Confusion regarding T25, T3 and T4 turbine flanges
thats why its so hard to compare kits. YOu say you had alot of headroom on your 18g's, yet there was just a 18g @18psi on C16 dyno posted, it only made 536 hp with the exact parts that I have (c2 cams, cosworth, big fuel....)
Unless the tuner left a 100 horses or so on the table, the parts are much greater than the whole.
With the Greddy TD05-18G's, I reached 609 whp on 93 octane at 17.5 psi on Japtrix's Mustang dyno. Roger at Japtrix told me that that particular dyno reads about 10% lower than a DJ. Moreover, I think Alberto reached 665 whp with his TD05-18G's using pump gas on a DJ.
There is a first time for everything. I don't remember anyone trying to make over 1,000 whp with a GTM kit up until very recently, and those builds are still in progrress.
What is your opinion on Mike's build. GTM TT kit, JWT cams, do you think he will make his stated goal?
Do you think GTM's AutoBahn build will make 1000 whp?
How much power are you laying down?
As for Mike's build... It's not the way I would have chosen to achieve 1000+whp, but I respect and support Mike as a friend and therefore hope for the best for his project. He has chosen to go with unproven components that thus far have not been used for a 1000whp VQ build; particularly a 4.0L non-sleeved block and cast log style exhaust manifolds. I have concerns about the longevity of the thinner than stock sleeves (due to 97mm bore) of the 4.0L non-sleeved block and it's ability to sustain over 800whp under load. I have posted my concerns publicly and have discussed it with Mike privately. I also wonder whether the log style manifolds will flow well enough for 1000whp. I anxiously await the results of Mike's build, since he is going into uncharted territories with those components.
I respect Mike for pushing the envelope into uncharted territories, since I am also going into uncharted territories with my build by attempting to push the 5AT trans farther than anyone elso has pushed it before. I therefore appreciate the risk Mike is taking for the sake of the community and its knowledge base.
This is another very valid concern.
https://my350z.com/forum/shop-builds...o-rebuild.html
nope, its a full on solid build done at forged. 3" downpipes, cosworth manifold, jwt c2 cams, 1000cc plus dual pump.
guy lives in TX, so not at altititude. Its still makes alot of useable power, just there was a huge amount of money spent overbuilding that car for the dyno it made. Prolly could saved close to 2 grand and shoulda been able to run the same power.
Now I am really wondering about this build. I did a quick search through the recent threads and didn't see it. Do you have a link? Who did his build/tune? Something definitely is not right with that build... I can see high altitude holding back the hp if he is in the mountains somewhere, but why would he be using C16 to get to 536 hp? High compression? If so, makes me wonder how that brilliant decision was made...
On my build, Roger at Japtrix commented on how easy the power came on. He only stopped at 600 whp because that is the target I set. He felt that if he pushed it to the limit, there was another 30 hp left on 93 octane, but I did not want to be right at the edge.
Before I over-reved my motor, it was laying down a lot of power. My Toyo R888 305/19/30 tires were spinning when the turbos spooled up in 3rd gear. Imagine starting at 2k rpm in third 3rd, and then once you get to about 4000 rpm (around 50 mph), the rear tires break loose. It was crazy power.
That is why I am going with a longer duration cam on the new build. A little less torque at 4000 rpm, but more top end power.
Feel free to call Roger at Japtrix and ask him about my build. He will tell you, and this guy has built/tuned alot of VQ motors.
just came back today
