Crank pulleys
Old Aug 8, 2010 | 10:54 AM
  #81
jonnylaw's Avatar
jonnylaw
When replacing the stock crank pulley with the ATI or Fluidampr, did you guys replace the crank pulley bolt or crank pulley seal?
Old Aug 8, 2010 | 02:14 PM
  #82
str8dum1's Avatar
str8dum1
the bolt was like 4$, so I did. didnt mess with the seal.
Old Aug 8, 2010 | 02:25 PM
  #83
binder's Avatar
binder
i didn't replace the bolt or the seal, but the seal was about a month old since i just put a fresh head gasket on.
Old Mar 18, 2011 | 01:52 PM
  #84
e30cabrio's Avatar
e30cabrio
Originally Posted by str8dum1
Ya, mine is def overdrive. same part # as IP sells. See ho close it is to the idler.
But the removeable crank damperner is nice becuase you can replace it.
What belts are you running?
Old Mar 18, 2011 | 07:22 PM
  #85
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
no, i only put the ATI on after I changed my setup and sold the vortech. Like I said, that crank pulley will add 1000 rpms onto your impeller speed off the bat. wayy too much unless you were only using the 3.33
I dont have a standard belt routing anymore either, so no idea on belt length you need. best bet is to measure with some string and buy 4 or 5 belts around and keep the one that fits the best.
Thats what I did
Old Mar 19, 2011 | 05:42 AM
  #86
e30cabrio's Avatar
e30cabrio
Thanks Adam, I hoped having done that the belt part numbers would have been saved and could be shared.
If I do that I certainly will make a note of which belts I use so I don't have to do it again.
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
