Vortech owners : Here is the place where to get 70K bearings.
ya, i remember those floating around. I'll have to dig for them. If the dimensions allow it to fit and there is actually one that i can find and purchase then i'm not against trying it. The built motor is just waiting for more hp
i thought we decided there wasn't enough room to fit a ysi in our car. I think the fx35 fit it because there is more room between the front support and the engine.
Maybe if someone modified the front support and put a custom radiator in the ysi will fit.
i might talk to them about a t-trim update. I didn't know they had a trade in program.
that's why I want someone to try... if it fits without mods or little mods then I would trade in my T trim
It will be another couple of years until i'm done before i can financially support this along with the time. My car is in my garage 4 hours away currently.
i was thinking this also. Even if it was very close they could run an intake tube out the front to the airfilter. g35 has a/c lines that run right in front of the vortech so those will have to be rerouted. There is almost no room for a standard Sc trim air filter in there in stock config.
exactly like that.
the g35 has a/c lines all bundled around in there and there isn't a hold in the support brace. There would need to be some mods involved to make that work. Cutting the support wouldn't be a big deal, but moving those a/c lines is a pain in the butt.
its not that hard. the original gtm G35 kits run a 3" pipe thru a hole there. All you have to do is trim some of the plastic on the radiator mount and you can move the lines over almost 2"
350Z_Al
Oct 29, 2020 07:44 PM
