Ross's Twin Turbo build ::PIC HEAVY::
Old Apr 8, 2010 | 07:51 AM
BornSlippyZ's Avatar
BornSlippyZ
Great looking Diy Op!!
Old Apr 8, 2010 | 07:52 AM
RandomHer0's Avatar
RandomHer0
Originally Posted by ashtrojan2008
I'll never do it in the car again, it's too easy to drop it out of the bottom.
When i built it i pulled it out of the top..still should have dropped it.
Same, picked motor from top, even that was a pain.
Old Apr 8, 2010 | 08:05 AM
ashtrojan2008's Avatar
ashtrojan2008
Originally Posted by Andrei
I thought Haltech didn't work with the Revup? Does the proEFI work with a Revup?
Having a rev up is one of the reasons that I went with Haltech and ditched the Utec. Haltech will control the rev up's variable exhaust cam timing, while the utec will not. I'm not sure about the proEFI, because I think it's listed as 03-05.
Ross
Old Apr 8, 2010 | 09:08 AM
RandomHer0's Avatar
RandomHer0
Nice pics dude, lots of work...
Old Apr 8, 2010 | 09:34 AM
ashtrojan2008
thanks man. it's been lots of work, but lots of fun.
My old Borla TD
new turbo back test pipes
2.5-3" venturi reducer cone
H pipe
Passenger side hanger
Silencers
No silencers
Old Apr 8, 2010 | 05:40 PM
phunk's Avatar
phunk
CJ Motorsports
hey i like your thread!
about your fuel system... i see my pump output fitting there!
is your return line running straight back to the stock fuel pump assembly, or is to going to the surge can, with a surge can overflow back to the stock assembly?
Old Apr 8, 2010 | 05:53 PM
ashtrojan2008
Thanks! and yes, it is your pump fitting! made things much easier.
the return goes to the surge tank. I modified mine basically the same way rmedicx did. I'll go ahead and outline the whole setup for anyone who is interested
-6an feed from walbro to surge tank
-10an from surge tank to bosch 044
-8an bosch to fuel filter to Y adapter (single 8 to dual 6) to fuel rails
-6an to FPR, -6an FPR to Surge tank.
-6an overflow to the -4an 90* into the walbro pump assembly
All are SS braided except the 6an return is hardline.
I ordered a check valve to go after the 044, should be in tomorrow. The system isn't holding pressure when the pump is off, making it a *$&#^ to start.
Ross
Old Apr 8, 2010 | 05:59 PM
phunk's Avatar
phunk
CJ Motorsports
perfect... thats how i always recommend people use that surge can. BTW cant recall if the 044 has a check valve, but i bet the regulator is your pressure leak. how long does it take for pressure to go to zero after pump is off? I think a pump without a check valve would be rather instant (could be wrong on that), and most aftermarket regulators will slowly seep down.
Old Apr 8, 2010 | 06:08 PM
ashtrojan2008
Here are some random pictures of the car. It's basically factory on the exterior. Since these pictures I grabbed an acura rdx antenna, looks much better I need wheels and tires though, no traction
SR20DET 260z and fuel injected 496 big block chevy in the background. 11's club?
only difference to date is black windshield washer fluid cap
zinc plated x drilled, slotted ebay rotors. My stockers were warped, and these are temporary. They have worked fine and look better though so no complaints. They are centric blanks.
this is at the track. Those are some borrowed MT et streets, same size as my chinese street tires. But they were dry rotted, i ran better times on my street tires. Ran 11.84@122mph that night.
Audio
my old audiobahn aw1206t's next to my RE SE10D4's for the Z.
my finished amp/cap rack
custom box i built. It's sealed, not much air space, but sounds pretty good. When i go to the track, it slides right out. Only slide 2 locks and pull out banana plugs.
Ross
Old Apr 8, 2010 | 06:12 PM
ashtrojan2008
its instant. 3x at idle to 0 in less than a second. I assumed the bosch had a check valve built in like the walbro, but I guess not. I can't see any other reason to lose pressure that fast.
Also, what ait's are normal under boost? I can't seem to find an answer, maybe you could help me.
Ross
Old Apr 8, 2010 | 06:18 PM
dubi2087's Avatar
dubi2087
SICK *** THREAD. Great pics.
Old Apr 8, 2010 | 07:08 PM
SilverFox006's Avatar
SilverFox006
Great job on the build
Old Apr 8, 2010 | 10:13 PM
350Z400rwhp's Avatar
350Z400rwhp
Nice job man!
Old Apr 9, 2010 | 06:16 AM
rcdash's Avatar
rcdash
Congrats on your build - must be great to see your efforts culminate in a great run at the track. Normal AITs are usually about 15-20 degrees over ambient on most street kits. With some water injection, it's 15-20 degrees under. Have you gotten it properly tuned and dyno'd yet? I figure probably so since you ran it at the track - would love to see the chart.
Old Apr 9, 2010 | 10:31 AM
djamps's Avatar
djamps
Holy &^%&^ this thread is so full of win.
your custom exhaust looks alot like the AAM 3" (one of my fav's)
free bump on a sick build.
Old Apr 9, 2010 | 11:59 AM
ashtrojan2008
Thanks everyone for the comments. everything is really starting to feel like it has payed off
Thanks man. I haven't had it on the dyno since I installed the haltech, which was in January. I have been street tuning the haltech for fuel, here and there on the weekends when i get time, and i'll get on the dyno and tune timing soon. That was where my ait question came in.. on a log the other day I noticed 160 degrees at 7k rpm and 14 psi. It was 80-90 degrees outside, but my air filters are under the hood in the regular greddy location and coolant temps were getting a little hot, thus why i just ordered a radiator. I'll be setting up wm injection before i hit the dyno, to make sure i get over the 600 whp mark
That time slip was on the utec, when i had my borla and single walbro. We maxed out the pump at 460 whp on a dyno dynamics (14psi). the 750cc injectors were in the mid 90's duty cycle, So i did the bosch 044 route to make sure i had enough fuel.
ross
Old Apr 9, 2010 | 12:22 PM
nismonian's Avatar
nismonian
sick build man, so much win in one place
Old Apr 9, 2010 | 04:44 PM
  #38
0jiggy0's Avatar
0jiggy0
This is the best thread I have EVER seen.
Old Apr 13, 2010 | 08:57 AM
  #39
bldg250z's Avatar
bldg250z
very nice setup bro!!! still got a ways to go on my setup!
Old Apr 13, 2010 | 09:50 AM
  #40
escobar929's Avatar
escobar929
great work man, much love to all the DIYers out there
