Old question revisited: APS TT kit and smoke out of the exhaust at idle.
Old Mar 11, 2010 | 08:56 AM
rcdash's Avatar
rcdash
^ that's the key right there. The drains and the oil at the seals are not anywhere near the same pressure as within the pressurized side of the oiling system due to the size of the lines feeding the turbo versus the volume they drain into.
Old Mar 11, 2010 | 04:59 PM
ToastZ's Avatar
ToastZ
So you are saying at idle and decel there *may* be enough pressure in the crankcase to cause a perfectly good seal in a relatively new turbo to leak ? I have doubts and still do, peter never convinced me of this and I still have doubts.
If the seals are bad, they leak - even on a brand new turbo, that is my point. The memo is trying to explain why basically a new turbo seal may leak due to high crankcase pressure either at idle or slight decel. If the crankcase pressure is that high then surely you can measure it by simply placing your hand over the oil filler tube, lol. Gravity has to drain the turbo and under 'normal' circumstances the crankcase pressure at idle is in vacuum ( and decel ).
I just don't get it - still no worries, I am no expert
Old Mar 15, 2010 | 12:11 PM
Enron Exec's Avatar
Enron Exec
My car would smoke when idling, especially in the winter. But during the hot summers, i can idle without smoking. With all things being equal, Im still wondering, how come? Can anyone shed some light on this?
Old Mar 15, 2010 | 12:45 PM
rcdash's Avatar
rcdash
that's water vapor
bcoffee20
Nov 19, 2015 06:39 PM
OdesiTT
Sep 30, 2015 10:47 AM
Ace2347
Sep 22, 2015 03:12 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
BlinkerFluid
Sep 8, 2015 10:06 AM
