Vortech owners : Here is the place where to get 70K bearings.
Old Dec 16, 2009 | 06:43 PM
str8dum1's Avatar
str8dum1
if a SC trq curve is the exact same or better than TT curve, what 'feeling' are you referring to? In a blind test, people would be hard pressed to tell the difference in acceleration between for example my car and a 450hp 18g.
a T-trim would be so far out of its efficiency at 70k. It would be like trying to make 500 on a turbonetics. A YSI on a build motor would be another story... I think a 10 ribbed YSI VQ would hang on the track with a build TT VQ. The potential is there http://www.vortechsuperchargers.com/global.php?cat=5
But what you suggest is not possible with any belt driven system as you cant spool up
Old Dec 16, 2009 | 07:06 PM
350Z400rwhp's Avatar
350Z400rwhp
So yea the belt would be an issue so a cog style or 8-10 rib conversion would be needed. I think with the right head unit this could be more than possible. Now a T-trim and the right combo of pulleys to make say 15-20 lbs of boost on a stock block and bleed off say everything above 10psi and you can see where I am going with this. My point is that turbos produce more flow then is needed so they can produce more boost down low and vent the rest off with a wastegate. The same could be done with a Supercharger. Most all supercharger setups the flow goes from the supercharger directly into the engine so you are limited by the amount of peak boost it produces. Oh and the "feeling" is that midrange surge.
Old Dec 16, 2009 | 07:14 PM
str8dum1's Avatar
str8dum1
ya my car definitely had a nice midrange surge. but again, not many other vortech setups are making 410 ft-lbs on a dyno dynamics.
like i have said in the past, i have logged 4 or 5 various pulley combos and only saw 1-2 psi difference under 4000 rpms. Thats maybe 20-30 hp difference between a 3.33 and 2.62. But with a much bigger charger, maybe there would be more of a difference.
Old Dec 16, 2009 | 08:01 PM
Vas_Z33's Avatar
Vas_Z33
i just posted the graphs, there is not one that has noticeably better torque
trq = hp*5252/rpm
spot check the above graphs for yourself...
thats too common a myth that people are still very ignorant to on this site... when comparing stock blocks, a SC can max out the rods just the same as a turbo kit costing alot more money
I take that back I didnt see the graphics , I was posting through my Iphone.
Old Dec 17, 2009 | 07:12 AM
max-hid's Avatar
max-hid
This thread is of bearing solution....
Old Dec 17, 2009 | 07:38 AM
350Z400rwhp
And the point I brought up is a major reason why someone would want to upgrade their bearings....
Old Dec 17, 2009 | 09:55 AM
str8dum1's Avatar
str8dum1
personally, i would never rebuild the blower myself. i would send it to vortech. I've had excellent turn around times (under 2 weeks). You cant get the proper seals, bearings are unproven, etc. its only 300$ from vortech and is warrantied work.
Old Dec 17, 2009 | 10:23 AM
350z006's Avatar
350z006
I would agree with you on that, although they did cross thread one of the mounting boltd on my SI trim when I got it back after a quick rebuild. My main issue is the unknown-rated bearings that Vortech uses. Are the blower max-rpm ratings based on the bearings or the impeller, or both?
Old Dec 17, 2009 | 10:50 AM
str8dum1's Avatar
str8dum1
its a combo of both. the cast impellers are prolly only balanced to some safe range past the 'max rating'. after that the chances of throwing the impeller into volute prolly gets much greater.
Old Dec 18, 2009 | 04:26 AM
max-hid's Avatar
max-hid
I live i9n dominican republic and is very expensive for me to send it and then receive it again...but i think with a shop here we an do a good job..they rebuld another vortech and its ok a year later..
Old Jan 6, 2010 | 02:37 PM
350z006's Avatar
350z006
Hey Vas did you ever find the dimensions of the input shaft bearing?
Old Jan 21, 2010 | 03:28 PM
RA11325's Avatar
RA11325
Based on some light reading I have been doing, correct me if I am wrong:
Standard SC-trim blower + bearings and seals + 928 impeller = cheaper alternative to T-trim?
Old Jan 21, 2010 | 04:01 PM
str8dum1's Avatar
str8dum1
no, the T-trim is a physically bigger blower
also there has only been 1 person to use the 928m impeller and he was on a non-standard setup. so who knows what that 500$ impeller does
Old Jan 22, 2010 | 01:01 AM
RA11325's Avatar
RA11325
I know the T-trim is larger, I was just curious if such mods would offer a significant upgrade in performance since it would cost approximately a 3rd of what a T-trim costs.
Old Jan 22, 2010 | 06:28 AM
str8dum1's Avatar
str8dum1
you could upgrade to a YSI blower for the cost of a S-trim plus all that other junk.
doesnt make any sense to take a good warrantable blower and add a bunch of non-standard/untested parts.
There is no-one who has tried that combo. There was a kit for sale with all that stuff, but it has been bought and resold so many times and never installed I have lost count.
if you want more power get a bigger blower from the start.
Old Jan 22, 2010 | 10:31 AM
RA11325's Avatar
RA11325
Do you happen to know off hand how much a YSi upgrade costs?
Old Jan 22, 2010 | 01:09 PM
str8dum1's Avatar
str8dum1
a new one is 2300$ but vortech has that trade in program. Call Mariano at vortech and check.
Old Jan 22, 2010 | 05:40 PM
  #38
Mr_pharmD's Avatar
Mr_pharmD
2300? I wish someone would do one.
Old Jan 22, 2010 | 06:54 PM
  #39
binder's Avatar
binder
i thought we decided there wasn't enough room to fit a ysi in our car. I think the fx35 fit it because there is more room between the front support and the engine.
Maybe if someone modified the front support and put a custom radiator in the ysi will fit.
i might talk to them about a t-trim update. I didn't know they had a trade in program.
Old Jan 22, 2010 | 07:41 PM
  #40
str8dum1's Avatar
str8dum1
ive seen dimension pdf's for the ysi somewhere. thats how I knew beforehand that the bolt pattern was the same. i think it was 1" thicker. i dont have my blower anymore so i cant measure to see if it fit.
I think Quamen had the pdf's, but it cant remember.
