200mph in 1 mile
Old Dec 20, 2009 | 12:16 PM
binder's Avatar
binder
Originally Posted by CrazyVQ35tt
It was 102° on the runway it should be 20 to 30° cooler this time.
Had to pull timing because of intake temps was too high.
meth injection will solve both of those problems by reducing intake temps.
Old Dec 20, 2009 | 12:45 PM
03threefiftyz's Avatar
03threefiftyz
Honestly, I would check out supra forums man.....there are several members there who do several 1 mile races. The C/D of our cars is pretty close to them as well. Since you are in a G....the weight is close as well. From what I have seen on there....800 +/- 50 (dynojet) seems to be the consensus for 200mph. Like mentioned above...initial traction plays a huge roll. Gaining mph from there means drastically bumping the hp up. The record setting SW supra (246mph) traps in the mid 180's in the 1/4 mile to give you an idea. Though I have heard the boost is turned down a bit for traction purposes. Still figure that car is making 1500+whp.
Old Dec 20, 2009 | 12:48 PM
CrazyVQ35tt's Avatar
CrazyVQ35tt
Originally Posted by Kwame@z1Auto
Theoretically yes it should, but in the real world drag is very difficult to overcome. I can only imagine (well it's possible to mathematically figure it out without having to imagine) how hard it might be to gain an extra 9 mph at 191 mph. Maybe you know more than you are letting on and have it all figured out; I hope that is the case.
I wish you the best of luck. I'm a big fan of your car and I posted it up on our blog awhile ago.
http://cornerbalance.wordpress.com/2...e-one-fun-g35/
I definitely do not have it figured out and I don't have any tricks of my sleeve the only way I know to get over 200 mph is more power. Thanks
Old Dec 20, 2009 | 02:03 PM
graffkid732's Avatar
graffkid732
I am no expert what so ever. But in only a mile having the attitude of "more power" can not be the answer to that. As others stated, if you spin a lot, that will kill your chances. I think, also as others have said, you should look into functional aero. Just because you have 800rwhp, doesn't mean you will hit 200mph in 1 mile.
I am just thinking realistically here. But good luck to you, and I hope you find out and do what you need to do to be successful with this.
Old Dec 20, 2009 | 02:07 PM
doug's Avatar
doug
^^^ ding ding... its going to come down to areodynamics.. you need to find a way to get rid of all that wind thats holding you back.. more power isn't going to solve the problem
Old Dec 20, 2009 | 02:29 PM
Glex25's Avatar
Glex25
also the gearing
I thought the 3.5 FD gearing limited you
that's why I say 3.3 FD and higher redline should bring up your top speed
Apart from what everyone else has said
Old Dec 20, 2009 | 02:39 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I'd first look into a full underbody 'tray' (flat bottom).
I personally wouldn't run the 3.5 final drive - the 3.3 would allow you to come out of the hole harder, get into the boost sooner, and give you a higher top end per gear. Problem is, it won't work with a NISMO LSD, but other diffs would work (Quaife and Cusco do diffs that are specific for the 3.3 auto ring and pinion)
Any idea what the car weighs? Any practical ways to reduce weight?
Old Dec 20, 2009 | 02:50 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
I remember seeing pictures of your car before. It is all business for sure . Please keep us updated on your progress and i would like to know your power/torque and weight when you do your run also the mph you get. A goal of mine is to run the Texas mile and your story will be a good indication of what it takes to make the 200mph club.
Good luck and I hope you make your goal.
Old Dec 20, 2009 | 03:51 PM
04fairlazdyz's Avatar
04fairlazdyz
LOW N SLO
Good Luck!!! Hope you hit your goals, may take a few tries of trial and error on a few things. +1 on the aerodynamics too.
would be interested in seeing pics of your car!! Glad to see another G around thats into power not just looks like most G's
Old Dec 20, 2009 | 04:00 PM
Spork's Avatar
Spork
Beautiful
Old Dec 20, 2009 | 04:11 PM
binder's Avatar
binder
i just checked out that blog. that car is serious stuff.
It appears that the oem plenum has been removed and a custom one built. It's not an individual throttle body setup but it has more of a LSx design. I like it. Any info on the gains from it?
Old Dec 20, 2009 | 05:37 PM
SniperHunter's Avatar
SniperHunter
Looks very cool. What airport in Florida do they hold this event at?
Old Dec 20, 2009 | 06:23 PM
Sylvan Lake V35
Pretty much all of the G owners on this site are about performance thats why we come here instead of Driver more Go than SHOW
Anyway here are some pictures of the OPs car the blog shows pictures of the interior all business same with the trunk.
Old Dec 20, 2009 | 07:41 PM
Heist.'s Avatar
Heist.
That G is just amazing, Love the transformation. Yet to see one that looks so clean and serious means "business" is an understandment.
GOOODLUCK! fingers crossed you pull it off.
Old Dec 20, 2009 | 07:54 PM
350Z400rwhp's Avatar
350Z400rwhp
XKR?
Old Dec 20, 2009 | 08:19 PM
rpm06g35's Avatar
rpm06g35
xkr knows all about this. He posted up comments from the first milemarker1 event.
Old Dec 20, 2009 | 08:23 PM
Sylvan Lake V35
OP also said he wants to be the first 3.5L G35 to go 200mph in the mile XKR is a 4.0L.
Old Dec 20, 2009 | 08:25 PM
  #38
go-fast's Avatar
go-fast
loose the side view mirrors,tape up the seams,custom undertray and improve the aero on that shovel of a nose
Old Dec 20, 2009 | 08:48 PM
  #39
350Z400rwhp
Here is some info that may help.....
http://racingarticles.com/article_racing-21.html
Old Dec 21, 2009 | 05:06 AM
  #40
Alberto's Avatar
Alberto
Cranky FI Owner
Revving to 7500rpms in 6th gear? Doubt it
Try a 3.3 FD to help you stay in the better part of the powerband.
