Which guages are essential?
Old Oct 7, 2009 | 07:38 AM
Jes-Z's Avatar
Jes-Z
Default Which guages are essential?
Hey fellas,
I'm slowly doing the interior to my car and I'm planning of going with the Powerlab setup after that. I'm going to use the cubby where the nav is supposed to be to setup a few guages and a boost controler. Is there anything in particular that is required for a Boost setup? I know that the Oil Pressure and the Vacuum guages are a must, but is anything else necessary. Also I'm going to be running Utec so I wanted to custom make the switch into the Nav Cubby with an aircraft type switch instead of the push button with numbers that comes with the switch. Anyone do anything like that?
So, what guages would you put to make a great setup? I'm also open to doing the pods on the drivers side as well in conjuction with the Nav Cubby.
Thanks guys.
Old Oct 7, 2009 | 08:02 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I would do boost/oil pressure minimum.
If you add a 3rd, I would add water temp.
I run the above, and oil temp, fuel pressure and a wideband as well.
Old Oct 7, 2009 | 08:06 AM
JAM3Z's Avatar
JAM3Z
Phenom
Definitely agree on the water temp.
Old Oct 7, 2009 | 08:24 AM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Boost, AFR, Fuel Pressure, Danger2manifold, and Water temp are the main things I'd like to be able to view at a glance. If you are doing a lot of road racing/endurance type stuff, oil temp would be nice too.
Old Oct 7, 2009 | 08:38 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Boost, AF, and Coolant temp would be my top three choices.
Old Oct 7, 2009 | 08:40 AM
XKR's Avatar
XKR
Camp2, Camp2 and Camp2
Old Oct 7, 2009 | 08:56 AM
Alberto's Avatar
Alberto
Cranky FI Owner
If you like to have your a$$hole stretched and your red sock pulled out sure...
Old Oct 7, 2009 | 09:04 AM
XKR's Avatar
XKR
So is that a thumbs up................
Old Oct 7, 2009 | 10:13 AM
djamps's Avatar
djamps
CAMP2 is a waste without an Fcon attached to it (no A/F and other stuff).
Old Oct 7, 2009 | 10:23 AM
fabcas311's Avatar
fabcas311
LOL
Old Oct 7, 2009 | 10:26 AM
Crom's Avatar
Crom
A/F is the only thing - other than that the FCON has no impact on the CAMP. - no map changing or anything. - might as well get a greddy info meter.
Old Oct 7, 2009 | 11:15 AM
- bigc -'s Avatar
- bigc -
www.plxdevices.com
Old Oct 7, 2009 | 11:59 AM
psychoballistic's Avatar
psychoballistic
Wideband, Oil temp, and Boost here. I'm adding a water temp this winter also, definately all important.
Old Oct 7, 2009 | 12:32 PM
XKR's Avatar
XKR
I was about to say that
Old Oct 7, 2009 | 12:37 PM
Crom's Avatar
Crom
The weird thiing is that it supposed to be fully functional w/ the IS version - but who runs that jalop.
Old Oct 8, 2009 | 04:49 AM
Jes-Z's Avatar
Jes-Z
Ok guys. I guess I'm going to do the A/F and Boost Gauges on the pillars to the left. I'm going to do 3 small guages in the cubby and switch. Oil Temp, Water Temp, and Fuel Pressure.
Now, Which gauges best match the Z interior. I've seen the Defi BF Linkmeter but I've only seen the Amber on the site and it looks red. Any other Brands that are a perfect match to the interior?
Old Oct 8, 2009 | 05:13 AM
XKR's Avatar
XKR
very true...you would think they would setup their flagship system that way.
Old Feb 12, 2010 | 10:24 PM
xzotklr's Avatar
xzotklr
I would suggest you replace the water temp with an oil pressure gauge. Reason being the primary function of these gauges is to provide info that we can instantly use to determine if there is a problem.
A change in oil pressure will tell you right away if there is a major problem that will cause catastrophic failure. Meanwhile water temp gauge would normally indicate overheating which while important does not cause major damage as quickly as problems with oil....Just my 2c
Old Feb 13, 2010 | 12:49 AM
phunk's Avatar
phunk
CJ Motorsports
the 350z already has an oil pressure gauge from the factory. it also already has a water temp gauge. both have always done me justice. i know the water temp doesnt give you exact degrees... but your water is typically always the same, and if it starts to climb then you know its going to keep climbing if you dont stop whatever youre doing to overload the cooling system. if youre not road racing, you dont need to add a water temp gauge.
boost, a/f, oil temp.
the only gauges i ever look at are oil pressure and a/f.... i only check oil temp if holding high speed on the tollway for long duration. i dont ever look at the boost gauge, because i dont particularly care what my boost is if my A/F is correct and i know i have a boost fuel cut set if something causes it to go higher then i would want. ill sometimes glance at the boost peak-hold on my boost controller after letting off full throttle just to make sure its still hitting where i have it set... i wouldnt notice if the boost gauge in my pillar stopped working cause i dont ever look at it unless checking engine vacuum.
nanotech
Oct 2, 2015 05:02 AM
mucky
Apr 12, 2003 09:35 PM
Raptor303
Feb 3, 2003 10:09 PM
onecoolee
Jan 11, 2003 04:29 AM
JDZ
Sep 15, 2002 04:20 PM
