Estimated # of hrs needed to swap heads
Old May 26, 2010 | 09:10 AM
mdcruz88's Avatar
mdcruz88
Default Estimated # of hrs needed to swap heads
Anybody know approximately how many hours would it take to swap both heads on a TT vq35de?
Old May 26, 2010 | 09:23 AM
str8dum1's Avatar
str8dum1
depends if you are dropping the motor, and then on which method you are using to drop the motor.
i'd figure 10-12 hours, esp if its your 1st time.
Old May 26, 2010 | 09:26 AM
Blackbird CPV35's Avatar
Blackbird CPV35
do yourself a favor and drop the motor, it would be ridiculously hard to do it with the motor in the car
Old May 26, 2010 | 09:47 AM
mdcruz88's Avatar
mdcruz88
Thanks guys. If I do proceed, will definitely drop the motor
Old May 26, 2010 | 10:29 AM
Vas_Z33's Avatar
Vas_Z33
( binder ) on here did his head gaskets with the motor in the car... Id ask him how long it took to take the heads out
Old May 26, 2010 | 10:31 AM
thom000001's Avatar
thom000001
I believe cam R&R flags for 12-13hrs with motor in car.....so its going to be similar to that.
Tom
Old May 26, 2010 | 11:09 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Really depends on many factors. Is there forced induction on the car already? In most cases, you are R/R'ing engine and taking everything apart except for the shortblock and trans bell housing. That is quite a bit of work.
Old May 26, 2010 | 12:35 PM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Since you will need to remove 90% of your twin turbo kit, you're looking at a pretty time consuming swap. Best way to go would be to drop the motor/trans out the bottom and disassemble everything outside of the car.
Pleask
Dec 21, 2021 03:17 PM
Fixxxercask
Nov 9, 2015 11:10 AM
SharX59
Sep 27, 2015 09:23 AM
