low-end CAMs on Single turbo application.
Old Jan 15, 2010 | 05:52 AM
  #41
ToastZ's Avatar
ToastZ
Originally Posted by Z1 Performance
512 whp on shariffs DD is not weak by any means unless all you're doing is e-posing. Sounds like a more than sensible figure for a reliable car. Sure as hell beats building multiple motors like so many other have who are merely chasing a random #
Thanks. My goals were definitely centered around reliability compared to maximum horsepower. Sharif listened to that and the car is tuned accordingly.
500whp on a reliable street setup has been extremely rewarding for me. The people I've given rides to in the car are amazed at the comfort level and power the car puts down. I've had zero down time and I drive the car around 13K miles per year all over the southeast. I have thoroughly enjoyed this as a hobby over the past years and will continue to do so.
Old Jan 15, 2010 | 05:54 AM
  #42
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
and that's what it should be all about - enjoy it!
hopefully you can give me a ride at ZDayz Then I can show you what an all motor setup feels like
Old Jan 15, 2010 | 05:55 AM
  #43
ToastZ's Avatar
ToastZ
Looking forward to it.
Old Jan 15, 2010 | 06:02 AM
  #44
str8dum1's Avatar
str8dum1
actually i cant think of any motor failures on here from people chasing #'s. Its always the ones that are just getting the motor started for the 1st time, abuse, or are running 'safe' tunes with no explanation of why it let go.
Has there actually been any one thats popped their motor running 700+ that wasnt sleeved? I cant think of one. i guess maybe because there are few people running that much HP
but ya mid 500s on a DD is a perfect daily driver/road race car. my 460whp DD vortech setup was plenty fun on the street.
Old Feb 1, 2010 | 10:35 PM
  #45
nightcrawler_8's Avatar
nightcrawler_8
update: i decided not to go for the cams untill i fix the issue of boost spike.
need your input guys on a custom External wastegate.
please check the below link: https://my350z.com/forum/forced-indu...-aps-st-2.html
Old Mar 26, 2010 | 08:54 PM
  #46
binder's Avatar
binder
also, i think you're confused on what "low end" and gearing are.
You keep saying you need cams to increase your low end because you are behind in the lower gears. Low to midrange power isn't based on the gear you select, it's your RPM.
I'm not saying you do'nt know the difference, but you've at least said it incorrectly a few times. It makes me think you want more power in lower gears, but that doesn't mean "low end".
Old Mar 28, 2010 | 11:11 AM
  #47
streetzlegend's Avatar
streetzlegend
What are the specs of the turbo nightcrawler? A restrictive exhaust system can cause what you describe. I had a t04b in the past with a 2.25" dynomax muffler and would get higher boost after every gear, for example 5psi 1st, 8psi 2nd, 10psi 3rd and up (my car is automatic). Now when I would open my cutout I would get the 10psi in 2nd gear or sooner. Perhaps your muffler or your piping is restrictive.
