Need help with arc v2 catch can install on turbonetics setup!!!!
Old Nov 12, 2009 | 07:46 PM
Nvmyz2's Avatar
Nvmyz2
Default Need help with arc v2 catch can install on turbonetics setup!!!!
I installed the arc v2 catch can according the intructions it came with and after driving for a while, i notice white smoke coming from the exhaust. Because of the turbonetics kit, I think there might be a different way to install the arc catch can. Need to know where the hoses need to connect???
Old Nov 13, 2009 | 06:35 AM
str8dum1's Avatar
str8dum1
white smoke has nothing to do with a oil/catch can. Thats head gasket.
either way, you plumb it between the PCV valve and the nipple on the plenum.
Old Nov 13, 2009 | 06:43 AM
Nvmyz2's Avatar
Nvmyz2
it started smoking right after i installed the catch can...the driver side is connected to the intake before the turbo...i wonder if that has anything to do with it since it might sucking oil from the catch can...
Old Nov 13, 2009 | 07:08 AM
str8dum1's Avatar
str8dum1
white smoke is radiator fluid, not oil....
so its attached to the inlet on the turbo and then where else?
hit that 'search' button and you'll have a days worth of reading on how to set up a catch can properly.
Old Nov 13, 2009 | 06:49 PM
Nvmyz2's Avatar
Nvmyz2
i changed the setup and attached the passenger side to the pcv and plenum...and i plugged up the drivers side....there is alot of suction...after i did this everything seems to be running fine now...
Old Nov 13, 2009 | 08:10 PM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
You can do like I did, drill out the pcv and run a hose from each valve cover to the can, and vent to atmosphere through a small K&N filter.
Old Nov 14, 2009 | 06:39 PM
Nvmyz2's Avatar
Nvmyz2
thanks
Old Nov 15, 2009 | 02:48 AM
midz350's Avatar
midz350
Pics or it didn't happen
VO...
Aug 4, 2012 07:14 AM
NA350Z
Dec 9, 2006 03:03 AM
dynamic6er
Apr 25, 2006 08:09 AM
VeilsideZ33
Sep 16, 2005 10:26 AM
