New winter new turbo build
Well, winter is here and I am playing around when I have some spare time. This is the latest in my never ending search for the perfect wastegate dump/recirculation plumbing. (I have now found the perfect solution)
I really wanted to have an economical option to give the customer both, an open dump tube and the choice to recirculate wastegate exhaust gases back in to the down pipe.
This is the latest:
This flexible exhaust tubing is made for just that, exhaust systems. It is tough as nails, flexible and can easily be removed.
I will make plugs to go with the kit. The plug will be a 1.5" piece of solid stainless tubing, 1" long with the end welded shut. So if you want to go with an open dump, just slide the flex down towards the down pipe, put the plug in and clamp it down. Very simple. This does not change the kit price, but you have both options available.
This is the latest:
It is rated for exhaust but won't even see much of it, as it will only flow though there once the system is under boost.
EDIT: Juste checked PM's, don't see one from you. Can you plese send it again, maybe I deleted it by accident.
It traps water and grime in the bends of the flex and rusts horribly if its not SS, even the SS wears after awhile and holes start to show through. I have use this stuff on old cars I have worked on. I would never use this in a boosted application, the thin parts of the flexible metal would become brittle over time due to the heat exposure.
You are better off if you want to offer options, is to make two style w/g tubes, and a down-pipe that has a block off plate, and use v/bands...
Slight update/change. The FMIC will be changing, it will now be slightly larger as well. Old core was 25x6x3.5, and the new one is 24x7x3.5. I finally got one in and got a chance to test fit it, the brackets had to be changes slightly (very minor change) and it does fit well. There will be no price change, and now a couple of pics:
Old vs new:
3" inlet and 3" outlet:
Installed:
The entire core is still exposed:
I am also hoping some other parts get here before the holidays so I can get the new TT build going. For now, I have one Garrett GT2860 turbo on the way, and that is all I am missing. The IC piping, flanges, exhaust piping..ect are all here already. Look for a build thread in the near future, as usual tons of pics and details.
Old vs new:
Installed:
what does this new core change?
You made it shorter but wider. I thought the more rows you had the greater the effect on cooling verses the length between endcaps. Isn't that the reason for using a vertical core?
I know you only dropped an inch off the width so i'm curious what the changes should do.
I had availability issues with the other FMIC, so I found a more reliable supplier that will build these to my specs.
So i heard my Z run the other day over the phone!
I have been traveling between Santa Monica and NYC too much. I hate my life right now. No car, women, or fun... Just work!
um sasha, PM me price PLZ!. This IC would fit perfectly on my bumper.. the one now looks very pointy .. My front end is bigger than stock. Besides, I need to keep my self busy with the car over winter lol...
Availability is always a good thing
Just thought I update a couple of small thing in this thread since it still gets a few visits.
It was brought to my attention that a couple of people had a bit of a hard time reaching one of the bolts on the driver side header (3-bolt flange). I made a small revision, and now it is easy to reach it with a 14mm (9/16") socket. In the picture below you can see what I mean (bolthole on the bottom).
Top is old, bottom is new:
One customer brought up the OEM power steering cooler, and the fact that it can be a PITA to relocate it with the OEM hard lines. As always, I listen to feedback and now include a simple bracket with a few feet of rad hose to alleviate this issue:
It is simple, and easy to install.
I have also made a change to the down pipes. No performance improvements, just easier for me to duplicate:
A couple of orders came in this week so I had to build up stock again:
Shot of the day
Shot of the day
