New built motor break in map??
Old Apr 18, 2010 | 09:17 AM
ttg35fort's Avatar
ttg35fort
Professional
Originally Posted by djtimodj
I asked the tuner about doing a oil and filter change while half way through thebreak in (im using joe gibbs break in oil) they have allways just run the car in with the same oil and then change to good stuff (im using motul 300v 15w50) for the final map. I understand that the oil may contain bits of crap as the motor wears in but the filter should catch it if there were any??
Last time around Roger told me not to worry about changing the oil/filter until the break-in period was over. That is what I did.
This time around I have two concerns. I lost two rod bearings. I shut the motor down fairly quickly, and I am replacing all oil lines and the oil coolers, I have a new short block, and the heads have been thoroughly cleaned. Still, I am going to play it ultra safe and change out the oil/filter very early. I'm leaning toward a dyno break-in based on the one article I found that actually provides what appears to be objective evidence as to the benefits of a dyno break-in, and based on my experiences with my stock motor. After the short break-in period, I am going to change the oil/filter again.
It may be overkill and a complete waste of money, but in comparison to the overall cost of the build, the cost to replace the oil/filter a couple of times is peanuts, and will give me good piece of mind.
Old Apr 18, 2010 | 01:07 PM
djtimodj's Avatar
djtimodj
I may look in to doing a fluid/filter change just for my piece of mine like you guys have stated.
Old Apr 19, 2010 | 07:02 AM
captj3's Avatar
captj3
If you really want know how your engine is doing then, I would suggest that you send a sample to a company like blackstone labs for a oil analysis. Do this with your break in and the next 2 oil changes. It will really give you a good idea of what is going on in the engine.
Old Apr 19, 2010 | 07:36 AM
djtimodj's Avatar
djtimodj
Yeah Im looking into oil analysis. I work for shell oil, we have labs on my site that do the fuel/oil testing for ferrari so im going to chase up a few lab tech's on my night shifts and see if they have time to test my oil!
2ndchanceZ
Oct 26, 2015 08:03 PM
