My powerlab gt37 numbers
Old Dec 3, 2009 | 12:10 PM
marra23's Avatar
marra23
Default My powerlab gt37r numbers
OK, so at last i manged to fix my utec voltage and some breathing issues.....power kept dropping at around 5500rpm.
After a 4hour dyno session my DW600 injector was maxed.
Keep in mind it made stock 202whp on the same dyno a while back....dyno was calibrated two days ago.
-437whp with 7.8psi, 95 pump, power all the way to 7000rpm.
Then manage about double spring pressure on my MBC
-542whp/464lb/ft with 15.5psi, 100 race fuel power to 7000rpm....ran a bit leaner due to IDC with very conservative timing.
will post up sheet tomorrow.
Old Dec 3, 2009 | 12:18 PM
str8dum1's Avatar
str8dum1
nice.
so you needed 100octane to run 15psi? Intense ran that turbo up to 700 hp, so it seems that mid 500s should be doable on pump.
Old Dec 3, 2009 | 12:21 PM
ni$mo350's Avatar
ni$mo350
Very nice #'s congrats..
Old Dec 3, 2009 | 12:22 PM
frankie945's Avatar
frankie945
he probably was running high octane to get that much power out of 600cc inj. I bet your IDC is way too high.
great #'s in for dyno sheet.
Old Dec 3, 2009 | 12:23 PM
marra23's Avatar
marra23
Originally Posted by str8dum1
nice.
I'd guess but around here we don't like going past 1bar with pump.
Low stock numbers due to altitude, around 5000ft.
Old Dec 3, 2009 | 12:31 PM
marra23's Avatar
marra23
Ya IDC hitting 90's....static fuel pressure just under 3bar so I'll bump this a bit tomorrow when i pick up my car and maybe just one run for safety.....might be looking for 750cc.
My intention is only to run high boost map for a few 1/4 passes if my axles last
Old Dec 3, 2009 | 12:40 PM
frankie945's Avatar
frankie945
I wish I went with the 37r. I would get some 750 or 800 like you mentioned beter safe then sorry. And after you get use to it you will be wanting more. Enjoy the power.
Old Dec 3, 2009 | 01:23 PM
Vas_Z33's Avatar
Vas_Z33
awesome!!! VIDS & PIX!!!!
Old Dec 3, 2009 | 02:05 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Congrats Nice numbers for the PSI levels, especially at 5000 feet elevation... or are these numbers after a correction factor for altitude?
Old Dec 3, 2009 | 02:28 PM
GT-ER's Avatar
GT-ER
Not knocking your numbers, since 550whp is no slouch....but why not stick with the GT35R and get those same exact numbers with less lag? Unless you wish to push it upwards of 650whp ( I have no idea what your plans are ).
Old Dec 3, 2009 | 03:42 PM
SlideFox's Avatar
SlideFox
^^He bought a used kit off of someone who had the GT37R
Old Dec 3, 2009 | 03:55 PM
str8dum1's Avatar
str8dum1
ya 5000 feet elevation changes stuff..
in for the sheet
Old Dec 3, 2009 | 04:55 PM
midz350's Avatar
midz350
I wish I have the PL kit, the GT35 HTA will be insane.
Old Dec 3, 2009 | 05:53 PM
SlideFox's Avatar
SlideFox
So you rather have a Powerlab GT35R Kit instead of your GTM TT HR Kit?
Old Dec 3, 2009 | 06:00 PM
str8dum1's Avatar
str8dum1
and the HTA wouldnt be insane either. maybe on a honda or any other sub 3000 lb car.
a 76mm or bigger is insane for a single. a sub 650 hp turbo is never insane.
Old Dec 3, 2009 | 07:54 PM
GT-ER's Avatar
GT-ER
Oh...makes sense then. T67's are awesome anyways so have fun.
Old Dec 3, 2009 | 09:09 PM
deanfootlong's Avatar
deanfootlong
nice numbers! i'd love to see what numbers that set up would do at sea level......
im assuming these are not corrected??
Old Dec 3, 2009 | 09:51 PM
marra23's Avatar
marra23
Lag's my friend, i have much more traction out blocks and as soon as i hit higher gears you're always in the boost....prob was just loosing power after 5500rpm in past.
Lets see how it goes now.
I don't think the gt35r would if made the same power at set manifold pressure, especially at the top rpm range.
They recon altitude loss on turbo cars 3% around here, numbers corrected accordingly.
Old Dec 3, 2009 | 10:11 PM
350Z400rwhp's Avatar
350Z400rwhp
HP loss is about 2-3% for every 1000 feet of altitude. 5000 feet you are losing about 10-15% so great numbers with this disadvantage
Old Dec 4, 2009 | 01:14 AM
marra23's Avatar
marra23
You sure this is on Turbo as well? most guys around here correct 16-18% on N/A and Supercharged cars.
