FI VQ on an FX
Old Apr 7, 2010 | 07:23 AM
  #41
quangquoclu's Avatar
quangquoclu
Newbie
congrats! glad you decided to keep it simple.
Old Apr 7, 2010 | 08:16 PM
  #42
whitez33350ztt's Avatar
whitez33350ztt
yeah i was going to say for a stock block and want to be maintain a bit of reliability is to try to stay close to 400whp.. and try to get crazy tq numbers.. bc thats what ususally breaks the stock connecting rods.. wich is the main weak point in the DE motor. i have a vortech on my 03 Z.. and im on stock block and i also wanted quicker acceleration and just a faster car overall but not overkill. and this is perfect for me.. very streetable and pins u back when u wana get pinned back.. i wouldve gone turbo but didnt want very high tq numbers bc i heard thats the real problem
Old Apr 19, 2010 | 12:31 PM
  #43
jumbosrule's Avatar
jumbosrule
Sort of funny how builds mature with education.
Once again, going bigger and better. now doing the full short/long block build. Goal is to build for 650 on the engine, but the turbo will top out around 550, so should make for a reliable, long term build.
Expensive? Yes. But I'm not doing this as an investment or because I want to sell it. I want THIS car customized for me. Here's the latest build list, lol. Hopefully it doesn't grow too much more!!!
Turbo hot side piping
Re-coating after piping mods
GT35 Turbocharger with Tial housing
Tial MVS 44mm wastegate
Tial Q series 50mm BOV
Haltec PnP 350Z platnium
boost controller
wide band system
IAT sensor set-up
ECU supplemental pins (2 units)
oil cooler
fuel injectors
fuel pump
intercooler plumbing
intercooler raw materials - fab
Tuning
General Labor Fabrication time
Stage 1 longblock - labor
Wiseco 96mm/8.8:1 Pistons
Eagle Rods
ACL Trust Washers
ACL Main Bearings(STD)
ACL Rod Bearings(STD)
Machine Work
VQ35HR Head Gasket (2)
Oil Pump - VQ35 RevUp
Stage 2 Return Fuel System - Labor
Fuel rails
Boost reference adjustable rising rate regulator
All new lines for feed side
Brand new custom lines for new return system
Fuel tank adapter hardware
Heat shielding materials
Line end fittings for all associated lines
FX35 Fuel Return Line Extension
ARP Head Stud Kit
ARP Main Stud Kit
Old Apr 21, 2010 | 06:32 AM
  #44
jumbosrule's Avatar
jumbosrule
lol - guess it's not quite so simple anymore...
Old Apr 27, 2010 | 06:08 AM
  #45
jumbosrule's Avatar
jumbosrule
Core block has arrived at the machine shop for the longblock work.
Haltech EMS and sensors, ARP Stud kits have arrived at the install shop
Still waiting on the turbo/wastegate/BOV, plus fuel return system kit to arrive, but the car is going in to the installer 48 hours from now and I don't expect to get her back for about three weeks.
Pretty jazzed up bout this!!!
Old May 6, 2010 | 08:25 AM
  #46
jumbosrule's Avatar
jumbosrule
It's in the shop for install...
Old May 18, 2010 | 06:20 AM
  #47
jumbosrule's Avatar
jumbosrule
Longblock work will be completed this Saturday. Two parts are on back-order, but should not stop the install. Expect the old engine to be out by the end of this week, with the majority of the fabrication and install going down next week.
Old May 25, 2010 | 02:27 PM
  #48
jumbosrule's Avatar
jumbosrule
Stopped by Powerfab this afternoon to check out my Longblock package and the initial teardown of the car.
Longblock machine work, plus rev-up oil pump, HR head gaskets and the pathfinder cooling mod.
And the engine and tranny dropped out the bottom:
New motor should be installed by the end of the week.
Old Jun 2, 2010 | 04:08 PM
  #49
jumbosrule's Avatar
jumbosrule
Fuel system components assembled - CJM stage 2 return system & Walboro 255 installed!
Old Jun 8, 2010 | 04:41 PM
  #50
jumbosrule's Avatar
jumbosrule
Parts back from powdercoating and motor assembly continues.
Old Jun 16, 2010 | 02:58 PM
  #51
jumbosrule's Avatar
jumbosrule
Completed longblock package, new valve covers & tensioners. Did a few powdercoated parts for custom look.
