New winter new turbo build
Old May 20, 2010 | 07:17 PM
  #501
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Originally Posted by str8dum1
why even mess with an expensive quick spool valve though. Just get a divided flange and use that. You'd need 2 wastegates though, so i guess that evens out the price difference...
Were you suggesting having one bank for each side of the turbine?
Old May 20, 2010 | 07:19 PM
  #502
str8dum1's Avatar
str8dum1
ya twin scroll. you already have a crossover so, that just get welded to one side of the divided manifold. And then the other side obviously gets welded to the other side
just seems like it would be easy to do.
Old May 20, 2010 | 07:22 PM
  #503
Boosted Performance
Yeah that would not be possible with this set up. There is room down there, but not THAT much.
Maybe if I was to redo the entire setup with 2" exhaust pipng it may work, but not with the 2.5".
Old May 20, 2010 | 08:29 PM
  #504
binder's Avatar
binder
ah, stupid speed based dynos!
rich, weren't some of the guys talking about twin scrolls not working well for v6's. Someone had a thread about it not long ago.
also, anyone know what the lag on a 6765 would be over a 6262? Thom tried to look up a few dyno's and couldn't find much luck. Basically a 3.0L supra engine would be a pretty close match to see how fast they spool.
Old May 20, 2010 | 09:37 PM
  #505
Vas_Z33's Avatar
Vas_Z33
ugh u guys are just tickling my *****... I just got the kit I dont wanna swich turbos already lol jk
Old May 20, 2010 | 10:40 PM
  #506
Elperuano's Avatar
Elperuano
Old May 21, 2010 | 05:21 AM
  #507
str8dum1's Avatar
str8dum1
there was another dyno with rpms, but i didnt post that one becuase its not relative to our cars. They were spinning the teg to 10,000 rpms. full spool wasnt until like 7500 rpms
On our cars the 6765 would lag pretty good, not a street turbo per say, maybe 800+ rpms later. Searching for T67 dynos would give you more insight. You'd definitely need to build your motor with a 8000+ redline in mind.
but no, twin scroll is a great design for a single. Its just hard to replicate on a V motor. But already using a crossover pipe is almost all the work. Its easy on an inline motor because all the runners are next to each other.
Old May 21, 2010 | 11:36 AM
  #508
binder's Avatar
binder
well, considering my car was still making power up to 8k (unforunately the vortech gave out and fuel also became an issue) i will probably be reving to 8500. The engine has been to 8500 on the street...hal just didn't want to push the vortech anymore on his dyno which is understandable. My redline will be no less than 8k.
Old May 21, 2010 | 11:42 AM
  #509
Boosted Performance
Found a supra with a 6765 .96a/r billet wheel:
Fuel: E85
Max WHP: 801
Torque: 760
Full boost: 4.5k
Link:
http://www.youtube.com/watch?v=pPvGElCX8R0
Old May 21, 2010 | 12:19 PM
  #510
str8dum1's Avatar
str8dum1
Then you need a much bigger turbo. ball bearing 6765 without a doubt
Old May 21, 2010 | 12:32 PM
  #511
binder's Avatar
binder
sob rich, why you throwing out that ball bearing ****!? you think i'm made of money and feel like running coolant lines? well, the money differene isn't bad but i hate the thought of running coolant lines under the car like that.
so 4500 isn't bad, that's well within what i would call "laggy" zone. plans might have just changed.
Old May 21, 2010 | 12:33 PM
  #512
Vas_Z33's Avatar
Vas_Z33
jeff, your motor and a 67 and 8K rpm..... would be insane... I think its time for you to do it already and set some records =)
Old May 21, 2010 | 12:36 PM
  #513
str8dum1's Avatar
str8dum1
no PTE has air cooled ceramic BB's now. Only way to go on a big single
Old May 21, 2010 | 12:43 PM
  #514
binder's Avatar
binder
slingshot, ENgaged.....
time to go stalk sasha some more.
Old Jun 5, 2010 | 11:29 AM
  #515
booger's Avatar
booger
Boosted P. Im sure this has been asked already but with out going thru all the pages of this great build . Have you tried fitting this kit to an early AT5 G35 yet ?
Old Jun 5, 2010 | 12:55 PM
  #516
Boosted Performance
I have not, and can tell you that it will not fit. It fits the G, but not the AT. The large AT oil pan is in the way of the cross over pipe. I use a large (2.5") cross over, so I had to run in right in the middle of the 6 spd gearbox, because this is where it is highest from the ground.
Old Jun 5, 2010 | 01:34 PM
  #517
tiguy99's Avatar
tiguy99
Is there anyway the pipes can be modified to fit the larger AT oil pan?
Old Jun 5, 2010 | 03:39 PM
  #518
Boosted Performance
There is always a way. I just don't have time to look in to it yet. Perhaps this winter.
Old Jun 5, 2010 | 07:38 PM
  #519
tiguy99's Avatar
tiguy99
I have a feeling you're going to get more customers if you come out with the automatic version of your turbo kit! Keep up the great work
Old Jun 12, 2010 | 12:30 PM
  #520
ekelly36's Avatar
ekelly36
Any news for the HR crowd? Im saving right now... im getting close to pulling the trigger and I really like the way your kit is set up....
