Powerlab?
Old Jun 4, 2010 | 08:55 AM
05blackdemon's Avatar
05blackdemon
Default Powerlab?
I have a bone stock 2005 350z. ive finally decided to pull the trigger on a single turbo. The question is is a 2005 z with 85k miles going to hold up with a turbo? im getting a new flywheel and clutch and its all going to be done right no short cuts. will it hold up? or should i just drop or build a new motor
Old Jun 4, 2010 | 09:02 AM
Nexx's Avatar
Nexx
no can predict if it will hold up. all cars a different. a brand new motor could pop on the dyno, a 100k car might go another 100k boosted or vice versa. you just never know. if you do it, do it right. spend 10 to 15k for the proper install, tune and supporting parts ie. gauges, clutch, cooling. all the little things will help maintain a reliable car. just make sure you are prepared to shell out close to another 10k if you motor does blow.
Old Jun 4, 2010 | 09:05 AM
05blackdemon
Nex i live in okc. there really arent any tuning shops here that will even touch my z. there is one in tulsa. full install with everything. cooler, clutch, gauges, tuned for $8,800. are there any good dfw shops thats worth my time to go down there and talk to them. i dont want crazy hp just enough to have alot of fun with but be reliable
Old Jun 4, 2010 | 09:11 AM
Nexx's Avatar
Nexx
i wouldnt let anyone F/I my car in the DFW honestly. not on a VQ platform at least. FSP is your best bet in the Oklahoma. $8800 + the powerlab kit or is that $8800 for everything? that seems very low if its $8800 for everything. also keep in mind, the drivers driving habit has a lot to do with the longevity of the motor. if you beat on your car constantly like i do then i would go very conservative on the about of boost you run. 6psi to 8psi at the most.
Old Jun 4, 2010 | 09:13 AM
05blackdemon
Also recommend any intake and dual exhaust systems?
Old Jun 4, 2010 | 09:15 AM
05blackdemon
Thats a quote from FSP and thats with EVERYTHING. yeah i will probably only run 6-8 daily. because of that reason. i bought this car to drive the snot out of it
Old Jun 4, 2010 | 09:23 AM
Nexx's Avatar
Nexx
intake? thats comes with the turbo kit.
exhaust, you can only run a single exhaust with a single turbo. that single can go into a muffler and have two tips like your stock exhaust currently is setup. personally with a single turbo i'd go with a single cannister 3" exhaust. greddy TIC single canister might be a good fit.
Old Jun 4, 2010 | 09:48 AM
05blackdemon
haha im not a gear head i have no idea I just wanna go fast! lol thank you nex for helpin me out i appreciate it bro
Old Jun 4, 2010 | 10:56 AM
go-fast's Avatar
go-fast
Old Jun 4, 2010 | 11:43 AM
J. Dub's Avatar
J. Dub
Cool, another turbo thread... Awesome!
Old Jun 4, 2010 | 12:17 PM
davboy's Avatar
davboy
Where the hell is the newb / search patrol?
Old Jun 4, 2010 | 12:21 PM
thatv35guy's Avatar
thatv35guy
The PowerLab GT35R Single Turbo is an awesome kit! Mine’s at Jet Hot right now getting coated…I should have it on by the end of the month or so…
My brother’s had a PowerLab GT35R on his Z for 2 years now, it’s tuned with ProEFI 48 pin ecu.
Old Jun 4, 2010 | 12:55 PM
ImWeeZzel's Avatar
ImWeeZzel
in for the build thread
Old Jun 4, 2010 | 01:35 PM
Nexx's Avatar
Nexx
well... he is a paying premier member. thought i would give him the benefit of the doubt.
trust me if it was a non paying member and with a post count of 1, i would have told him to DIAF.
Old Jun 4, 2010 | 01:52 PM
phreaktor's Avatar
phreaktor
Design Engineer
Wait so you cannot use a system like an Invidia N1 with a ST, Nexx? Can't you have a crossover pipe that runs to the midpipe or something?
Old Jun 4, 2010 | 02:07 PM
Nexx's Avatar
Nexx
phreak, is the N1 would work fine. just cant use a true dual exhaust with a single turbo. some people with true duals have removed the mid pipe and used a reverse y pipe with a true dual which isnt true dual anymore after you do that lol.
Old Jun 4, 2010 | 02:10 PM
UMW350Z's Avatar
UMW350Z
Build the motor, new brakes, all new fluids, clutch, flywheel, radiator, oil cooler, EBC...you NEED wheels and tires as well, suspension is going to matter also.
You got some buying to do, son...hope you got tons of cash or a low interest credit card.
Old Jun 4, 2010 | 02:12 PM
UMW350Z's Avatar
UMW350Z
I have a 3" JIC single exit exhaust that i had one my powerlab Z...just replaced with the Greddy Ti-C (but it had to be chopped up to work). The sound is about the same from inside, the single is a little louder...they both put out the same power.
Let me know if you want it...about 500 plus shipping
Old Jun 4, 2010 | 02:26 PM
phreaktor's Avatar
phreaktor
Design Engineer
Thanks bro... Expect some more annoying PM's in the near future.
Old Jun 4, 2010 | 03:01 PM
jeffie7's Avatar
jeffie7
did you miss my thread on the powerlab kit?
