Inputs on Crankcase Ventilation System (Greddy TT)
Old Oct 14, 2009 | 12:17 PM
04G35tt's Avatar
04G35tt
Default Inputs on Crankcase Ventilation System (Greddy TT)
Just wanted to get some opinions on my Crankcase ventilation system. Is it overkill? I have seen a couple of diagrams using the Drivers side turbo intake only and using the crossover tube between the valve covers, but I think a dedicated system for each bank should suffice. The check valves are using viton valve and the stock ones will be drilled out. Using -6 AN SS hose line for the bling bling factor. Anybody try this setup yet? the only change I would make, is on the second picture and that is to drill and tap a new hole for the breather filter so that the vacuum is across the entire passenger side valve cover, capping the stock hole of course.
Attached Thumbnails Inputs on Crankcase Ventilation System (Greddy TT)-pvc.jpg   Inputs on Crankcase Ventilation System (Greddy TT)-pvc2.jpg
sales@czp
Sep 23, 2019 03:30 PM
nanotech
Oct 2, 2015 05:02 AM
