ARC Oil Catch Can and AAM Spec Modified ARC Catch Can
Old Apr 10, 2006 | 12:03 PM
dynamic6er's Avatar
dynamic6er
Default ARC Oil Catch Can and AAM Spec Modified ARC Catch Can
We have found that mounting a standard Greddy or Universal type oil catch can in the 350Z is a huge pain. Fortunetly ARC makes this awesome unit that installs right under the stock strut tower on the passenger side. One downfall to this setup is its more for Naturally Aspirated motors. That is why we are offering our Custom AAM Spec Modified ARC Catch can.
With a Forced Induction car it helps immensely to utilize intake vacuum (pre-turbo/suprecharger) to evacuate the crankcase of excess pressure created by blow-by and other factors. Ring sealing is better and seals/gaskets are less likely to blow out. At the same time, without a catch can, the atomized oil and carbon will eventually build-up in your intake piping and intercooler causing a loss of efficiency.
How can this be avoided? Well you could use a universal catch can and try to rig a bracket up to secure it in the engine bay. Or you could use our Modified ARC catch can that fits perfectly into the engine bay.
We are using this design on quite a few cars, including a customers car that just made 501RWHP on the stock motor with an HKS F-Con PRO (shown in last picture).
ARC Catch Can Retial: $269
SALE PRICE: $219
AAM Spec Modified ARC Catch Can: $319
We will weld a tube onto the ARC Catch can so that you can connect a vacuum line to the intake nipple prior to the Turbo or Supercharger or on the Factory nipple just as you would with a "Universal Catch Can". The ARC does not include enough vacuum tubing to connect to the intake so you will need to supply this (readily available at NAPA or many auto parts stores).
Please note these pictures are of an AAM Spec Modified ARC Catch Can but it uses AN fittings. The modified catch can will have a tube welded on that is similiar to the existing ARC tube you see in the pictures above. We will also weld the vent holes at the top of the catch can closed. As you can see our new tube exits on the left side of the ARC catch can. This allows us to utilize the ARC internal baffle system.
PLEASE CONTACT US @
SALES@ALTEREDATMOSPHERE.COM
301.330.8835
Old Apr 10, 2006 | 12:54 PM
tig488's Avatar
tig488
question, in that last pic, the top ss braided line in front of the motor at the "T", is that going behind the timing cover and hitting another "T" that goes to both valve covers?
Old Apr 10, 2006 | 01:05 PM
dynamic6er's Avatar
dynamic6er
Yes. The ARC takes the PCV line and connects that to the Catch Can and then brings the line from the valve cover on the drivers side over to the cach can. Then there is a cap put on the PCV tube on the intake manifold.
Old Apr 10, 2006 | 02:00 PM
failsafe306's Avatar
failsafe306
I want one
Old Apr 10, 2006 | 02:10 PM
dynamic6er's Avatar
dynamic6er
Originally Posted by failsafe306
I want one
Old Apr 10, 2006 | 07:15 PM
mchapman's Avatar
mchapman
Looks nice,
What is the baffling like on the inside of the catch can?
Old Apr 11, 2006 | 06:13 AM
dynamic6er's Avatar
dynamic6er
Originally Posted by mchapman
Looks nice,
From what I can see it looks about like this internally (lol...pretty sweet photoshop skilz too )
Old Apr 11, 2006 | 06:23 AM
MADScientist's Avatar
MADScientist
Are these avail and in stock for sale right now? I want one!!!
Old Apr 11, 2006 | 07:16 AM
dynamic6er's Avatar
dynamic6er
I have the unmodified versions in stock. The modified ones can ship the same day or following day.
Old Apr 11, 2006 | 07:23 AM
dynamic6er's Avatar
dynamic6er
Here's the link!
AAM Spec Modified Catch Can
Be sure to us the check box for the modified version! Thanks!
Old Apr 11, 2006 | 12:57 PM
buzzardmountain's Avatar
buzzardmountain
This may be a dumb question, will this work with the APS strut bar or Crawford?
Old Apr 11, 2006 | 01:17 PM
dynamic6er's Avatar
dynamic6er
It looks like it will be close. I don't have one here to test fit.
Old Apr 13, 2006 | 11:50 AM
buzzardmountain
If you come across one to test fit, would you mind updating this thread or PMing me. This is what's keeping me from buying it.
Old Apr 13, 2006 | 11:52 AM
dynamic6er's Avatar
dynamic6er
NP!
Old Apr 13, 2006 | 12:05 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I have a Crawford STB I can put on a Z at AAM if they wanna test fit it.
Or Dave can send me a ctach can and Ill test fit it for you
Old Apr 13, 2006 | 12:30 PM
dirtroad's Avatar
dirtroad
Assuming it fits an APS setup, is this something that can be installed by a hack without special tools? Please let me know once it's tested on APS...
Old Apr 13, 2006 | 12:40 PM
dynamic6er's Avatar
dynamic6er
LOL...definetly. Very straight foward.
Old Apr 13, 2006 | 12:48 PM
dirtroad's Avatar
dirtroad
You guys should go ahead and include the extra lines and connections needed. Make another few bucks on it, and us lazy consumers don't have to do anything extra.
kevinapex's Avatar
kevinapex
Mine will be at my door tomarow!! I'll post some picts.
Thannks for your help Dave!!
Old Apr 13, 2006 | 01:02 PM
dynamic6er's Avatar
dynamic6er
Thanks!