Buttoned back up, along with a new suspension:
Turbo system hot side/cold side fab begins this week.
Old Jun 16, 2010 | 03:05 PM
  #52
Highway Riding's Avatar
Highway Riding
Nice stuff man it will be interesting to see what that 35R will do on that motor. GL
Old Jun 16, 2010 | 03:06 PM
  #53
da mayor's Avatar
da mayor
great progress shots!
Old Jun 28, 2010 | 07:53 AM
  #54
jumbosrule's Avatar
jumbosrule
Hot side fab 95% complete. Cold side in work!
Old Jul 5, 2010 | 01:22 PM
  #55
jumbosrule's Avatar
jumbosrule
Default Breakin in the new motor
Old Jul 5, 2010 | 01:30 PM
  #56
bigcloud's Avatar
bigcloud
Sick setup! What were your numbers?
Old Jul 28, 2010 | 04:03 PM
  #57
jumbosrule's Avatar
jumbosrule
So my research into gauges has just begun and I thought it would be good to actually have a thread that talks about all the different systems out there and what the most common monitoring displays should have. I posted this same thread other forums and so far have not had much response. I could use the help from here on my350z where I KNOW there are boosted VQs.
Universal, expandable setups that have been suggested:
http://www.zeitronix.com/
http://www.hksusa.com/products/more.asp?id=3471
http://www.egauges.com/Defi/dp_top.html
I have identified the items that I want to monitor but I am still not sure where the gauges will be mounted and what they will look like. I'm thinking SMALL. If anybody has links to small gauges - from 1 inch to 1.5 inch digital displays - please post up. I think I'm leaning towards individual gauges rather than a universal display. Interested in but don't have to include all of the following:
Oil pressure
Water Temperature
A/F
Boost
Transmission temp
I have seen some gauges that display multiple items as well - with the ability to display of two or three of the items above on one gauge all at once or selectable with a button.
Here is my shop's recommendation, after I told him I wanted to pick only two gauges:
"AF gauges are nice but only truly useful under WOT for critical monitoring, otherwise they are always in a state of flux. Oil pressure and water temp is always useful data especially when the motor is cold - to monitor oil pressure vs. motor rpm. So when limited to two and knowing the Haltech sees its own wide-band, I prioritize two gauges differently.
The zeitronix display is likely a OBDII pass through tool that displays that data then pipes in it's own wide-band. Currently the Haltech will see all of it's own sensors which can be viewed in the software (read: your laptop), the next option from Haltech is they use Racepack and AIM dash setups which plug in native to the Haltech ECU. These are far from a simple gauge though and are generally meant to replace everything in a car to act as a new digital dash.
This all being said, once Haltech finds a new maker for there gauges themselves (used to be Nordschief or something like that but that went under about a year ago), you'll be able to buy a standalone gauge and wick the signal from your Haltech wide-band so that the same sensor feeds the standalone gauge and the Haltech ecu."
I have seen the Racepack display before and it is sweet, but doesn't fit with the theme of the interior. I want it to look like it belongs there. Here are two options from Racepack:
http://www.racepak.com/Components/Dash_Compare.php
http://www.aimsports.com/auto/index.html
Really I'm wide open to anything as long as the new gauges look like they belong. I'd consider mounting anywhere - on the roof liner, dash, on the console, hidden, pop-up, etc. Only thing that is non-negotiable is the aesthetic. They MUST match the amber OE gauges or interior.
The engine is now broken in and is back in the shop for the power tune. We are coating all the pipes with a ceramic insulator - black on the hot side and silver on the cold side, plenum included. I'll have a dyno to post the day that I pick her up - sometime next week, hopefully.
Old Jul 28, 2010 | 04:29 PM
  #58
tylerxfire's Avatar
tylerxfire
i am about to pull my AEM uego wideband and aem boost gauge ...both digital and match and work nicely...I will be selling them very soon...
Old Jul 28, 2010 | 05:10 PM
  #59
str8dum1's Avatar
str8dum1
the obvious choice is the CAMP2 with added sensors.
but the DEFI and Zeitronix are nice also.
Old Jul 28, 2010 | 05:27 PM
  #60
jbaker1121's Avatar
jbaker1121
hey jumbo! haha
