied by a rough sssshhh sound that almost makes me think I can hear the return fuel going back to the tank. I am thinking that the clicking sound might be the fuel injectors firing? Are the DW's noticeably louder than the stock injectors? Could the ssshhh sound be from the return fuel regulator being mounted to the firewall? I have heard exhuast leaks that sound similar, but I checked for leaks and I can't find any.
Old Oct 5, 2009 | 04:36 AM
350z 6spd's Avatar
350z 6spd
The DW 600's are definitely louder than stock and make a noticeable ticking noise.
Old Oct 5, 2009 | 05:02 AM
XKR's Avatar
XKR
Welcome to the world of FI sounds....
Old Oct 5, 2009 | 05:04 AM
04fairlazdyz's Avatar
04fairlazdyz
LOW N SLO
just be happy your f/i and car runs good. i only have 1 of the 2 and its not the better one. lol
Old Oct 5, 2009 | 06:27 AM
BoostedProbe's Avatar
BoostedProbe
Yup, after I installed my injectors I heard the ticking. Thought I screwed something up, or worse, valve ticking (although there was no reasong for it).
So I got the stethoscope out ans started poking around while the engine was running. All was nice and quiet untill I hit the fuel rails. Those things tick like crazy, at least it's nothing to worry about.
Old Oct 5, 2009 | 06:50 AM
350Z400rwhp's Avatar
350Z400rwhp
Yup mine tick loud too especially when in a high gear and part to full throttle, kind of sounds like a header gasket leak.
Old Oct 5, 2009 | 07:03 AM
mx594's Avatar
mx594
Well at least it's normal. I also feared that it might be valve ticking…thoughts rushed through my head that I may have forgotten to put oil in, but then I quickly remembered that I did! I'm surprised how noisy they are - it's strange how they seem louder in the car than they do when you are looking under the hood. My 550cc RC injectors in my Miata do not seem this loud, but then again the exhaust is considerably louder. I guess I just need a louder exhaust!
What about the other noise? Has anyone expirienced a "running water" sort of noise when mounting the FPR to the firewall?
Old Oct 5, 2009 | 07:21 AM
BrianLG35C's Avatar
BrianLG35C
Who did the install/tune, you or a shop?
Old Oct 5, 2009 | 07:57 AM
mx594's Avatar
mx594
I did the installtion/fabrication work myself. I am also doing the tuning myself. Which reminds me - if anyone has good experience with a UTEC and 600cc injectors, please check out my other thread in the tuning section.
Old Oct 5, 2009 | 08:21 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
If it's a stock engine, you are probably just hearing various sounds related to your lightened clutch and flywheel.
Old Oct 5, 2009 | 09:15 AM
mx594's Avatar
mx594
Yes, that stupid flywheel makes its own plethora of sounds. I installed the clutch and fly months before the turbo, so I am already familiar with these sounds. The ticking is a new sound, and I am now 90% certain it is the injectors.
Old Oct 5, 2009 | 10:00 AM
BoostedProbe
Just get one of these, put it on the fuel rails and you will see:
http://toolmonger.com/wp-content/upl...oscope-450.jpg
Old Oct 5, 2009 | 10:11 AM
djamps's Avatar
djamps
I have the same noise with DW 440's. I narrowed it down to coming from the Aeromotive regulator mounted on the firewall. It's transmitting the fuel injector noise into the cabin. Not incredibly loud but definitely noticeable and 'diesel sounding'.
My FRS eliminated the factory fuel dampener which may also be part of the reason it's louder.
Old Oct 5, 2009 | 10:15 AM
Cass007's Avatar
Cass007
Just get some 3" true duals and test pipes and I gaurantee all the pesky injector noises will go away
Old Oct 5, 2009 | 06:46 PM
Sharif@Forged
Forged Performance
LOL...you beat me to it.
Old Oct 5, 2009 | 07:29 PM
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
my DW 600 dont click... weird
Old Oct 6, 2009 | 06:08 AM
tiguy99's Avatar
tiguy99
Do other brand injectors make the same sounds the O.P's complaining about?
Old Oct 6, 2009 | 06:13 AM
djamps's Avatar
djamps
Where is your regulator mounted and did you retain the factory fuel dampener?
My buddy had 600's but still had the fuel dampener I think that's the main diff.
Old Oct 6, 2009 | 06:19 AM
Vas@Extended
I dont have a FRS... and yes I still have the factory fuel dampener . No click clicks here though. WOT or not. Now the walbro in other hand.. definitely louder than stock.
Old Oct 6, 2009 | 06:25 AM
djamps's Avatar
djamps
Stock fuel system - that's why u don't hear the injectors.
From my investigation the noise is transmitted from the fuel rails to the regulator. If the regulator is mounted on the firewall, it transmits the noise into the cabin and it sounds like *** .
