***Sound Performance Boost Activated Exhaust Cutout Results!!! VIDEO INSIDE
Old Mar 23, 2010 | 08:36 AM
athensgls's Avatar
athensgls
with meth i was running up to 19 deg of timing on utec, made 56xwhp DJ on a turbonetics kit, 530whp on mustang dyno
GreenGoblin's Avatar
GreenGoblin
I am just curious because for a low compression motor and pump gas, no meth or anything that is crazy.
Last edited by GreenGoblin; Mar 23, 2010 at 08:48 AM. Reason: saw the post a few above that says cams
Old Mar 23, 2010 | 08:43 AM
athensgls's Avatar
athensgls
u talking about the aps car right? i agree 14psi amking 600whp on pump is fantastic! took me 18psi to make 560
Old Mar 23, 2010 | 08:49 AM
SoundPerformance's Avatar
SoundPerformance
Sound Performance
Originally Posted by Reid@SP
That car was on 14psi with cams. No spray. We were on a crunch and couldn't do back to back runs with it.
Reid
Reid, the 613 RWHP pull was at 12 psi and the 100 shot!!
It only made 560 RWHP on boost!
Old Mar 23, 2010 | 08:51 AM
athensgls's Avatar
athensgls
big difference!!!
Old Mar 23, 2010 | 08:53 AM
GreenGoblin
I wasnt trying to call you out or anything, just seemed to good to be true.
Old Mar 23, 2010 | 08:54 AM
athensgls's Avatar
athensgls
so a 100 shot equates to only 53whp?
Old Mar 23, 2010 | 09:45 AM
SoundPerformance
Sound Performance
No sir, the 560 pull was at more boost but no nitrous. About 14.5 psi
Old Mar 23, 2010 | 03:06 PM
Reid@SP's Avatar
Reid@SP
This is why you need to clarify with me poo head!
Sorry for the confusion guys.
Reid
Old Mar 24, 2010 | 05:10 AM
GreenGoblin
That sounds much more resonable 20-21 hp pre lbs of boost
Old Jun 28, 2010 | 09:17 PM
Mr_pharmD's Avatar
Mr_pharmD
Ok, I got a chance to install the cut out this weekend but it keeps opening/closing (chatters). How do I adjust it so at idle it will stay close completely?
Old Jun 30, 2010 | 07:43 AM
rrmedicx's Avatar
rrmedicx
Just curious what is your boost signal source for the cut out coming from?
Plenum? Pre-Throttle body? Pre-intercooler, off turbo outlet?
Old Jun 30, 2010 | 10:00 AM
SH Luciano's Avatar
SH Luciano
aps twins or aps single?
Old Jun 30, 2010 | 11:28 AM
IIQuickSilverII's Avatar
IIQuickSilverII
Originally Posted by SoundPerformance
Actually the exhaust is a 3.5" so it does neck down from 4".
The idea of the cutout is that we now dont have to run those annoyingly loud exhausts all day. You can even run the stock exhaust and be nice and quiet and still make 1000 HP !!!
larry, i got a bit confused at 1st but
i am gessing that the 55whp, is kind of the same as making the whole piping 4" rather than neck to 3.5"
I guess taht what he means as far as if the whole thing been 4" what else you pick up... i am assuming there is alwasy a bit just as if you take the exhaust completely off for testing purpuses.
In any case, the felxibility of basically being able to run ANY exhaust is the most apealing... no longer you have to stress about what exhaust you buy n/a if you do if later on do FI.... or about sound/loudness as you say.
TT turbos will have to use 2 i think right... i guess all those with sensitive ears can now run that borla exhaust
ovbiously twins.. and prob extreme version.
Old Jun 30, 2010 | 12:05 PM
thom000001's Avatar
thom000001
Just run 3in DP's to a big Y, then dump after the Y....then a single back to a stock style (or lighter) setup....keep weight down, noise down for normal driving, and power high when in boost.....
Don't forget, Vlad's car has stock exhaust behind the cutout!!!
Tom
Old Jul 3, 2010 | 05:06 AM
rrmedicx's Avatar
rrmedicx
Hey Larry or Reid,or anyone for that matter, any pics of this done on a TT set-up (Z or G). I might need some pics to show how its done. So if I decide to get it done in NY I can just show the shop a pic of what I want. Thanks.
Old Jul 3, 2010 | 07:23 AM
str8dum1's Avatar
str8dum1
they just go inline with the exhaust. so if you have a dual exhaust, you need 2, 1 for each side. basically they are just cutting a section of pipe out and welding in the Y shaped piece with the cutout on it.
Old Jul 3, 2010 | 10:41 AM
  #38
thom000001's Avatar
thom000001
Depends on your exhaust setup Randy.
If you have a X pipe you can or something connecting the two sides you can put it there, or else you will need two.
I will be putting one on my car...mine y's together so I will just need 1 large one.
Tom
Old Jul 6, 2010 | 07:56 AM
  #39
IIQuickSilverII
the most awesome thing of this is that i have never been " excited" about the cost of the true dual exhausts.... and this is just everything everybody needs FI...if you want the dual exists you can do it and still save a bit on the cost form the dual piping...
this exhaust is bringing back all the old exhaust back to FI life...like the amuse (OK that one isn't cheap but it was a shame it was worthless FI), RS, invidia...adn the older true duals scrapped because they were not 3".
I am not that familiar pricing fabrication work, but i am going to guess its cheaper to bastardize a true dual to start from a "y' and just use the cut out then, instead of getting 2 cutouts.
What exhaust you have thom?
Old Jul 6, 2010 | 08:10 AM
  #40
thom000001's Avatar
thom000001
I have a custom exhaust (from before the cutout was available).
3in DP's to a 4in Y. 4in back to the stock muffler. "Modified" stock muffler.
Tom
