So yea went to the track last night (Greddy TT)
Old Nov 28, 2009 | 05:12 AM
projektZ's Avatar
projektZ
Default So yea went to the track last night (Greddy TT)
It was a really great night. Not too many cars. No crappy civics for once and it was nice and cool out, in the 40's. Brought my drag radials out for the 1st time.
12.4 @ 111 with a 3rd gear screw up
Broke the axle
End goal for this Z is 550-600 rwhp so I guess it's time to get some stronger axles...
Old Nov 28, 2009 | 05:15 AM
doug's Avatar
doug
not the axles.. its your launching technique
Old Nov 28, 2009 | 07:48 AM
tylerxfire's Avatar
tylerxfire
what was ur 60ft.? u should pull much more mph that what u are unless u are saying u coasted thru the traps...post ur slip up
Old Nov 28, 2009 | 07:55 AM
03threefiftyz's Avatar
03threefiftyz
Agreed, I only trap 4mph lower with 130whp less.
Old Nov 28, 2009 | 08:41 AM
OMERTAITALIA's Avatar
OMERTAITALIA
i got 435whp at 10 psi and ive never broke a axle
Old Nov 28, 2009 | 08:49 AM
silverbullet_Z's Avatar
silverbullet_Z
better knock on wood
Old Nov 28, 2009 | 08:51 AM
binder's Avatar
binder
that sucks.
how many runs did you get before you broke an axle?
Old Nov 28, 2009 | 09:20 AM
str8dum1's Avatar
str8dum1
good thing they are only $70 shipped on ebay and even cheaper if you can soruce them on car-parts.com locally.
You broke going into 3rd gear?
this should be in the drag forum as well, not FI
Old Nov 28, 2009 | 09:37 AM
350Z400rwhp's Avatar
350Z400rwhp
Yea 111 seems slow for a 12.4. I ran a 113 with a 13.3 with lots of wheel spin. I broke my supercharger cog belt when I went so I share your feelings when you go to the track and don't get to get a few runs in. Axles are cheap no big deal.
Old Nov 28, 2009 | 10:33 AM
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
Oh noes!!!
U think you'll find an axel soon? Try Jim at Turbo Toys in Tampa:
Jim Polson-813-695-6664/ 1-888-214-4880
Old Nov 28, 2009 | 12:46 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
There is a thread about a group buy on DSS pro axles now is a good time to look into it.
Old Nov 28, 2009 | 03:57 PM
projektZ's Avatar
projektZ
I don't have a scanner. The first run I did a 12.9 at 111mph but I didn't do a burnout. It spun all through first gear but hooked up the rest of the run.
The time slip reads:
60': 2.080
330: 5.638
1/8: 8.509
MPH: 85.78
1000: 10.906
1/4: 12.928
MPH: 111.44
I did a total of three runs with the last one being at 12.4 at 111mph but messed up on third gear. Went into the third thinking I missed it and put the clutch in but realized it was in gear.... cost me .2 on the time im sure but I think it is easily capable of an 11.9... I thought it was strange in regards to the mph as I did a 13.3 on street tires at 115mph with a 2.3 60' but I spun through first and second (This was a run I did about a month ago). The results from the 12.4 run are as follows:
60': 1.870
330: 5.351
1/8: 8.162
MPH: 88.09
1000: 10.496
1/4: 12.495
MPH: 111.27
The drag radials really do make a differance. It was the standing burnout that broke the axle. Broke the passanger rear right before the spline goes into the hub.
I want to go on the "Run 7" Dec 15th but I don't want to go with stock axles. I am thinking about putting a stocker on for now and upgrading after christmas to the driveshaft shop stage 2 with a nismo or cusco diff.
Old Nov 28, 2009 | 04:32 PM
tylerxfire's Avatar
tylerxfire
damn...that mph is strangely low for your power level...a 1.8 60ft. isnt too bad so must not have been spinning bad there..
Old Nov 28, 2009 | 04:37 PM
projektZ's Avatar
projektZ
Originally Posted by shezzzhot
Oh noes!!!
Thanks. I will try to give him a call on monday. I really want to go ahead and drop the bomb to get the upgraded axles b/c theres no point in going to the track on street tires now that I've seen what it can do with the drag radials. lol
Old Nov 28, 2009 | 08:09 PM
Sylvan Lake V35
I ran similar times 12.7 @112mph with a 2.08 60ft on street tires with around 400whp what altitude are you running at i am at a high altitude and that usually kills the trap speed a bit.
Old Nov 28, 2009 | 08:16 PM
03threefiftyz
Well, it's FL......It just about has to be under 200'.
Old Nov 28, 2009 | 08:34 PM
Sylvan Lake V35
I guess the location on the left gave that away I am over 2400ft and density altitude is usually over 3000ft in Orlando i would expect it to be close to sea level so i would expect some better trap speeds. What size are your drag radials, i tried DR with a shorter over all diameter than stock (all that was available at the time) and it caused me to have to shift right before the finish line or I would hit the rev limiter and I also noticed i lost about 5mph.
Old Nov 28, 2009 | 09:34 PM
03threefiftyz
Well if the temps were in the 40's as mentioned........the DA very well could have been negative. Certainly no more than 300-400'.
Old Nov 28, 2009 | 11:46 PM
Blackbird CPV35's Avatar
Blackbird CPV35
Don't waste your money on the lvl 2's. Jump on the group buy for dss pro axles
Old Nov 29, 2009 | 12:51 AM
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
Seems like now is a great time to do that group buy and get your Z an early Xmas present!!
