New Build
Old May 18, 2010 | 07:43 PM
thom000001's Avatar
thom000001
There room for a bigger snail in there.......like maybe a pte 6262????
Tom
Originally Posted by SH Luciano
i wasn't looking for "big" numbers, just hoping for 500 to the tire...which i've seen a few other builds get.
oh well, back to the drawing board...
Old May 18, 2010 | 07:56 PM
Elperuano's Avatar
Elperuano
How r u liking the block from IPP?
Old May 18, 2010 | 08:32 PM
SH Luciano's Avatar
SH Luciano
unfortunately there's no room, which is why aps used the smaller gt35r housing in the first place. i'm thinking ill either be picking up a greddy kit or doing some custom modifications to this and turn it into a twin kit (well not me modifying it but having a friend do the work).
block is great thus far, no problems at all.
Old May 18, 2010 | 08:52 PM
tig488's Avatar
tig488
try to either dump the wg to atmosphere or move it farther downstream, the way you have yours, its dumping it back at a 90 degree too close to the turbo. could be a backpressure problem, small housing too.
slick design on the wg tho.
Old May 19, 2010 | 06:48 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
If this was an issue with too small of a turbo, you would just see higher boost levels not making any more power, not a jagged boost curve up top. My turbos run out of steam with my stock cams above 16psi, but I can run a rock solid 20psi if I want to just blow hot air at the motor.
I vote for moving the WG dump further downstream and merging it with the exhaust at less of an angle. That might solve the boost issues right there.
Old May 19, 2010 | 07:00 AM
thom000001's Avatar
thom000001
How bout just making it an atmospheric dump to test to see if its the culprit?
Tom
Old May 19, 2010 | 07:16 AM
SH Luciano's Avatar
SH Luciano
Tom
that's kind of what i want to do right now...and who knows i may like the sound.
Old Jun 7, 2010 | 03:40 PM
SH Luciano's Avatar
SH Luciano
need some help from the haltech experts out there. couple problems i think may be tune related, but not 100% certain.
first, when at idle the tach has a tendancy to bounce around from 500rpm's to 1500rpms
secondly my afr's can vary just as wildly at idle and cruise, i.e. mid 10's to high 17's.
lastly, and i remember seeing another thread around here where op had a similar problem...if i'm cruising at a constand speed and press the gas for a little acceleration, my car goes very lean just for a second and hesitates (like high 16's to 17 afr's) and then richens up to where it should be.
if anybody has some advice for me to test, and/or wants some parameters out of the map to provide advice let me know...i'd be much obliged.
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
