Confusion regarding T25, T3 and T4 turbine flanges
Old Oct 12, 2009 | 07:13 AM
GT-ER's Avatar
GT-ER
Originally Posted by ttg35fort
No, those are T25 flanges. GTM uses the same manifold set for all of it's turbo kits.
Yeah I just double checked and you are right...I didn't even see a GT35R kit...lol ( what was I thinking about? ).
Old Oct 12, 2009 | 07:23 AM
ttg35fort's Avatar
ttg35fort
Professional
That might be their stage 6 kit.
Old Oct 12, 2009 | 07:32 AM
ttg35fort's Avatar
ttg35fort
Professional
Originally Posted by thawk408
Then entire thread is fail. Ill edit my post
You will NOT FIND anyone that recommends t25 for big power.
Incorrect. Sam at GTM recommends his turbo kits for big power, and they only come with T25 flanges. There are two builds underway right now using the GTM turbo kits, and both are shooting for over 1000 whp.
Based on its design, a log style manifold is going to be restrictive. Merely changing out the flange to a T3 flange is not going to miraculously change the log manifold itself. imo, with a log style manifold, there won't be any significant difference at all between the T25 and T3 flange.
On a header style manifold, OK, then the T3 flange makes sense.
Also, show me a VQ35 log style manifold that is made with a T3 flange. One may exist, but I have never seen one. If one does exist, it would be interesting to see how well it fits, as well as compare its performance to the GTM exhaust manifold.
Old Oct 12, 2009 | 10:00 AM
XKR's Avatar
XKR
Thats correct...thats their stage 6 kit
Old Oct 12, 2009 | 04:36 PM
str8dum1's Avatar
str8dum1
With THOSE exhaust manifolds, then the T3/T4 flanges make sense.
Hey Thom, is there a way you could post a pic of looking under your car from the front bumper. Kinda to showcase how the oil sump pump sits.
How much drop do you think you can have without fear of tearing it or the hoses off?
Old Oct 12, 2009 | 05:43 PM
thawk408's Avatar
thawk408
Of course he's going to back his own kit. Do what you want, dont matter to me.
Old Oct 12, 2009 | 05:44 PM
thawk408's Avatar
thawk408
FAIL.
Old Oct 12, 2009 | 06:02 PM
ttg35fort's Avatar
ttg35fort
Professional
Does anyone know of a log style manifold for the VQ35 motor that is available with a T3 or a T4 flange. I don't know of any. If there is somebody who makes them, it would be interesting to compare their respective back pressures and/or performance on similar builds, as well as see how well they fit.
Old Oct 12, 2009 | 06:10 PM
ttg35fort's Avatar
ttg35fort
Professional
FAIL.
Got me. I said "imo".
Old Oct 12, 2009 | 06:37 PM
GT-ER's Avatar
GT-ER
imo the problem isn't the flange it's self but rather the housing options available. T25 is more than enough for just about everyone but there are 10 different styles of T3 housings for every T25 housing so it just let's you be more creative. Plus, I really wouldn't rock a 1000+whp kit on T25 housings. It's possible, just not the best setup.
Old Oct 13, 2009 | 03:14 AM
ttg35fort's Avatar
ttg35fort
Professional
If you are using a log style manifold, I don't know of any other choices for Garrett turbos other than a T25 flange. If someone makes a log style manifold for the VQ35 with a T3 flange, I have not seen it.
Anyway, if you want to get up much past 1000 whp, perhaps stainless steel header style manifolds are the way to go. Again, with those manifolds a T3 or T4 flange makes more sense.
Old Oct 13, 2009 | 06:08 AM
SmallTuner's Avatar
SmallTuner
the old ultimate racing tiwnturbo kit comes with a T3 flang.
i have the kit i can take some pics of the manifolds.
Old Oct 13, 2009 | 07:00 AM
ttg35fort's Avatar
ttg35fort
Professional
Cool.
EDIT: I just checked their website and could not find the log style manifolds for the VQ35 motor. Is it a new product?
Old Oct 13, 2009 | 10:35 AM
GT-ER's Avatar
GT-ER
Cool.
I think that'll answer your question..lol.
Old Oct 13, 2009 | 10:44 AM
str8dum1's Avatar
str8dum1
ya all the current stuff is APS or APS knockoff manifold. all T25 or that weird 3 bolt Mitsu/Greddy stuff.
The catch 20 is that to go with a bigger housing, you have to go with low hanging turbos, which means oil sump pump, which is no good for non-stock height cars.
Thats why the single turbo market should be much bigger. Ya there's alot of distance between the exhaust manifold and the turbo, but for a big power hwy car, thats the way to roll. No one wants to make a kit though with a big 70+mm turbo though. Thats a smallish standard size single on a supra, yet we are using the same sized single as 2L Subys
Old Oct 13, 2009 | 01:12 PM
thawk408's Avatar
thawk408
Why do you think a scavenge pump would not let you lower the car? You can route it just find and not be in danger of hitting it.
The reason the single market on the Z is not real strong is because ITS A V MOTOR. Its easier to do twins to obtain higher horspower. There isnt a lot of engine bay room and the pipe routing can get to be a PITA.
Old Oct 13, 2009 | 01:46 PM
ttg35fort's Avatar
ttg35fort
Professional
Yes, I should have read closer. Thanks for the heads up.
Did they stop making it because of fitment issues?
If they changed to a T25 flange from a T3 flange, I would hope they did some testing first. I wonder if they have data comparing the two?
Old Oct 13, 2009 | 01:55 PM
  #38
ttg35fort's Avatar
ttg35fort
Professional
Based on what others have said, a twin-turbo setup will give faster spoolup, i.e., less turbo lag, while a single large turbo will give more top end power. Quad turbos is supposed to be even less laggy than twin turbos, which is why you are starting to see them on high end production cars which are not shooting for the moon with hp, e.g., the new BMW V-8s under development (maybe their out by now, I don't know).
Old Oct 13, 2009 | 02:08 PM
  #39
copec's Avatar
copec
Twin turbos with six cylinders also has a similar effect as twin-scroll single turbos, although combined smaller turbos are not usually as efficient with big pressure ratios as a single turbo.
Old Oct 13, 2009 | 02:12 PM
  #40
binder's Avatar
binder
ok, since this is about flanges. can you explain with pictures of the differences in the flanges?
i'm turbo dumb so i'm trying to figure this all out.
