200mph in 1 mile
Old Dec 20, 2009 | 07:52 AM
CrazyVQ35tt's Avatar
CrazyVQ35tt
Default 200mph in 1 mile
I am going to the mile mark-1 event on January 3 to TRY and be the first G35 with a 3.5 liter engine to do 200 mph in the US. Everyone is invited to come and hang out in the pits and watched the madness.
Last time it October the car ran a nonofficial speed of 191 this time they will have a TAG HEUER system to record speed/times and give out time slips just like the Texas mile. Last time it was very unorganized and many people were upset. The event holders realize how serious sponsors and shops take this event and promise to make this event more organized and official then the event held in October.
So what does it take to go 200 mph in 5,280 ft 1 mile?
<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/vc85X27uBYk&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/vc85X27uBYk&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
Old Dec 20, 2009 | 07:59 AM
bigcloud's Avatar
bigcloud
Wow another high powered G35 Coupe!! What type of WHP you running? Build specs?
Old Dec 20, 2009 | 08:01 AM
*Boose*'s Avatar
*Boose*
You bring me hope and joy. Goodluck to you. Do you have a list of mods? 1/4 mile times, dyno sheets, anything to get me turned on?
Old Dec 20, 2009 | 08:06 AM
Glex25's Avatar
Glex25
3.3 FD
Higher Redline
Old Dec 20, 2009 | 08:08 AM
Two words. Pop Charger.
Old Dec 20, 2009 | 08:12 AM
*Boose*'s Avatar
*Boose*
Oh lawd. ::
Old Dec 20, 2009 | 08:15 AM
Vas_Z33's Avatar
Vas_Z33
XKR... where are you? =)
Old Dec 20, 2009 | 08:19 AM
*Boose*'s Avatar
*Boose*
I think he's running the fwhp type.
Old Dec 20, 2009 | 08:40 AM
CrazyVQ35tt
Engine specs
JE pistons with 8.5 and 2618 T6 high tensile forged aluminum 95.5mm bore with a Ceramic/Moly Piston Coating
The new ERL Performance Main Girdle
Pauter Rods 4340 chrome-moly forged rod
ARP Rod Bolts
ARP Main Studs
Rotating assembly 100% balanced
ARP VQ35 L19 Head Studs
The car makes 632rwhp/643rwtq @ 19psi with c16 on a Mustang Dyno
The Nismo LSD 1.5 with the stock 3.5 final gear should put me over 200 at 7500 RPM's the car is geared perfect for the mile
Old Dec 20, 2009 | 08:59 AM
Engine specs
ARP Rod Bolts
ARP Main Studs
Thats a pretty impressive set-up. Most likely you will want to post your time here: https://my350z.com/forum/drag/233840-top-25-1-4-mile-times-for-tt-st-supercharger-nitrous-bolt-ons-stock.html
Old Dec 20, 2009 | 09:06 AM
str8dum1's Avatar
str8dum1
632 hp is enough to get 200 in the standing mile?
what did you change since the 191? 9 mph might as well be 100 mph in most cases.
Old Dec 20, 2009 | 09:34 AM
denchan350gt's Avatar
denchan350gt
Did you spin most of 1st and 2nd? If so try to limit your spin in 1st and 2nd (if you can).
Old Dec 20, 2009 | 10:23 AM
*Boose*'s Avatar
*Boose*
You look like you're running stock aero. With a proven diffuser I bet you could pick up a good 2 to 3.
Old Dec 20, 2009 | 10:29 AM
NISMO_558's Avatar
NISMO_558
What was the point of the video since it really didn't show the car going 200? or really anything for that matter.
Old Dec 20, 2009 | 10:49 AM
doug's Avatar
doug
ain't going to happen
Old Dec 20, 2009 | 10:59 AM
NismoZ123's Avatar
NismoZ123
two words. Pop charger.
omfg where do i buy one
Old Dec 20, 2009 | 11:38 AM
Cass007's Avatar
Cass007
What TT kit are you running? I would expect your whp # to be higher on a c16 tune for a 200mph car.
+1 on the vid not showing a thing.
Old Dec 20, 2009 | 11:40 AM
CrazyVQ35tt
Here are some of the changes from the run in October.
It was 102° on the runway it should be 20 to 30° cooler this time.
Had to pull timing because of intake temps was too high.
Will be running 4 to 5psi more boost.
Raised the rev limiter.
Dialed in the boost controller to work by gear/mile-per-hour to control tire spin in first and second gear.
Experience running my car at that speed.
I'm TRYING to run 200, I hope these changes will get me there.
Old Dec 20, 2009 | 11:53 AM
Kwame's Avatar
Kwame
Theoretically yes it should, but in the real world drag is very difficult to overcome. I can only imagine (well it's possible to mathematically figure it out without having to imagine) how hard it might be to gain an extra 9 mph at 191 mph. Maybe you know more than you are letting on and have it all figured out; I hope that is the case.
I wish you the best of luck. I'm a big fan of your car and I posted it up on our blog awhile ago.
http://cornerbalance.wordpress.com/2...e-one-fun-g35/
Old Dec 20, 2009 | 12:01 PM
CrazyVQ35tt
Read your story last night I have had two oil failures myself your story is pretty crazy. I'm not really sure what's going on with the c16 tune I thought the car would make crazy power on c16 I guess I need more boost + bigger turbos and I just went through 2 engines not ready to take the car apart again. 18G modified by Mike Turbo are the turbos but everything has been modified I mean everything.
