Built Motor + Greddy Twins + Osiris = A good idea?
Old Dec 31, 2009 | 08:58 AM
  #101
Dal35's Avatar
Dal35
Car just did 523WHP 450WTQ at 11.5psi on pump gas and 594WHP 538WTQ at 14psi on race gas for now.
Old Dec 31, 2009 | 11:59 AM
  #102
Iron-Mike's Avatar
Iron-Mike
I'll be running greddy twins on a stock block this year with 8psi springs in my wastegates and a greedy profec B spec II boost controller. Also will be running 50/50 meth mix and Osiris for the tune. Only reason I chose the Osiris for the tune over say a Haltech or Fcon is the fact I have one of the designers of the Osiris software platform a couple states away from me in NJ. We've had extensive talks about what I will and won't need in order to make this work properly so I'm following his advice to the letter
I'll let you guys know how things turn out in the end
but on a side note I will be running the 3" aluminum MAF housing and HPX MAF sensor along with DW600cc injectors and AAM fuel return system with the rails and a walbro fuel pump
anyone want to suggest anything else I should get for this setup?
Old Jan 1, 2010 | 06:48 AM
  #103
Dal35's Avatar
Dal35
here is the first day tune video.
http://www.youtube.com/watch?v=K-HgnBAKQ3g
Old Jan 9, 2010 | 02:17 PM
  #104
eZg's Avatar
eZg
nevermind
Old Jan 10, 2010 | 05:20 PM
  #105
midz350's Avatar
midz350
Originally Posted by PunKidd
We've tuned more than two dozen FI Z cars on the stock computer over that last 4 years (a hell of a lot more than that if you take our pro tuners into account) and we have yet to have one fail from detonation or over-boost. We've seen a couple of other failures like oil starvation and spun bearings, but no pitted/cracked pistons on any or our tunes on the stock ECU.
Jared@UpRev.com
I got one for you. PM me if you want to see the pics
Dymsi
Sep 29, 2015 11:32 AM
35reilly
Sep 28, 2015 07:42 AM
