Trying to put a seal in my supercharger and need advice........
Old Mar 31, 2010 | 07:37 PM
350Z400rwhp's Avatar
350Z400rwhp
Default Trying to put a seal in my supercharger and need advice........
The seal is made out of metal and rubber and I don't have a press. I have two ideas. 1. Put the seal in the freezer and put the metal housing off the supercharger in the oven and warm up to about 300 degrees. Then try and press in the seal with a piece of wood and some oil. 2. Find a place that has a press and have them press it in for me. What kind of shops would have a press for this? Vas, if you are reading this I was hoping to call you tomorrow as I didn't want to call you too late. I know you said that you were able to press this bearing in by hand but it seems like a VERY tight fit. Any advice would be much appreciated. Thanks in advance.
Attached Thumbnails Trying to put a seal in my supercharger and need advice........-supercharger-seal.jpg
Old Mar 31, 2010 | 07:59 PM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
This is a DIY. These seals go in very easy, just make sure you are square with the bore. use some aluminium or wood across the seal and just tap it in with a small hammer. When I say across, I men the outer edge (metal). You should not have to heat anything up or cool the seal down. The metal on the outside is thin, and acts like a spring.
I have installed plenty of these in gear boxes.
When installing a bearing in to a bore, I like to put it in some dry ice. This allows the bearing to shrink enough to just drop in to place, zero impact on the bearing. Works great
If you need to put a shaft through a bearing, cool the shaft, slides right in.
Old Mar 31, 2010 | 08:31 PM
350Z400rwhp
So I'm on the right track by freezing the seal that I am trying to install into the housing (see pic)? BTW, Congrats on your turbo kit Boosted. I followed your thread from the start, very impressive!
Old Mar 31, 2010 | 08:39 PM
Boosted Performance
Thanks.
Yes, you are on the right track but you don't need to freeze the seal. It is very flexible and will pop right in without much effort. You can put a bit of oil on the ouside to help it slide a bit better.
Freezing the bearings is good, as they are much more solid and do not flex like the seal.
Old Mar 31, 2010 | 11:22 PM
CAB350z's Avatar
CAB350z
+1 listen to Sasha, the man knows everything
Old Apr 1, 2010 | 08:00 AM
Boosted Performance
You are lucky my wife is not on here, she would let you have it. For some reason she doesn't like when people feed my "ego".
Old Apr 1, 2010 | 10:32 AM
350Z400rwhp
Ok, I stuck the seal in the freezer for a bit, sprayed some WD-40 on the case and used a piece of wood and a hammer. Went right in, thanks Sasha!
Old Apr 1, 2010 | 04:06 PM
05Z33's Avatar
05Z33
So how hard has this been for you to DIY? I'm thinking about taking on this project myself. Would you mind posting a step by step write up?
Old Apr 1, 2010 | 04:12 PM
350Z400rwhp
I took pics of the whole process and planned on putting together a DIY for everyone. Honestly for the input shaft seal it's a very easy job. The hardest part was taking my supercharger out but that only took about an hour. I'd say the whole job could be done in 2-3 hours. Now for the inner impeller shaft seal I'd add another hour to the job (I didn't replace that just because it's not leaking and I didn't want to replace it unless I had to). I'll have the DIY posted tonight.....
Old Apr 1, 2010 | 04:28 PM
350z006's Avatar
350z006
Nice!! Thanks a lot
BTW, which seals did you end up getting?
Old Apr 1, 2010 | 04:37 PM
350Z400rwhp
928 Motorsports $68 Shipped.
Old Apr 1, 2010 | 04:39 PM
Boosted Performance
$68 for a seal?
Those things can be bought for about $15. If you do this again, just take it to your local bearing speacialty store and they will get it for you.
All you need is ID, OD and width.
Old Apr 1, 2010 | 04:52 PM
350Z400rwhp
$68 for a seal?
Opps! Well at least I didn't pay someone $300 to rebuild it lol I though $68 (2 seals) was a deal, guess not. Live and learn.....
350Z_Al
Oct 29, 2020 07:44 PM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
