cometic headgasket or HR headgasket
Old Jun 30, 2011 | 12:04 AM
  #41
Sylvan Lake V35's Avatar
Sylvan Lake V35
Your link isnt working but I think i know what youre talking about. A member on here did the HR coolant piping mod on a DE...KelEL...theshaddix...I cant recall who
Old Jul 1, 2011 | 06:52 PM
  #42
Resmarted's Avatar
Resmarted
Originally Posted by Alberto
AFAIk Joe is the only "proven" case for HR HG's. He had headlift issues and that was that but I wouldnt go around saying an HR gasket would perform as well or stand up better than even a Cometic HG. Perhaps in regards to cooling but its too soon to say IMO, more people need to prove these things.
For something as crucial as a HG, $300 is nothing to worry about (especially considering your SN LOL), if it is, you shouldnt be building IMO.
Not quite.
Cometic doesn't make any head gaskets with the stopper built in. The HR is a multi layer metal headgasket with stoppers. That's actually a superior design.
I've spoken to a few engine builders (that specialize in jaguar, vw and american engines) and they agree that the stopper is superior. Why doesn't cometic switch if it's so much better? Well the manufacturing cost is much higher to add the stopper. That same engine builder is a vendor for cometic.
That's the same reason why HKS gaskets are so highly recommended for our high hp builds...
Last edited by Resmarted; Jul 1, 2011 at 06:53 PM. Reason: added italicised word for clarification.
Old Jul 2, 2011 | 09:35 AM
  #43
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Originally Posted by Resmarted
Not quite.
For whatever reasons, the cometic gaskets have had a high failure rate across many different V6 nissan engine types. I only use them if absolutely necessary such as a custom bore size. We stick to stock or OEM.
Old Aug 27, 2011 | 05:19 PM
  #44
specialist's Avatar
specialist
Do they make hks hr head gaskets? I am sorry if that is a noob question.
I have lifted my head 3 times and used cometic. I am using hks and darton sleeves and pathfinder mod with l19. Vq35de block. Twin turbo. Some times my coolant temps go passed half sitting in traffic. Should I get the block modfied for hr coolant mod? Or maybe start over with no sleeves
Old Aug 28, 2011 | 08:03 AM
  #45
Cass007's Avatar
Cass007
Are you sure you haven't dropped a sleeve? The sleeves have a somewhat negative reputation for causing heating issues and lifting heads.
Some have had success, but many others have not.
Old Aug 28, 2011 | 08:22 AM
  #46
e30cabrio's Avatar
e30cabrio
Should I be concerned with the ones I got through you guys in February for my NA 88mm stroker 96.5mm build? It's still not assembled.
Old Aug 28, 2011 | 07:16 PM
  #47
binder's Avatar
binder
Not quite.
Cometic doesn't make any head gaskets with the stopper built in..
false
i'll take pics to prove it. Every cometic gasket i've purchased has a stopper ring in it. Not sure what cometics you have but in the last 2 years the ones ive purchased have them.
If cometics sucked then people that have 100mm bore wouldn't use them for their 1000hp builds.
Old Aug 28, 2011 | 09:12 PM
  #48
specialist's Avatar
specialist
I will see if my sleeve dropped i am ripping it apart to take a look at it to make sure.
Can you tell by looking the seleeve if it dropped
If i decide to keep sleeves and do the hr mod do i have to loose the path find mod?? and go back to the stock one?
Old Aug 29, 2011 | 06:37 AM
  #49
str8dum1's Avatar
str8dum1
sucking and being the only part available are 2 different things
but cometic hasnt seemed to have the failures like they did in the early days of the VQ
Originally Posted by binder
false
Old Aug 29, 2011 | 08:19 AM
  #50
binder's Avatar
binder
true, but how many of those big builds do we hear of that have head gasket failures?
If they were that bad the people putting down power would find a company to build them custom head gaskets that are worth it. I think if their 100mm gaskets hold the 800-1000hp then they'll be perfectly ok for my 500-600hp.
Mine held for 3 pulls at 14psi with 28* of timing before it finally went when that idiot at GRD attempted to tune my car. That's a pretty strong head gasket to hold that.
Old Aug 29, 2011 | 10:24 AM
  #51
str8dum1's Avatar
str8dum1
i dont think there has been a non-sleeved/ ARP stud build with HG failure in the past couple years.
Joe was the the last one I can think of that lifted a head and that wasnt on L19s.
I really doubt any HG choice is bad anymore.
Old Aug 29, 2011 | 10:28 AM
  #52
binder's Avatar
binder
ya. I think quality of all the headgaskets is up to par in order to meet the demands of the customers.
I forgot to put in my other post that i agree with your statement about cometic being the only option for the large bore guys. I also think because they are the only ones they stepped up their game in order to keep their big build customers happy.
Old Aug 31, 2011 | 02:31 AM
  #53
Resmarted's Avatar
Resmarted
Well I'm glad that I'm not having that machine shop that told me cometic doesn't have stoppers on them ISN'T doing the machine work! lawl.
They swore none of the cometics had stoppers. Maybe only the vq model has the stoppers?
Either way im going to be running hr gaskets... with the l19 studs and arp mains...
Old Aug 31, 2011 | 11:59 AM
  #54
binder's Avatar
binder
I think the first head gaskets they made for the vq didn't but that was a quite a few years ago. They just need to keep up on their info. Same as cosworth's being the same gasket as cometic. They are different now.
Old Aug 31, 2011 | 07:13 PM
  #55
Resmarted's Avatar
Resmarted
Yeah that would make sense.
For what they wanted to bore/hone my block (3 grand, without a bunch of clearance measuring) I think they better be up to date on what they tell me. over priced turds
Old Sep 1, 2011 | 12:25 PM
  #56
Sharif@Forged
Forged Performance
The Cometic failures I speak of, for what it's worth, occuring in the big overbore engines where Cometic was the only option. 100mm bore sizes mostly. If I must use a cometic gasket due to sizing limitations I will, but if another option exhausts I would take it.
I'd have to do some searching, but can't recall anyone having Cometic gasket issues with stock or close to stock bore sizes and good L19 head studs trqed to 90-95 ft/lbs.
Old Sep 1, 2011 | 01:12 PM
  #57
e30cabrio's Avatar
e30cabrio
Thanks Sharif. I have ARP studs and am only .20 over. I will make sure the machine shop doing the assembly torques the heads properly.
Old Dec 29, 2012 | 06:10 PM
  #58
blAk mAx's Avatar
blAk mAx
are the HR gaskets holding strong? is the block machining a must when using the HR gasket?
Old Dec 30, 2012 | 07:53 AM
  #59
lp_turbo's Avatar
lp_turbo
Since L19 stud is out of stock, ARP standard or HR bolts hold more hp ?
I see HR engine approximately at 520hp @ motor on youtube but it's the same for rev up engine with hr hd gasket & hr bolts?
Old Dec 30, 2012 | 05:47 PM
  #60
Resmarted's Avatar
Resmarted
L19's are the way to go.
If you can't find them locally find a shop to get them for you.
If worse comes to worse I can help you get them for you from ARP directly custom made.
Absolutely do not use anything other than the L19's. They're worth it.
Or pick up some used ones.
Get a Dynosty head gasket. It's almost identical to an HKS gasket (which is basically the best) but it's about $100 cheaper.
