So....how wants to make some serious single turbo power
Old Oct 8, 2009 | 08:46 PM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by deeznutts23
^LOL. I live in Louisiana and they haven't heard of emissions over here. I'm gonna PM you, I have a few questions.
Damn I only wish we could have that kind of lax attitude here...
Old Oct 8, 2009 | 08:47 PM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by Zippy_z
i definitely didnt mean what i said to bad mouth the kit. I know tons of dudes running this kit with no problems and loving it. The problems were definitely a case to case basis
NO worries man... every kit has its pros and cons...
Old Oct 9, 2009 | 06:36 AM
str8dum1's Avatar
str8dum1
ya, the turbonetics piping was maxxed at under 500 hp. No way you could put 6-700 hp thru that and make any power.
to make 6-800 hp efficiently, you need a true t4 flange, 3" hot/cold side.
I'd hate to see turbonetics owners buy these big turbos thinking they can just drop them onto their stock piping and intercooler.
Old Oct 9, 2009 | 06:59 AM
BoostedProbe's Avatar
BoostedProbe
Something I noticed in my build too. I originally had a 2" crossover pipe, going from bank one to bank two, which was 2.5". I think all single turbo kits out there have a 2" crossover pipe, and now one manufacturer has an O2 sensor in the 2" crossover pipe. The Power lab ST kit does have an advateage over other kits though, they have the W/G dump comming off of the 2" line (bank one crossover).
Well, I had my O2 sensors in about the same location and distance from the header flange. I noticed that bank one (2" tubing) was running richer than bank one (2.5" tubing). I know my injectors were flow tested and were all within 1% of each other. I have a fuel return system as well, so that was ok too. When I increased the boos from 5.5psi to 7.5psi this bank one richer than bank two amplified a bit.
So, when I did my clutch swap I decided to make both sides 2.5", merging in to a 2.5" feeding the turbo. Again O2 sensors were in the same location but my A/F were now identical. The 2" tubing was a restriction with hp being in the mid 350's. I'd hat to see the difference if I tried to push 500whp.
Old Oct 9, 2009 | 08:14 AM
tig488's Avatar
tig488
where did craig and his Z go?
Old Oct 9, 2009 | 09:17 AM
MIAPLAYA's Avatar
MIAPLAYA
I'd have to disagree with you...
https://my350z.com/forum/shop-builds...o-problem.html
Old Oct 9, 2009 | 09:30 AM
doug's Avatar
doug
I had to do a double take on the date of the first post of this thread
Old Oct 9, 2009 | 09:33 AM
doug's Avatar
doug
i'm going to reserve comments on this whole thread until some solid results are posted.. no sense in beating them down if they feel they can make another run at it..
Old Oct 9, 2009 | 10:40 AM
str8dum1's Avatar
str8dum1
Just because he strung out that turbo, does not mean that the piping etc will support more HP. Doesnt the tnetics kit has a giant 2.5" downpipe. 2" crossover pipe? Thats definitely the right size for big power
BUT, its great news for all those built block turbonetics guys. I'm sure thats a huge market.
Originally Posted by MIAPLAYA
Old Oct 9, 2009 | 11:16 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
I agree with Doug, I had to look at the date to make sure this wasn't old. I would love to be proved wrong, but having done a little work with Turbonetics setups I found there is much more required for "serious power" than just a turbo upgrade. Turbo, feed pipes, down pipe, intercooler etc.... basically a whole new kit.
Old Oct 9, 2009 | 11:30 AM
MIAPLAYA's Avatar
MIAPLAYA
I'm obviously a single turbo guy so that's where my head went but any twin kit using a T3 turbine would benefit from these as well. Speed Force Racing comes to mind...
Old Oct 9, 2009 | 11:48 AM
escobar929's Avatar
escobar929
lol, i had to look at it three time, i thought my eyes were playing a joke on me
Old Oct 9, 2009 | 12:10 PM
str8dum1's Avatar
str8dum1
there would be absolutely no reason to use an inferior Turbonetics turbo over the billet PTE's that SFR uses.
Well i guess if you wanted less HP and more heat.
Also shoving big turbines in little housings has been the core issue with the GTM type kits and producing big power. Its not as simple as just putting in bigger wheels as the turbonetics ads make it appear.
Old Oct 9, 2009 | 12:17 PM
MIAPLAYA's Avatar
MIAPLAYA
Actually SFR uses both. I know Tim pretty well and have been to his shop quite a few times. Clearly you have a problem with Turbonetics units. Sad to hear but whatever floats your boat. I don't think anyone said its as easy as shoving a larger wheel into a smaller housing but if that's what you got out of it I'm sorry to hear that too. These units weren't the result of trying to stuff a wheel into a random housing. There's actually quite a few of these running on test cars.
Old Oct 9, 2009 | 12:18 PM
Dynosty's Avatar
Dynosty
+1000000
Huge wheels in small housings, while trendy, = fail
Old Oct 9, 2009 | 12:33 PM
Motormouth's Avatar
Motormouth
does anyone sell turbonetics anymore, or is this an ad?
Old Oct 9, 2009 | 12:45 PM
Cass007's Avatar
Cass007
Turbo Tim just threw up in his mouth a little bit
I am officially a trendy failure
Old Oct 9, 2009 | 01:46 PM
  #38
MIAPLAYA's Avatar
MIAPLAYA
Actually yes Treadstone bought a bunch of 350Z turbo kits as a last buy from Turbonetics. I think they still have some...
Old Oct 9, 2009 | 02:57 PM
  #39
superchargedg's Avatar
superchargedg
Damn Noobs
Still eating those quarter pounders?Long time no hear from.
Old Oct 9, 2009 | 03:39 PM
  #40
doug's Avatar
doug
Treadstone? isn't Jason Bourne looking for them?
