injector clips, EV1 or EV2?
Old Jan 10, 2010 | 09:15 AM
str8dum1's Avatar
str8dum1
Default Are these the right injector clips
Hey guys,
what style injector clips do you need for aftermarket injectors?
EV1's like this I think is correct?
http://cgi.ebay.com/ebaymotors/ws/eB...m=320467138141
Old Jan 10, 2010 | 01:48 PM
rcdash's Avatar
rcdash
I think it depends on the injectors. My HKS use stock injector clips. The RC's required the adapter to work... These are denso adapters or some such - Sharif can send you a set unless you really want to rewire everything for the RC style injectors.
Old Jan 10, 2010 | 02:43 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Rich, if you purchase RC or Precision Injectors, you will need to use some adaptor harnesses. As Raj mentioned, the HKS injectors use factor style connections so no changes are needed. The ones you linked from EBAY will work, but you need to cut and solder them in. There is also a PnP version that saves some time, and doesn't require molesting the harness. Let us know if you need anything.
Old Jan 10, 2010 | 03:06 PM
str8dum1's Avatar
str8dum1
i've got a spare harness thats already been cut, so soldering is no big deal.
Thats easy compared to the rest of the stuff on my mile long list. I'm starting to think that dropping the car off and picking it up when its done is the way to go
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
