Ross's Twin Turbo build ::PIC HEAVY::
Old Apr 14, 2010 | 07:08 AM
  #41
rrmedicx's Avatar
rrmedicx
Def Thumbs up for the DIY'er! Great stuff Ross!
Old Apr 14, 2010 | 07:48 AM
  #42
CRIDDA's Avatar
CRIDDA
Very nice. Great job
Old Apr 14, 2010 | 10:30 AM
  #43
ashtrojan2008's Avatar
ashtrojan2008
Originally Posted by nismonian
sick build man, so much win in one place
Originally Posted by 0jiggy0
This is the best thread I have EVER seen.
Originally Posted by bldg250z
very nice setup bro!!! still got a ways to go on my setup!
Originally Posted by escobar929
great work man, much love to all the DIYers out there
Thanks everyone. I'll post more pictures when I can and as more projects get done. I realized the car was overheating at idle the other day, cut the ac on and saw the temp go down so i know my main fan is out.. there is a recall and extended warranty on it, but I've got to get nissan to just swap the part out for me because I'm NOT letting the stealership touch my car. Maybe they'll flash my airbag light for free while i'm there
Ross
Old Apr 15, 2010 | 03:17 AM
  #44
kelly350Z's Avatar
kelly350Z
Awesome thread Ross. I've seen your video on youtube before several times. There is nothing like the satisfaction you get from installing or doing something you enjoy so much yourself.
Old Apr 15, 2010 | 04:00 AM
  #45
rcdash's Avatar
rcdash
If you've tripped the airbag light (from disconnecting the sensor), you can reset it yourself. There are several threads on the topic. Found one here:
https://my350z.com/forum/maintenance...srs-light.html
I saw Sharif do this for my car while I watched so I know it's possible. Took him two tries using his wristwatch to keep time, but it worked.
Hope to see you at ZdayZ - maybe the airstrip?
Old Apr 18, 2010 | 07:38 PM
  #46
ashtrojan2008
I am doing what i can to get to ZdayZ, but no way the airstrip, that's my finals week :/
The airbag reset procedure won't work at all. It has worked in the past when i replaced my crash sensor, but it won't erase the driver airbag code bout to send the module to that guy on ebay that resets them. I really don't want to do that though.....
https://my350z.com/forum/maintenance...rn-it-off.html
ross
Old Apr 19, 2010 | 05:29 AM
  #47
Glex25's Avatar
Glex25
Definitely nice work Ross
Jealous about the surge tank
Now get some wider wheels so you can gain some traction
you can always find used R-Compund tires on the cheap from race teams
that have only used them for a warm up
Old Apr 19, 2010 | 06:03 AM
  #48
SmallTuner's Avatar
SmallTuner
nice GF !!
Old Apr 19, 2010 | 10:53 AM
  #49
Hexxum001's Avatar
Hexxum001
Gotta give props to the DIYers. I wish I had these kind of skills. Great job bro.
Old Apr 19, 2010 | 11:36 AM
  #50
ashtrojan2008
Thanks, the surge tank really turned out well. I've been shopping for wheels but really don't have the money right now. I'm keeping my eye out for a set of rays g-games 99b... maybe a set will show up here in my price range
Originally Posted by SmallTuner
nice GF !!
yep its nice that she was there and understands what i'm talking about in car conversations. She puts most dudes to shame in "car talk"
Just give it a try man! with the right tools anything is possible.
ross
Old Apr 19, 2010 | 12:27 PM
  #51
ashtrojan2008
More pictures I found
Adding fittings to the surge tank
First color I painted it.. thought high temp exhaust paint would be more gasoline resistant. It wasnt.
Second paint, my favorite color of the three but still killed by gas. I replaced aam's cushion between the tank and the brackets with some 3M double sided tape. looks cleaner IMO
Had a leak on aam's weld. I may have nicked it with the grinder; i just laid a bead on top of it
-8AN check valve from JayRacing
works flawlessly, holds pressure now
mishimoto next to stock. she got me in the picture too lol
next mishimoto ad
my ambient temperature sensor has been showing some crazy numbers.. so i found it, which happened to be sandwiched between my intercooler and radiator. I moved it inside the factory lip (this picture was not final placement, it's where the red circle is). Works fine now.
my girl's rx-8. thought I'd throw that in there. future sr or ls swap
ross
Old Apr 24, 2010 | 02:05 PM
  #52
Dib07CE's Avatar
Dib07CE
what size/kind of tool was used to remove those^^ 16 bolts???
Old Apr 24, 2010 | 06:28 PM
  #53
350Z_LEE's Avatar
350Z_LEE
Hats off to you for doing all this stuff yourself. Great thread, and not too shabby of an E.T. either. Way to represent Louisiana
Old Apr 24, 2010 | 07:43 PM
  #54
ashtrojan2008
I'm pretty sure it was a 12 point socket, probably 10mm; its been a while, i try not to have to tear the bottom end down too often (like some people i know)
thanks bro. i try just need some wheels
Old Apr 26, 2010 | 03:06 PM
  #55
Dib07CE's Avatar
Dib07CE
sorry, i meant these bolts...
but thankyou for that answer too. that was probably going to be my next question.
Old Apr 26, 2010 | 03:22 PM
  #56
ashtrojan2008
those are the ones i was talking about. it may be torx sockets tho. i remember buying torx for something.
ross
Old Apr 26, 2010 | 03:38 PM
  #57
ashtrojan2008
19. Remove main bearing cap bolts.
NOTE:
Use TORX socket (size E14).
took that straight out of the FSM. I recommend downloading a copy.
ross
Attached Thumbnails Ross's Twin Turbo build ::PIC HEAVY::-fsm-diagram.jpg
Old Aug 21, 2010 | 10:46 PM
  #58
ashtrojan2008
Well I haven't posted here in a while, so it's time for an update.
About a week ago my ac went out in the 300zx and the 350z.. the same day
somehow the ac compressor pulley touched the high pressure hose and cut a hole in it.. $75 for a salvage line and about $25 for refrigerant and stuff
I installed my haltech ait sensor.. does anyone have a good way to calibrate it? I tried water and air... got totally different readings. the water was a more stable temperature, but i trust the air values better so i dunno
wrapped my intake pipe. didn't do much imho. everything is still hot as hell.
had to throw in some pics of the z32
still working on the tig skills
Injected performance is tuning the z32 and z33 on sept 11th.. i cannot wait, it's driving me insane. It will be a 14 hour drive.. but well worth it I hope.
Old Aug 21, 2010 | 11:10 PM
  #59
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Hope u trailer the z
Old Aug 21, 2010 | 11:20 PM
  #60
ashtrojan2008
we're trailering the 300 just in case something happens to one on the dyno we can drive the other home.
I'm not too worried about my car, i've got 30K miles on the motor so far with only my street tune
ross
