what about this, instead of fmu
Old Oct 29, 2003 | 07:59 PM
Dissolved's Avatar
Dissolved
Originally posted by damen
is the FMU the weak link for the ATI or do you guys just want to use something different?
I'm not sure. I know very little on the ATI kit other than it's roasted a couple motors. I've always been more of a fan for Vortechs anyway.
The general consensus in the tuning world, is that FMUs are a cheap fix
Old Oct 31, 2003 | 06:21 PM
Dissolved's Avatar
Dissolved
Z1, havent forgot about the little experiment I said I would do. Was in the blown t/a on friday. Fuel pressure at idle with vacuum was 42psi. With no vacuum it was 52psi. However, the T-connector for the boost gauge broke prior to my arrival so I was unable to test the FP under full throttle. Owner is fixing . Will do a full throttle run and report fp readings
Old Nov 1, 2003 | 11:27 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Cool cool...will be interesting to see.
That means though you are running higher than stock base fuel pressure - not a bad thing to do if you have slightly undersized injectors.
What ecu does the car run?
Old Nov 2, 2003 | 02:29 PM
reen's Avatar
reen
Default best.thread.ever
Sorry to interrupt, but I just have to say I'm enjoying this thread immensely.
Very educational -- I appreciate Z1 being so articulate and patient in his explanations. Keep it up!
Old Nov 2, 2003 | 03:13 PM
Dissolved's Avatar
Dissolved
yea slightly higher than stock. Actually, these injectors suffice. Car was running rich before with this setup
ECU was reflashed with a desensitized knock sensor, pulse width decreased in lower/mid rpm ranges
t connector is installed. Just have to run car now
Old Nov 3, 2003 | 08:07 AM
Z1 Performance
Former Sponsor
Sounds good - curious to see what you find!
BTW, as an aside, what motor is this and what size injectors (and impedance) are they?
brickyard bully
Jan 11, 2006 02:03 PM
zimbo
Jul 11, 2004 01:46 PM
fluidz
Mar 16, 2004 05:44 PM
daking350
Dec 30, 2003 04:33 PM
12SecZ
Dec 28, 2003 02:27 PM
