New winter new turbo build
Old Jan 20, 2013 | 12:44 PM
  #621
350z006's Avatar
350z006
PM this guy...
https://my350z.com/forum/members/141...rformance.html
Originally Posted by Simon da Silva
where can i buy this?
Old Jan 20, 2013 | 02:31 PM
  #622
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Originally Posted by 350z006
Thank you. The prices/details can be found here:
https://my350z.com/forum/members/boo...itor_messaging
While I am here...I just finished a custom kit with a catalytic converter in the down pipe. This customer asked to have two oxygen sensor bungs welded after the cat for OEM post cat sensor relocation. They can't be seen as they are on the top. The sensors are between the cat outlet, but upstream from the waste gate recirc.
At the same time I figured out a different way to add the exhaust hanger needed to support the weight of the turbo. This will be specific to the G35 guys, since it is a bit different under there due to the two-piece drive shaft:
It is very simple, just have to take one of the skid plate bolts out, and loosen the other. The hanger/plate sandwitches between the skid plate and fram. It will never move.
Old Jan 20, 2013 | 02:48 PM
  #623
suprasam's Avatar
suprasam
Top notch work Sasha! I love seeing your updates!
Old Jan 27, 2013 | 11:48 AM
  #624
tw2's Avatar
tw2
Have you ever produced a kit for a right hand drive car? Is there any difference?
Old Jan 27, 2013 | 12:09 PM
  #625
Boosted Performance
No I have note, and the current kit would not fit. I think the starter is on the opposite side, and would interfere with the charge piping.
Old Jan 27, 2013 | 02:23 PM
  #626
Resmarted's Avatar
Resmarted
Can't you just move the starter to the opposite side if you extend the wires? I can't remember on the bell-housing but I thought there were two holes...
Old Jan 27, 2013 | 02:50 PM
  #627
tw2's Avatar
tw2
Thanks for the quick reply.
I think the starter was moved to the other side because it interfered with the steering rack so unfortunately I don't think so. Vortech it is....
Old Jan 27, 2013 | 03:51 PM
  #628
Resmarted's Avatar
Resmarted
Sasha could you just flip the piping and create new mounts to get a RHD kit together?
EDIT:
Intake piping would be a mess. I know. I've been there...
Old Jan 27, 2013 | 05:39 PM
  #629
Boosted Performance
EDIT:
When it comes to a $6,500 investment (complete kit) by a customer, I don like to guess.
To do this right (and that is the only way to do it) I would have to have a RHD 350z on my lift.
Old Jan 27, 2013 | 07:18 PM
  #630
jerryd87's Avatar
jerryd87
havnt really looked but to flip everything i would imagine it would need a different intercooler too since swapping side, but the tb should still be on the driver side
Old Apr 7, 2013 | 08:36 PM
  #631
Boosted Performance
Thought I update on a couple of small things with this kit..
The lowest part of this kit used to be the crossover pipe. I recently made a small/simple adjustment on that, so the pipe clearance is increased. These crossover pipes now come with a small section of flat 304ss plate welded on the under side:
This was never a clearance issue before (at least no customers have ever had issues with it).
All the flanges are also now 304ss V-band, vs. the 2-bolt flanges used before:
I think I posted this earlier...but it doesn't hur to post again. The G35 cars have the two piece drive shaft so finding a good common exhaust hanges support was a bit of an issue since I did not have a G. Both cars do however have the rear skid plate, so that is the optimal place to use the hange:
This hanger supports the weight of the turbo, and down pipe so that no additinal weight is added to the OEM headers.
The intercooler pipe going under the driver side headers has also been changed to 2.5" vs 2.75". This does not change the performance at all, but does improve clearance and is easier to install. It can also now be removed independently from the car, without removing anything else. This was not possible with the 2.75" diameter pipe.
These kits are still doing well. It seems that every time a car with this kit enteres a shop that has not seen this setup before, they say it is the best kit they have seen on the Z. This is on both fitment and simplicity. On top of that the tuners are always suprised on how responsive it is, and how effortless the power deliver is.
Quote from a recent customer:
"And the shop it's at loves your kit btw. said it was one of the best looking kits they have ever seen."
Old Apr 7, 2013 | 09:25 PM
  #632
Da_tigga's Avatar
Da_tigga
Is this my kit???
Old Apr 7, 2013 | 09:50 PM
  #633
Boosted Performance
Originally Posted by Da_tigga
Is this my kit???
One of the two that I am shipping out as soon as the flanges arrive is yours. That is the only thing left.
Old Apr 8, 2013 | 09:03 AM
  #634
binder's Avatar
binder
Oh ya, love the full v-band setup.
I also dig that 2.5" pipe section since the 2.75" is a SUPER pita to get it not to rattle (on my car with aftermarket headers. I might need to purchase one if i ever get back around to working on my car.
Old Apr 8, 2013 | 12:10 PM
  #635
Da_tigga's Avatar
Da_tigga
Cool thanx Sasha
Old Apr 21, 2013 | 08:53 AM
  #636
Boosted Performance
This kit is still producting some great results. Another short block build, wastegate spring only, 6266 T4 .81 a/r, pump gas:
I hope to do a group buy of about ten mid mount kits towards the end of this year, so start saving .
Old Apr 23, 2013 | 06:42 AM
  #637
Da_tigga's Avatar
Da_tigga
Did RT do the short block for this??
Old Apr 23, 2013 | 08:32 AM
  #638
Boosted Performance
Yes they did the entire build. Vince was very suprised when the car made over 600whp with 14psi of boost (boost pressure at peak power) on pump.
Old Apr 23, 2013 | 10:58 AM
  #639
Da_tigga's Avatar
Da_tigga
You wouldnt happen to know how much the block build was?
Old Apr 23, 2013 | 11:03 AM
  #640
Boosted Performance
Sorry, I do knot know.
